that’s weird. I took that directly from the man page
huh restarting the service worked when I tinkered with the config
So no more connectivity issues? Did you really not once restart your computer after posting this issue? It’s been a week!
I don’t think that is intended behavior. I suspect that my bug correlates with either the restart itself or the log functionality.
As I have elaborated on, this issue happened in the past, and I remember using systemctl restart NetworkManager with no success.
But I cannot remember it bugging my existing, and working WiFi connections back then.
Could be just bad memory, though.
I am sure, this is how its supposed to happen.
No, its been a day.
And yes, I did not restart it.
I usually have my laptop configured to shut down the display, when I close the lid.
I paid attention, that it had always a power source. ![]()
OK, I seem to have another issue.
I just wanted to verify, that now, as the issue is gone, I can simply add that log config and restart NetworkManager. The result was the same:
I do now a couple of experiments with restarting that service, with either no configs around logging, or them being enabled.
Edit: I can confirm:
The issue has nothing to do with the log setting.
My particular setup does not restart NetworkManager properly.
That means:
A fresh reboot gives me a perfectly working internet connection.
systemctl restart NetworkManager just kills it.
I am on the current test ISO, updated system, Wayland.
Kernel: 6.5.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=4836c503-d2d0-481e-a632-f9ac2f82aebc rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Type: Laptop System: HP product: HP EliteBook 820 G3 v: N/A
Mobo: HP model: 807C v: KBC Version 85.61 serial: <superuser required>
UEFI: HP v: N75 Ver. 01.05 date: 03/22/2016
ID-1: BAT0 charge: 36.0 Wh (100.0%) condition: 36.0/36.0 Wh (100.0%)
volts: 12.8 min: 11.4 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: full
Info: model: Intel Core i5-6200U bits: 64 type: MT MCP arch: Skylake
model-id: 0x4E (78) stepping: 3 microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 500 min/max: 400/2800 scaling: driver: intel_pstate
governor: powersave cores: 1: 500 2: 500 3: 500 4: 500 bogomips: 19200
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports:
active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:1916 class-ID: 0300
Device-2: Cheng Uei Precision Industry (Foxlink) HP HD Camera
driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 1-9:4 chip-ID: 05c8:0383 class-ID: 0e02
Monitor-1: eDP-1 res: 1366x768 size: N/A modes: N/A
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 520 (SKL GT2)
device-ID: 8086:1916 memory: 7.25 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.264 layers: 3 device: 0 type: integrated-gpu name: Intel
HD Graphics 520 (SKL GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:1916 surfaces: xcb,xlib,wayland device: 1 type: cpu
bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
API: ALSA v: k6.5.7-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.81 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I219-V vendor: Hewlett-Packard driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:1570 class-ID: 0200
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24f3 class-ID: 0280
Device-3: HP HP lt4120 Snapdragon X5 LTE driver: cdc_ether type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:7 chip-ID: 03f0:9d1d
IF: enp0s20f0u3i1 state: up speed: 425 Mbps duplex: half mac: <filter>
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:2 chip-ID: 8087:0a2b
Local Storage: total: 894.26 GiB used: 22.2 GiB (2.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Patriot model: M.2 P310 480GB
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: EDFM90.0 temp: 29.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37480G
tech: SSD serial: <filter> fw-rev: 1103 scheme: GPT
used: 22.19 GiB (5.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 7.42 GiB used: 3.97 GiB (53.5%)
System Temperatures: cpu: 64.0 C pch: 53.0 C mobo: N/A
Processes: 239 Uptime: 15h 43m wakeups: 5 Memory: total: 8 GiB note: est.
available: 7.42 GiB used: 5.43 GiB (73.1%) Init: systemd v: 254
pm: pacman pkgs: 1490 libs: 377 tools: octopi,paru Shell: fish v: 3.6.1
running-in: yakuake inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2023-10-05
Last full system update: 2023-10-13 ↻
Without your inxi I had no idea which network adapters your system had. The reason I asked for you to do a complete power down and reboot was in case you had an Intel Ethernet card. I recalled a bug from way back with Intel ethernet cards that required that or there was connectivity problems. This bug with Intel cards has a habit of resurfacing sometimes years later. Your fix may have been unrelated to the reboot, but there’s a good chance that’s what helped.
This is one of the reasons we always want a garuda-inxi output on help requests. Especially with connectivity problems, knowing the adapter make and model is of paramount importance. Please, always provide an inxi whenever opening a help request.
Don’t worry too much about that, NM has always worked that way on my machine as well. Including the Limited Connectivity you had which required a reboot.
Any time I have a connectivity problem (most of the time it’s when I wake up. Not me, my machine), I don’t even bother anymore trying to restart services or kill stuff or whatever, it never works and keeps me disconnected, so I reboot straight away.
“This bug with Intel cards has a habit of resurfacing sometimes years later.”
So you recommend to just don’t use it or what? I’ve just installed Garuda on my HP Omen 15 laptop, I thought that I’ll be able to have it done before midnight and go to sleep and I can’t even connect it to the network.
I’ve spent hours on trying to at least find something that will let me explain what’s wrong and honestly I’m so exhausted that I’m not even able to get myself together and find a way to copy the garuda-inxi from my laptop to my phone without having a free USB port.
(long story short: it’s connecting, saying that it has limited access, then no access, disconnecting, having problem with some IP settings and I don’t know why because all wi-fis in my block have been detected and the signal is strong and it’s the first time that something has a problem with connecting to it)
I don’t even care anymore but can you please explain to me why would it install the drivers for my on-board Ethernet (RTL8111/8168/8411) and Wi-Fi card (Intel Wi-Fi 6 AX200), since it wasn’t able to do the same for the Alfa AWUS036ACS adapter that is recommended everywhere as an out-of-the-box working on Kali Linux?
Why Garuda Linux running on a quite powerful laptop can’t do what a Debian distro on a thin client was able to do without any issues?
And hello everybody by the way and good night… or good morning already.
Completely different network components @CoreyFalken . Your Ethernet card is a Realtek adapter, your WiFi models are also very different, (although both are Intel).
Use USB phone tethering for a working internet connection.
I would suggest installing and testing the linux-lts and linux-mainline kernels.
If that does not help, you should really open a separate help request thread of your own.
Welcome to the Garuda forum Corey. ![]()
Can you rephrase that maybe a little?
Does Garuda use different drivers or just a different version?
For the last case, do as @tbg said, installing an LTS kernel could fix this.
Or do you say, that these distros use a completely different driver, and you wonder, how you could install that one?
Actually, restarting NetworkManager used to work quite well, although on KaOS, and a few years back.
Recently, and certainly since I have adopted Garuda, was it simply not needed anymore, since the network connection just worked.
Potentially because I don’t use Realtek and similar chips, which most often require non-free or reverse-engineered drivers.
