My computer crashed during an update which caused Garuda to be missing from the boot options. I booted from a live usb to try and fix the issue using Garuda Boot Repair, but aftering running the fix option Windows also disappeared from the boot options.
sudo mount /dev/sda2 /mnt
─garuda@garuda in ~ as 🧙 took 25ms
╰─λ cd /mnt/@
╭─garuda@garuda in /mnt/@🔒 as 🧙 took 87ms
╰─λ sudo mount /dev/sda1 /boot/efi
╭─garuda@garuda in /mnt/@🔒 as 🧙 took 36ms
╰─λ sudo grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=garuda --recheck
Installing for x86_64-efi platform.
grub-install: error: failed to get canonical path of `overlay'.
here is my fdisk output
╭─garuda@garuda in /mnt/@🔒 as 🧙 took 3ms
╰─λ sudo fdisk -l
Disk /dev/sda: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: Samsung SSD 870
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: D5B18F49-EAF4-A047-BEB6-9F33B5B5526D
Device Start End Sectors Size Type
/dev/sda1 4096 618495 614400 300M EFI System
/dev/sda2 618496 1953520064 1952901569 931.2G Linux filesystem
Disk /dev/nvme0n1: 953.87 GiB, 1024209543168 bytes, 2000409264 sectors
Disk model: Sabrent
Disklabel type: gpt
Disk identifier: 1812AB88-983C-48EE-9030-C07162AFA8EF
/dev/nvme0n1p1 2048 1333247 1331200 650M EFI System
/dev/nvme0n1p2 1333248 1595391 262144 128M Microsoft reserved
/dev/nvme0n1p3 1595392 1966018559 1964423168 936.7G Microsoft basic data
/dev/nvme0n1p4 1966018560 1968046079 2027520 990M Windows recovery environment
/dev/nvme0n1p5 1968046080 1998034943 29988864 14.3G Windows recovery environment
/dev/nvme0n1p6 1998034944 2000408575 2373632 1.1G Windows recovery environment
Disk /dev/sdb: 14.94 GiB, 16039018496 bytes, 31326208 sectors
Disk model: USB DISK 2.0
Disklabel type: dos
Disk identifier: 0x00000000
Device Boot Start End Sectors Size Id Type
/dev/sdb1 * 64 5122467 5122404 2.4G 0 Empty
/dev/sdb2 5122468 5130659 8192 4M ef EFI (FAT-12/16/32)
Disk /dev/loop0: 18.94 MiB, 19857408 bytes, 38784 sectors
Disk /dev/loop1: 430 MiB, 450883584 bytes, 880632 sectors
Disk /dev/loop2: 1.25 GiB, 1337995264 bytes, 2613272 sectors
Disk /dev/loop3: 680.74 MiB, 713805824 bytes, 1394152 sectors
Disk /dev/zram0: 31.21 GiB, 33516683264 bytes, 8182784 sectors
Units: sectors of 1 * 4096 = 4096 bytes
Sector size (logical/physical): 4096 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
So i ran all those commands and got no errors, but when i boot i dont have get give an option to choose the OS to boot from. I would sent a picture but it won’t let me because im a new user.
Enter in a terminal efibootmgr and provide the output, to see what you’re booting by default.
It could be that everything was/is in /dev/nvme0n1p1, which is an EFI System Partition as well.
So you could try to switch to that, or repeat the procedure with /dev/nvme0n1p1 instead of /dev/sda1.
The strange thing for me is that 0000 is missing in the BootOrder.
Can you check if you can boot Windows using the Function Key for your boot loader selection (e.g. F12)?
If you can boot Windows, disable the “fast startup” feature in Windows. What Is “Fast Startup” Mode and How to Enable or Disable It? - MiniTool, login back to Garuda and try again:
sudo update-grub
Also make sure (but this should be the default) that you see GRUB_DISABLE_OS_PROBER=false (uncommented) in /etc/default/grub
Ok, I did that and still not luck. Here is the output of running update-grub if it helps
Found theme: /usr/share/grub/themes/garuda-dr460nized/theme.txt
grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
Adding boot menu entry for UEFI Firmware Settings ...
Detecting snapshots ...
Found snapshot: 2024-06-06 10:04:17 | @/.snapshots/247/snapshot | pre | pacman -Su |
Found snapshot: 2024-04-22 09:38:16 | @/.snapshots/246/snapshot | post | aalib accountsservice alsa-card-profiles attica baloo beautyline bind bi |
Found snapshot: 2024-04-22 09:31:02 | @/.snapshots/245/snapshot | pre | pacman -Su |
Found snapshot: 2024-04-13 11:31:02 | @/.snapshots/244/snapshot | post | alsa-card-profiles ark aspnet-runtime-6.0 aspnet-runtime-7.0 baloo-widge |
Found snapshot: 2024-04-13 11:27:00 | @/.snapshots/243/snapshot | pre | pacman -Su --config /tmp/tmp.EQ9gQtAm4g |
Found snapshot: 2024-04-11 21:42:30 | @/.snapshots/242/snapshot | pre | pacman -Su |
Found snapshot: 2024-04-03 11:49:57 | @/.snapshots/241/snapshot | pre | pacman -S scanner-support printer-support --needed |
Found snapshot: 2024-04-01 20:28:23 | @/.snapshots/238/snapshot | post | nmap |
Found snapshot: 2024-04-01 20:28:21 | @/.snapshots/237/snapshot | pre | pacman -S --config /etc/pacman.conf -- extra/nmap |
Found snapshot: 2024-03-30 21:18:47 | @/.snapshots/236/snapshot | post | postman-bin |
Found snapshot: 2024-03-30 21:18:38 | @/.snapshots/235/snapshot | pre | pacman -S --config /etc/pacman.conf -- chaotic-aur/postman-bin |
Found 11 snapshot(s)
Unmount /tmp/grub-btrfs.dG3usCpxVm .. Success
done
Just in case… I edited my post above when you maybe already started working…
Have you been able to boot Windows with the Function Key for boot order selection (at least this would be a workaround) and remove “fast startup”?
Pretty much the exact same output , I did change the boot order to start with 0000 tho. Is it possible to reinstall and not lose my files and settings?
No, you have to backup your home folder from the live USB.
But hold on a little bit more.
There might be something stupid i’m missing.
I’ve stopped dual booting since quite some time now.
Maybe someone else will jump in with other suggestions.
A good place to start is to try successfully completing the upgrade. Set up a chroot again from the live environment.
garuda-chroot -a
Then try running an update.
garuda-update
Paste the output into the thread if it fails or there are any errors so we can see what is happening. If the update succeeds, exit the chroot and see if you are able to boot back into the installation again.
╭─garuda@garuda in ~ as 🧙 took 81ms
[🔍] × sudo garuda-chroot -a /mnt/broken/@/
==> ERROR: No Linux partitions detected!
╭─garuda@garuda in ~ as 🧙 took 4s
[⚡] × sudo garuda-chroot /mnt/broken/@/
sh-5.2# garuda-chroot -a
sh: garuda-chroot: command not found
sh-5.2# garuda-update
error: failed to synchronize all databases (unable to lock database)
spawn pacman -Su -yy
sh-5.2#
Some of those errors are normal when you are running an update inside the chroot.
Did you chmod 777 anything while you were troubleshooting? That is almost always a dangerous move, because it can be difficult or impossible to undo.
Anyway, before getting out of the chroot try reinstalling the kernel. That will ensure you have a good kernel and will regenerate the initramfs as well.
