Hello community!
inxi:
Kernel: 6.5.7-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=21c7fde8-1bef-4f82-abc8-364dad2d6848 rw rootflags=subvol=@
resume=UUID=59131e58-a432-49f0-bae1-aebf3325230e loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 dm: SDDM
Type: Laptop System: HP product: OMEN by HP Laptop 15-dc1xxx v: N/A
Mobo: HP model: 8574 v: 21.17 serial: <filter> UEFI: AMI v: F.22
date: 05/03/2021
ID-1: BAT0 charge: 70.0 Wh (97.9%) condition: 71.5/71.5 Wh (100.0%)
volts: 17.5 min: 15.4 model: HP Primary type: Li-ion serial: N/A
status: not charging
Info: model: Intel Core i7-9750H socket: BGA1440 (U3E1) note: check bits: 64
type: MT MCP arch: Coffee Lake gen: core 9 level: v3 note: check built: 2018
process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 0xD (13)
microcode: 0xFA
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2869 high: 4199 min/max: 800/4500 base/boost: 3960/8300
scaling: driver: intel_pstate governor: powersave volts: 1.1 V
ext-clock: 100 MHz cores: 1: 3300 2: 1593 3: 3000 4: 4199 5: 800 6: 3300
7: 4063 8: 3566 9: 3618 10: 3000 11: 800 12: 3197 bogomips: 62399
Device-1: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Hewlett-Packard
driver: nvidia v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-09) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1f11 class-ID: 0300
Device-2: Lite-On HP Wide Vision HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 04ca:707f
Display: server: X.Org v: 21.1.8 with: Xwayland v: 23.2.1 compositors:
1: kwin_x11 2: Tabby driver: X: loaded: nvidia gpu: nvidia display-ID: :0
Screen-1: 0 s-res: 1920x1080 s-dpi: 143 s-size: 341x191mm (13.43x7.52")
s-diag: 391mm (15.39")
Monitor-1: Unknown-1 mapped: DP-2 res: 1920x1080 hz: 60 dpi: 142
size: 344x194mm (13.54x7.64") modes: 1920x1080
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 535.113.01
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2
memory: 5.86 GiB
API: Vulkan v: 1.3.264 layers: 1 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 2060 driver: nvidia v: 535.113.01
device-ID: 10de:1f11 surfaces: xcb,xlib
Device-2: NVIDIA TU106 High Definition Audio vendor: Hewlett-Packard
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
API: ALSA v: k6.5.7-zen2-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.82 status: n/a (root, process) with:
lanes: 1 port: 3000 bus-ID: 3c:00.0 chip-ID: 10ec:8168 class-ID: 0200
speed: 5 GT/s lanes: 1 bus-ID: 3d:00.0 chip-ID: 8086:2723 class-ID: 0280
IF-ID-1: ztksey564h state: unknown speed: 10000 Mbps duplex: full
mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:4 chip-ID: 8087:0029
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.2
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c010c
v: 3.0 port: 5020 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 1.84 TiB used: 143.5 GiB (7.6%)
model: MZVLB1T0HBLR-000H1 size: 953.87 GiB block-size: physical: 512 B
fw-rev: HPS0NEXF temp: 43.9 C scheme: GPT
SMART: yes health: PASSED on: 357d 4h cycles: 1,719
read-units: 74,518,345 [38.1 TB] written-units: 81,076,733 [41.5 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
family: based SSDs size: 931.51 GiB block-size: physical: 512 B
logical: 512 B sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 1B6Q temp: 36 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 89d 4h cycles: 1385
written: 6.01 TiB Pre-Fail: reallocated sector: 98 threshold: 10
ID-1: / raw-size: 896.9 GiB size: 896.9 GiB (100.00%)
used: 143.47 GiB (16.0%) fs: btrfs block-size: 4096 B dev: /dev/sda2
maj-min: 8:2
used: 29.4 MiB (11.5%) fs: vfat block-size: 512 B dev: /dev/sda1
maj-min: 8:1
ID-3: /home raw-size: 896.9 GiB size: 896.9 GiB (100.00%)
maj-min: 8:2
ID-4: /var/log raw-size: 896.9 GiB size: 896.9 GiB (100.00%)
maj-min: 8:2
ID-5: /var/tmp raw-size: 896.9 GiB size: 896.9 GiB (100.00%)
maj-min: 8:2
ID-1: swap-1 type: partition size: 34.36 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 31.23 GiB used: 5 MiB (0.0%) priority: 100
System Temperatures: cpu: 65.0 C pch: 57.0 C mobo: N/A gpu: nvidia
temp: 55 C
Fan Speeds (rpm): cpu: 2395 fan-2: 2216
Processes: 345 Uptime: 25m wakeups: 1 Memory: total: 32 GiB
available: 31.23 GiB used: 6.19 GiB (19.8%) Init: systemd v: 254
pm: pacman pkgs: 1922 libs: 541 tools: pamac,paru,yay
Shell: garuda-inxi (sudo) default: Bash v: 5.1.16 running-in: tabby
inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2021-07-24
Last full system update: 2023-10-16
Relevant software: timeshift(custom) tlp NetworkManager mkinitcpio nvidia-dkms
Windows dual boot: Yes
Today after update, NetworkManager started behaving weirdly again. It refuses to connect to my primary SSIDs saying Wireless Interface wlo1 - the wifi network could not be found. I’ve tried deleting the connection and adding it again, without success. It will connect to a hotspot provided by my iPhone, but it won’t connect to my home SSID.
I don’t have a problem with resetting the whole NetworkManager, if someone can just point me in the right direction, please.
Additional info - I’m using same SSID for 2.4 and 5Ghz wireless. Don’t have any other networks accessible to me for testing, and I cannot change the router settings to another SSID because that would mess up everything else (which is working) and my wife would kill me ![]()
Thanks in advance for any help.
