Night Light and DisplayCal
hey, i have noticed something strange, i have a color calibrator and i did the calibration, so far so good but when the night light kicks in it seem that the calibration profile just stops working...
It should apply the calibration first and on top of that the blue light filter, but it doesn't... on top of that if i force the calibration profile the night light doesn't work and i have to reboot.
is there a fix for that?
Which “night light” are you using? If it’s part of a DE then use that DE’s colour settings to apply the profile rather than DisplayCAL.
i'm using the one in the display and monitor settings, how do i do that?
And which one is that? I have literally no idea what you have running on your system.
nothing, just the stuff that is preinstalled >.<
system settings > display and monitor > Night color (not night light)
it seems not working together with displaycal
Which is what? I have literally no idea what you installed on your system.
Garuda Gamer thing... i'm new to this linux thing... i literally haven't modified anything
You are obviously not catching the drift of what is being said here.
Without knowing the particulars of your system we can only make wild guesses. We do not have a crystal ball, and playing 50 questions gets old real fast. You need to post your system specifications as stipulated in the help request template that you ignored when you created your help request.
As per the forum guidelines/expectations please post the output of :
inxi -Faz
hey... i have no idea... next time i will post it just in case, how am i supposed to know what is asked from me if you are not clear... i don't have a crystal ball to know what exactly is wanted from me
rw rootflags=subvol=@ quiet
cryptdevice=UUID=53f62651-9e7c-4ac4-9ddc-9ae7a1225771:luks-53f62651-9e7c-4ac4-9ddc-9ae7a1225771
root=/dev/mapper/luks-53f62651-9e7c-4ac4-9ddc-9ae7a1225771 splash rd.udev.log_priority=3
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine:   Type: Desktop System: Micro-Star product: MS-7B79 v: 3.0 serial: <filter>
Mobo: Micro-Star model: X470 GAMING PLUS MAX (MS-7B79) v: 3.0 serial: <filter>
UEFI: American Megatrends v: H.60 date: 06/11/2020
CPU:       Info: 8-Core model: AMD Ryzen 7 1800X bits: 64 type: MT MCP arch: Zen family: 17 (23)
model-id: 1 stepping: 1 microcode: 8001138 cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 121595
Speed: 3800 MHz min/max: N/A Core speeds (MHz): 1: 3800 2: 3800 3: 3800 4: 3800 5: 3800 6: 3800
7: 3800 8: 3800 9: 3800 10: 3800 11: 3800 12: 3800 13: 3800 14: 3069 15: 3800 16: 3800
Graphics:  Device-1: NVIDIA TU104 [GeForce RTX 2080 Rev. A] vendor: ASUSTeK driver: nvidia v: 470.74
alternate: nouveau,nvidia_drm bus-ID: 27:00.0 chip-ID: 10de:1e87 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: nvidia
unloaded: modesetting alternate: fbdev,nouveau,nv,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 122 s-size: 533x302mm (21.0x11.9") s-diag: 613mm (24.1")
Monitor-1: DP-4 res: 2560x1440 dpi: 123 size: 527x296mm (20.7x11.7") diag: 604mm (23.8")
OpenGL: renderer: NVIDIA GeForce RTX 2080/PCIe/SSE2 v: 4.6.0 NVIDIA 470.74 direct render: Yes
Audio:     Device-1: NVIDIA TU104 HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 27:00.1
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus-ID: 29:00.3 chip-ID: 1022:1457 class-ID: 0403
Sound Server-1: ALSA v: k5.14.9-zen2-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI
driver: r8169 v: kernel port: f000 bus-ID: 22:00.0 chip-ID: 10ec:8168 class-ID: 0200
Drives:    Local Storage: total: 2.02 TiB used: 506.53 GiB (24.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM003-1CH162 size: 931.51 GiB
serial: <filter> rev: CC49 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37480G size: 447.13 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 1103 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Kingston model: SUV400S37240G size: 223.57 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 37R5
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: Toshiba model: MK5059GSXP size: 465.76 GiB
block-size: physical: 512 B logical: 512 B type: HDD rpm: 5400 serial: <filter> scheme: MBR
Partition: ID-1: / raw-size: 223.31 GiB size: 223.31 GiB (100.00%) used: 20.79 GiB (9.3%) fs: btrfs
dev: /dev/dm-0 maj-min: 254:0 mapped: luks-53f62651-9e7c-4ac4-9ddc-9ae7a1225771
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.45%) used: 706 KiB (0.3%) fs: vfat
dev: /dev/sdc1 maj-min: 8:33
ID-3: /home raw-size: 223.31 GiB size: 223.31 GiB (100.00%) used: 20.79 GiB (9.3%) fs: btrfs
ID-4: /var/log raw-size: 223.31 GiB size: 223.31 GiB (100.00%) used: 20.79 GiB (9.3%) fs: btrfs
ID-5: /var/tmp raw-size: 223.31 GiB size: 223.31 GiB (100.00%) used: 20.79 GiB (9.3%) fs: btrfs
ID-1: swap-1 type: zram size: 15.57 GiB used: 69 MiB (0.4%) priority: 100 dev: /dev/zram0
Sensors:   System Temperatures: cpu: 36.5 C mobo: N/A gpu: nvidia temp: 54 C
Fan Speeds (RPM): fan-1: 0 gpu: nvidia fan: 0%
Info:      Processes: 393 Uptime: 56m wakeups: 1 Memory: 15.57 GiB used: 5.91 GiB (37.9%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 Packages: 1671 pacman: 1666 lib: 489 flatpak: 5
Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06 ~~~
Read before posting. Saves making an ass of yourself.
Just read the template.
Post in and output from terminal.
Kernel is missing.
better making an ass out of myself rather than be a passive aggressive smartass, i switched to linux 3 days ago sorry for being new i guess… i’m done here, i will ask somewhere else… it looks it’s not noob friendly here
thanks for those that actually tried to help tho :stuck_out_tongue:
You read the posting template but chose to either ignore or avoid reading it altogether. You were asked by members several times to provide relevant information and, again, avoided posting it. You've wasted the time of several members with, apparently, expectations of being treated with kid gloves just because you're new. Well, being new doesn't preclude making an ass of yourself which, again, you have capably demonstrated.
New thread with more detail from the get-go:
