I am getting an issue again, that plagued me a while ago. I always managed to temporarily fix it, and I want to track it down this time.
The Network Manager tries to connect me to an Ethernet connection, while this installation has never seen one at all, and particularly not at the time.
It fails to connect and tries again.
This loop doesn’t end, it just continues to disconnect and tries to connect again.
I added the journalctl since the boot, it started immediately after that one.
journalctl -r -b
FGD
13 October 2023 13:34
2
Well that’s kinda annoying!
Are you able to remove the Ethernet/Wired connection from System Settings ?
I think it’s under Network , not on my machine right now.
FGD
13 October 2023 14:57
4
Ha I see, it even decides to appear/disappear by itself in System Settings!
I’m not good enough with networking to go deeper on this one.
No existing bug on KDE.org ?
I didnt found any.
The Network Manager is although not a KDE tool, it is its own thing.
The search terms loop, connect and auto-connect didn’t yield anything either.
The issue exists since at least a year, though.
I don’t know, if Network Manager is to blame, even.
FGD
13 October 2023 15:33
6
Are you able to reproduce with a different installation, or from an ISO?
Yes, I experienced this issue with Garuda last year, and now again on this ISO from October.
FGD
13 October 2023 15:36
8
Sorry, I meant a Live ISO, does it also happen?
The issue occurs relatively unpredictably. I had months where no boot caused this, so I think it is relatively tricky to reproduce this live.
Are you concerned with the customizations that I did to the system, or the different image that the live mode boots?
FGD
13 October 2023 16:36
10
Not really concerned about those, I don’t have enough knowledge about networking apps/services to make any possible link.
could you share journalctl -u NetworkManager after telling the system to connect?
tbg
13 October 2023 19:15
12
This could be some type of bug with Network Manager or any other networking component. Sometimes testing an alternate to network manager may help troubleshoot the problem.
The best GUI alternative to network manager is to test out Connman & cmst. I have not used Connman in a very long time, but I have found it an adequate replacement for Network Manager in the past. Although, I will say Connman is very different to Network Manager and it does take a fair bit of getting used to.
https://wiki.archlinux.org/title/ConnMan
I don’t know what you mean with “after telling the system to connect”
It connects constantly, and journalctl is supposed to show all the past attempts, I assume?
I have internet, if that’s it, what you mean.
The wlan works just as expected, and I don’t have any issues with that whatsoever.
This is the log: Paste.ee - Network Manager
tbg:
ConnMan - ArchWiki
That is a very good idea, but again, it may take months to trigger this issue again.
If I switch now to ConnMan, I might use it for months, until the issue happens again, and then I only know, that it is not related to Network Manager.
Or, worse, I wait for months, nothing happens and it could still be both, Network Manager or something else.
So I guess just filling a report for Network Manager and working through it with the guys, would make more sense.
Or, that might actually be sensible, changing the DE.
I could strip myself from Plasma at the running instance, and see if it tries to reconnect again.
I guess I could do this on the fly, without going back to the login screen.
To some WM?
tbg
14 October 2023 08:57
14
I can’t see any smoking gun in your logs, but without your garuda-inxi output it somewhat limits further suggestions.
A few universal suggestions:
Make sure your bios is up to date.
Power down your computer, then remove all AC & DC power sources. Leave the computer without power for several minutes then restart.
Try a different session, switch to X11 if using Wayland and vice versa.
Switch to iwd if using wpa_supplicant and vice versa.
Will do so.
This happens regularly. The battery is already pretty dry, and discharges quickly. Then, the computer is without a power source for long.
Happens on both.
Will look into this.
Please, post garuda-inxi here in this post
Kernel: 6.5.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=4836c503-d2d0-481e-a632-f9ac2f82aebc rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Type: Laptop System: HP product: HP EliteBook 820 G3 v: N/A
Mobo: HP model: 807C v: KBC Version 85.61 serial: <superuser required>
UEFI: HP v: N75 Ver. 01.05 date: 03/22/2016
ID-1: BAT0 charge: 36.0 Wh (100.0%) condition: 36.0/36.0 Wh (100.0%)
volts: 12.8 min: 11.4 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: full
Info: model: Intel Core i5-6200U bits: 64 type: MT MCP arch: Skylake
model-id: 0x4E (78) stepping: 3 microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 500 min/max: 400/2800 scaling: driver: intel_pstate
governor: powersave cores: 1: 500 2: 500 3: 500 4: 500 bogomips: 19200
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports:
active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:1916 class-ID: 0300
Device-2: Cheng Uei Precision Industry (Foxlink) HP HD Camera
driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 1-9:4 chip-ID: 05c8:0383 class-ID: 0e02
Monitor-1: eDP-1 res: 1366x768 size: N/A modes: N/A
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 520 (SKL GT2)
device-ID: 8086:1916 memory: 7.25 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.264 layers: 3 device: 0 type: integrated-gpu name: Intel
HD Graphics 520 (SKL GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:1916 surfaces: xcb,xlib,wayland device: 1 type: cpu
bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
API: ALSA v: k6.5.7-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.81 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I219-V vendor: Hewlett-Packard driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:1570 class-ID: 0200
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24f3 class-ID: 0280
Device-3: HP HP lt4120 Snapdragon X5 LTE driver: cdc_ether type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:7 chip-ID: 03f0:9d1d
IF: enp0s20f0u3i1 state: up speed: 425 Mbps duplex: half mac: <filter>
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:2 chip-ID: 8087:0a2b
Local Storage: total: 894.26 GiB used: 22.2 GiB (2.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Patriot model: M.2 P310 480GB
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: EDFM90.0 temp: 29.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37480G
tech: SSD serial: <filter> fw-rev: 1103 scheme: GPT
used: 22.19 GiB (5.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 7.42 GiB used: 3.97 GiB (53.5%)
System Temperatures: cpu: 64.0 C pch: 53.0 C mobo: N/A
Processes: 239 Uptime: 15h 43m wakeups: 5 Memory: total: 8 GiB note: est.
available: 7.42 GiB used: 5.43 GiB (73.1%) Init: systemd v: 254
pm: pacman pkgs: 1490 libs: 377 tools: octopi,paru Shell: fish v: 3.6.1
running-in: yakuake inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2023-10-05
Last full system update: 2023-10-13 ↻
Happy weekend, SGS
from what I found online, maybe your dhcp client is having some issues.
Please check what you’re using here and then upload the service’s log
wpa_supplicant or iwd are about wireless connections.
How is this going to help with my device connecting randomly to non-existent wired connections?
I use the default solution, so the inbuild Network Manager stuff.
The connection that is trying to establish itself, does not show, if it is trying to do so via 4 or 6, but
I am able to set the setting “ipv4 is required for this connection” and it even lasts beyond the loop iterations.
Same thing for ipv6. Doing so does not change anything, and assuming this setting is applying, can we outrule, that it is either the ipv4 or ipv6 implementation, right?
I can try to swap the whole network stack, but again, then is the issue most likely gone anyway, if it is actually being fixed, or simply not yet triggered again.
Connman looks really good, I would love to try this one eventually.
Well then your overall best option seems to be to crank up the loglevel:
create /etc/NetworkManager/conf.d/95-loglevel.conf and add
[logging]
level=TRACE
domains=ALL
Then restart NetworkManager, and upload the connection attempt logs again
I created that file, and then restarted the NetworkManager via systemctl restart NetworkManager and got this as the logs:
And no connections are possible anymore AT ALL.
Also Wifi doesn’t connect anymore.
It seems not to be amused by my attempt to increase the log level.
Setting the log level back to normal and restarting NetworkManager again
did not bring back the functionality.
This new error popup appears:
I had to restart the whole system.
The issue is gone now.
So, the opportunity to track the issue down, is gone for now as well.
I will report again, if I am able to reproduce.
