i need help in changing keyboard input, rts telugu option is not available in language settings, i am used to rts (reverse translation), a tutorial on youtube is having that option but my system is not showing it, can anyone help me getting that keyboard setting??
Maybe.
Can you add your garuda-inxi and post the link to YT?
I personally did not understand the rts telugo part, GNOME specific?
Describe your issue in detail. The more we know, the better we can help
Show us the results of your searches, and what you’ve tried
After rebooting, post the FULL output of
garuda-inxiin the body of the post (not linked externally, or collapsed with the “hide details” feature)Format terminal output (including your
garuda-inxi) as a code block by clicking the preformatted text button (</>) , or put three tildes (~) above and below the text
Kernel: 6.13.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=5ade1dc0-42f5-442c-a411-eead4b8c6958 rw rootflags=subvol=@
Desktop: GNOME v: 47.4 tk: GTK v: 3.24.48 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Garuda base: Arch Linux
Type: Laptop System: LENOVO product: 82NC v: YG Slim 7 Pro 14IHU5
serial: <superuser required> Chassis: type: 10 v: YG Slim 7 Pro 14IHU5
Mobo: LENOVO model: VIUU4 v: SDK0K17763 WIN serial: <superuser required>
part-nu: LENOVO_MT_82NC_BU_idea_FM_ uuid: <superuser required> UEFI: LENOVO
v: FJCN75WW date: 03/17/2023
ID-1: BAT1 charge: 43.9 Wh (84.4%) condition: 52.0/61.0 Wh (85.2%)
power: 10.1 W volts: 16.4 min: 15.4 model: Celxpert L19C4PH3 type: Li-poly
Info: model: 11th Gen Intel Core i5-11320H bits: 64 type: MT MCP
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 2
microcode: 0x38
smt: enabled cache: L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB
desc: 4x1.2 MiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1079 min/max: 400/4500 scaling: driver: intel_pstate
governor: powersave cores: 1: 1079 2: 1079 3: 1079 4: 1079 5: 1079 6: 1079
7: 1079 8: 1079 bogomips: 50995
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
built: 2020-21 ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4
bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: IMC Networks Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 13d3:5419
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: eDP-1 model-id: CSO 0x140c built: 2021 res: 2880x1800 dpi: 242
gamma: 1.2 size: 302x188mm (11.89x7.4") diag: 356mm (14") ratio: 16:10
modes: 2880x1800
API: Vulkan v: 1.4.304 layers: 4 device: 0 type: integrated-gpu name: Intel
Iris Xe Graphics (TGL GT2) driver: N/A device-ID: 8086:9a49
Info: Tools: api: vulkaninfo x11: xdpyinfo, xprop, xrandr
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo
snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:a0c8 class-ID: 0401
API: ALSA v: k6.13.5-zen1-1-zen status: kernel-api tools: N/A
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8087:0026
Local Storage: total: 937.14 GiB used: 333.03 GiB (35.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFS512GDE9X084N
lanes: 4 tech: SSD serial: <filter> fw-rev: 41010C22 temp: 44.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: USB 3.2Gen1
size: 460.2 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 1.00 scheme: MBR
used: 48.33 GiB (10.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.4 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 45.0 C mobo: N/A
Memory: total: 16 GiB note: est. available: 15.4 GiB used: 6.7 GiB (43.5%)
Processes: 321 Power: uptime: 22m states: freeze,mem,disk suspend: s2idle
suspend, test_resume image: 6.15 GiB services: gsd-power,
Packages: pm: pacman pkgs: 1276 libs: 429 tools: paru Compilers:
gcc: 14.2.1 Shell: garuda-inxi default: fish v: 4.0.0
running-in: gnome-terminal inxi: 3.3.37
System install date: 2025-03-03
Last full system update: 2025-03-03
i need to change the keyboard input method,
settings> keyboard> input sources, search for telugu, there must be another input method that is missing, like telugu sarala, there must be telugu itrans, i need itrans
locale
Edit the file /etc/locale.gen
for example to add hungarian erase the # to
#hu_HU.UTF-8 UTF-8
#hu_HU ISO-8859-2
then run as root
sudo locale-gen
restart your system
i am new to this, can you please explain in detail
It is explained in detail, you can also read the Arch Wiki.
yes, but which is for telugu?
IDK,
#kok_IN UTF-8
#ks_IN UTF-8
#ks_IN@devanagari UTF-8
I never need it ![]()
If there are no more options to load extra languages you must use Ubuntu ![]()
is there no otherway??
Just wait for answers from Indian people, please.
this one
# te_IN UTF-8
Hello Krishna_Chaitanya,
its not on Kde Settings like you trying but your video was good to test myself to get run.
Terminal :
- Open the Terminal and install IBUS like on those video.
sudo pacman -S ibus ibus-db ibus-lib git clone https://aur.archlinux.org/ibus-m17n.gitcd ibus-m17n/makepkg -i
I have the problem now i got it in on test iso and want reproduce on the official version but stucks actually !!! If i found out what did the change or maybe a other coder can help more out with a hint will be good.
trying @SGS sudo locale-gen
changing like @Valiant_AJ sayed and return it.(savings)
rebooted few times
had a update also between.
changed between x11 and wayland does no differences.
pic:
also i read some arch stuff too and wiki for it too.
managed to open ibus but there is an error popping up in command line when i add a language, maybe it is not running properly
also, ibus-db and ibus-lib are unable to install
warning: ibus-1.5.31-2 is up to date -- reinstalling
error: target not found: ibus-db
error: target not found: ibus-lib
(ibus-setup:8613): dconf-WARNING **: 07:42:55.346: failed to commit changes to dconf: Error spawning command line “dbus-launch --autolaunch=71c9a79afca948e6bcbcbcb018e85e47 --binary-syntax --close-stderr”: Child process exited with code 1
(ibus-setup-m17n:8863): dconf-WARNING **: 07:43:21.909: failed to commit changes to dconf: Error spawning command line “dbus-launch --autolaunch=71c9a79afca948e6bcbcbcb018e85e47 --binary-syntax --close-stderr”: Child process exited with code 1
(ibus-setup-m17n:8863): dconf-WARNING **: 07:43:21.910: failed to commit changes to dconf: Error spawning command line “dbus-launch --autolaunch=71c9a79afca948e6bcbcbcb018e85e47 --binary-syntax --close-stderr”: Child process exited with code 1
(ibus-setup:8613): dconf-WARNING **: 07:43:32.625: failed to commit changes to dconf: Error spawning command line “dbus-launch --autolaunch=71c9a79afca948e6bcbcbcb018e85e47 --binary-syntax --close-stderr”: Child process exited with code 1
Remove the # from te_IN UTF-8 in /etc/locale.gen and execute locale-gen as sudo in one line in terminal with
sudo sed -i 's/#te_IN UTF-8/te_IN UTF-8/g' /etc/locale.gen && sudo locale-gen
copy and paste, Enter, after that restart your system.
yeah, done it, didnt work
it said generation complete and i restarted the system yesterday night itself, but didnt work, the error i showed you is after doing it
These packages probably exist only in Ubuntu.
Only the ibus package exists in Arch.
Please check if this Arch Wiki article helps. It describes also some configurations required, but you will have to try them in your system.
e.g.:
Some non-Latin languages (e.g. Simplified Chinese) need to enable the Show Extended Input Sources option in GNOME Tweaks
