Newbie has issue with dependencies updating
just installed garuda linux, not for the first time and had an issue when updating.
The error said that two pipewire dependencies were in conflict:
:: Replace kwayland-server with extra/kwin? [Y/n] y
:: Replace lib32-sdl with multilib/lib32-sdl12-compat? [Y/n] y
:: Replace qemu with extra/qemu-desktop? [Y/n] y
:: Replace qemu-arch-extra with extra/qemu-emulators-full? [Y/n] y
:: Replace sdl with community/sdl12-compat? [Y/n] y
:: Replace wxgtk-common with extra/wxwidgets-common? [Y/n] y
:: Replace wxgtk3 with extra/wxwidgets-gtk3? [Y/n] y
resolving dependencies...
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
:: wireplumber and pipewire-media-session are in conflict
What should i do to resove this.
garuda-inixi command output here:
Kernel: 5.17.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=15156c4f-3e3e-41d3-958e-6a41e5b966d5 rw rootflags=subvol=@
Type: Laptop System: HP product: OMEN by HP Laptop 15-ce0xx v: N/A
Mobo: HP model: 838F v: 40.28 serial: <superuser required>
UEFI: American Megatrends v: F.24 date: 07/05/2021
ID-1: BAT0 charge: 61.1 Wh (100.0%) condition: 61.1/61.1 Wh (100.0%)
volts: 17.4 min: 15.4 model: HP Primary type: Li-ion serial: N/A
status: full
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: <filter>
Info: model: Intel Core i5-7300HQ bits: 64 type: MCP arch: Kaby Lake
family: 6 model-id: 0x9E (158) stepping: 9 microcode: 0xEC
desc: 1x6 MiB
Speed (MHz): avg: 3263 high: 3482 min/max: 800/3500 scaling:
driver: intel_pstate governor: performance cores: 1: 3124 2: 3210 3: 3238
4: 3482 bogomips: 19999
Type: l1tf
STIBP: disabled, RSB filling
Device-1: Intel HD Graphics 630 vendor: Hewlett-Packard driver: i915
v: kernel ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:591b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Hewlett-Packard
driver: nvidia v: 510.60.02 alternate: nouveau,nvidia_drm pcie: gen: 2
speed: 5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: none off: HDMI-A-2 empty: DP-2 bus-ID: 01:00.0 chip-ID: 10de:1c8d
Device-3: Chicony HP Wide Vision FHD Camera type: USB driver: uvcvideo
bus-ID: 1-6:3 chip-ID: 04f2:b593 class-ID: 0e02 serial: <filter>
gpu: i915,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1440 s-dpi: 96 s-size: 1182x380mm (46.54x14.96")
s-diag: 1242mm (48.88")
Monitor-1: not-matched mapped: HDMI-1-0 pos: primary,top-left
res: 2560x1440 dpi: 109 size: 597x336mm (23.5x13.23") diag: 685mm (26.97")
modes: N/A
Monitor-2: eDP-1 pos: bottom-r model: LG Display 0x0532 built: 2016
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 22.0.2
direct render: Yes
Device-1: Intel CM238 HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a171
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
v: kernel pcie: speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s
Sound Server-1: ALSA v: k5.17.4-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.50 running: yes
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 3b:00.0 chip-ID: 10ec:8168
speed: 2.5 GT/s lanes: 1 bus-ID: 3c:00.0 chip-ID: 8086:095a class-ID: 0280
bus-ID: 1-7:5 chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 1.03 TiB used: 14.4 GiB (1.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: LITE-ON model: CA1-8D128-HP
size: 119.24 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: A182
temp: 37.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM049-2GH172
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: RXM3
ID-1: / raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
used: 14.4 GiB (12.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-4: /var/log raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-5: /var/tmp raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.38 GiB used: 1.5 MiB (0.0%)
System Temperatures: cpu: 58.0 C pch: 60.5 C mobo: N/A
Fan Speeds (RPM): cpu: 7680 fan-2: 0
Processes: 254 Uptime: 24m wakeups: 3 Memory: 15.38 GiB
used: 3.62 GiB (23.6%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1704 lib: 511 Shell: fish v: 3.4.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
Garuda (2.6.2-1):
System install date:     2022-07-29
Last full system update: 2022-07-29
Is partially upgraded:   Yes
many thanks
Please try:
sudo pacman -Rdd pipewire-media-session && garuda-update
PS: I edited your post to format it according to:
Thankyou very much for your help, however when the update command occurs there is an error
error: optimus-manager-qt: signature from "Nico Jensch (Chaotic-AUR) <dr460nf1r3@garudalinux.org>" is invalid
:: File /var/cache/pacman/pkg/optimus-manager-qt-1.6.9-1-x86_64.pkg.tar.zst is corrupted (invalid or corruptedpackage (PGP signature)).
Do you want to delete it? [Y/n] y
error: failed to commit transaction (invalid or corrupted package)
Maybe try:
garuda-update remote keyring
same result
Try
sudo rm /var/cache/pacman/pkg/optimus-manager-qt-1.6.9-1-x86_64.pkg.tar.zst
If that doesn't work, try
sudo find /var/cache/pacman/pkg/ -iname "*.part" -delete
(This is what I would do in Arch, I hope it's also applicable here)
Thankyou so much, the first otpion didnt recognise the file, said that the file didnt exist , and the second caused a new error to occur
[🔴] × sudo pacman -Syu
:: Synchronising package databases...
garuda is up to date
core is up to date
extra is up to date
community is up to date
multilib is up to date
chaotic-aur                          1970.2 KiB  4.22 MiB/s 00:00 [------------------------------------] 100%
:: sweet-theme-full-git and kvantum-theme-sweet-git are in conflict
If you use garuda-update many of the conflict issues etc. will be taken care of automatically.
First I think you could try garuda-update again.
If you get the same error, you could temporarily try this workaround (the -git version)
and then garuda-update
not sure how to do this without triggering the error
] × sudo pacman -S optimus-manager-qt-git
[sudo] password for sebastian:
:: optimus-manager-qt-git and optimus-manager-qt are in conflict. Remove optimus-manager-qt? [y/N] y
Packages (2) optimus-manager-qt-1.6.5-1 [removal]  optimus-manager-qt-git-1.6.9.r1.g4c35f53-1
Total Download Size:   0.20 MiB
Total Installed Size:  0.86 MiB
Net Upgrade Size:      0.02 MiB
:: Retrieving packages...
optimus-manager-qt-git-1.6.9.r1....   205.8 KiB   497 KiB/s 00:00 [-------------------------------------] 100%
(1/1) checking keys in keyring                                     [-------------------------------------] 100%
(1/1) checking package integrity                                   [-------------------------------------] 100%
error: optimus-manager-qt-git: signature from "Nico Jensch (Chaotic-AUR) <dr460nf1r3@garudalinux.org>" is invalid
:: File /var/cache/pacman/pkg/optimus-manager-qt-git-1.6.9.r1.g4c35f53-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] n
error: failed to commit transaction (invalid or corrupted package (PGP signature))
this triggers the same conflict error
optimus-manager-qt-1.6.9-1-x86_64     205.8 KiB   420 KiB/s 00:00 [-------------------------------------] 100%
dxvk-mingw-git-1.10.1.r364.gea76...     7.4 MiB  7.38 MiB/s 00:01 [-------------------------------------] 100%
Total (2/2)                             7.6 MiB  7.33 MiB/s 00:01 [-------------------------------------] 100%
(1000/1000) checking keys in keyring                               [-------------------------------------] 100%
(1000/1000) checking package integrity                             [-------------------------------------] 100%
error: sweet-kde-theme-git: signature from "Nico Jensch (Chaotic-AUR) <dr460nf1r3@garudalinux.org>" is invalid
:: File /var/cache/pacman/pkg/sweet-kde-theme-git-r24.9e36d3a-4-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: sweet-folders-icons-git: signature from "Nico Jensch (Chaotic-AUR) <dr460nf1r3@garudalinux.org>" is invalid
:: File /var/cache/pacman/pkg/sweet-folders-icons-git-r12.d50fbe3-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: sweet-theme-full-git: signature from "Nico Jensch (Chaotic-AUR) <dr460nf1r3@garudalinux.org>" is invalid
:: File /var/cache/pacman/pkg/sweet-theme-full-git-r277.7190f77-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: ananicy-cpp: signature from "Nico Jensch (Chaotic-AUR) <dr460nf1r3@garudalinux.org>" is invalid
:: File /var/cache/pacman/pkg/ananicy-cpp-1.0.0.rc6-1.1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: ananicy-rules-git: signature from "Nico Jensch (Chaotic-AUR) <dr460nf1r3@garudalinux.org>" is invalid
:: File /var/cache/pacman/pkg/ananicy-rules-git-2.2.1.r297.g8e78562-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: bluetooth-autoconnect: signature from "Nico Jensch (Chaotic-AUR) <dr460nf1r3@garudalinux.org>" is invalid
:: File /var/cache/pacman/pkg/bluetooth-autoconnect-1.3-1.1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: find-the-command-git: signature from "Nico Jensch (Chaotic-AUR) <dr460nf1r3@garudalinux.org>" is invalid
:: File /var/cache/pacman/pkg/find-the-command-git-2.0.r1.g608d240-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
:: File /var/cache/pacman/pkg/optimus-manager-qt-1.6.9-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
sudo pacman -Sy archlinux-keyring chaotic-keyring
Then update again.
the named command finished without error, however then the upgrade errored out with the same previous conflicts
No, that's a different error. Apparantly those two packages - sweet-theme-full-git and kvantum-theme-sweet-git - are in conflict now. Try to delete one before trying updating once more.
This is a fresh installation? Maybe next time use a fresh installation medium too.
Did you update via garuda-update?
If yes, try to remove the package via sudo pacman -Rdd <package> (<package> being either sweet-theme-full-git or kvantum-theme-sweet-git, whatever you have installed) and then update again
The kvantum deleted, however when i tried to update afterward i got another error
:: File /var/cache/pacman/pkg/ananicy-rules-git-2.2.1.r297.g8e78562-1-any.pkg.tar.zst is corrupted (invalid orcorrupted package (PGP signature)).
:: File /var/cache/pacman/pkg/bluetooth-autoconnect-1.3-1.1-any.pkg.tar.zst is corrupted (invalid or corruptedpackage (PGP signature)).
error: plymouth-git: signature from "Nico Jensch (Chaotic-AUR) <dr460nf1r3@garudalinux.org>" is invalid
:: File /var/cache/pacman/pkg/plymouth-git-22.02.122.r50.g0d30fe59-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
try
sudo pacman -Sy archlinux-keyring chaotic-keyring && garuda-update
I also faced this issue , I think one of the chaotic mirror is the root of all these pgp failures
BTW remove optimus-manager-qt and install optimus-manager-qt-git
Do this for all conflicting packages if garuda-update does not helps
Which one?
Maybe India one According to https://status.chaotic.cx/geo
