My Wallpaper is Gone after attempting to fix a crash loop I had with plasma
Hey All!
I’ve been using Garuda Mokka for a few days now, and it’s largely been great.
However this morning before work I turned on my PC and discovered that my desktop was blank. The applications I had open before I turned my PC reopened themselves (Firefox, Steam, Discord), but all of the UI and my wallpapers vanished. Additionally, I have no sound.
This is bizarre to me, as I as far as I know haven’t done anything to cause this (I’m sure I have but do I know what did it…no). As far as I can tell, all I’ve done is use Steam, Discord, Firefox, and garuda-update to do normal computer stuff. No tricky maneuvers, no wild out there packages.
Flash forward to now after work, I boot into my PC again and I get a helpful little pop up window:
plasmashell — Crash Handler
Gathering crash information failed for unknown reasons. You can retry, close the window, or view detailed output.
Automatic Report [Restart plasmashell]
Collecting crash data. The collected data will automatically be submitted in the background.
And so I think “oh good, at least I have something to google now.”
Of course, what I turn up has not been too helpful (At least, not to me…I’m sure it helps someone but I’m a fool).
What I have read thus-far:
This madlad whose KDE install was done by hand and who was not using garuda-update
(As I write these, I discover that among other things the clipboard isn’t working so I have to copy all this data by hand…yay)
So then I read this post and decided to give the solution in it a try.
And sure enough, Plasma has appeared to stopped crashing and “works” now after deleting the file ~/.config/plasmashellrc.
Which is great! Except my wallpaper has vanished.
If I view the Desktop and Wallpaper Settings, I can see that they are still what they should be.
But all I’ve got are flat black backgrounds (which, if this were a work computer would be fine. It isn’t :slightly_smiling_face:).
So I put it to you, wizards of the internet!
Where has my wallpaper gone, and how do I conjure it back?
(Oh, and because y’all want it):
Kernel: 6.15.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=56e860a8-7ca9-4ddf-956b-495ba0def4bd rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.4.2 tk: Qt v: N/A info: frameworks v: 6.15.0
Type: Desktop System: Micro-Star product: MS-7B86 v: 5.0
Mobo: Micro-Star model: B550 GAMING GEN3 (MS-7B86) v: 5.0
Megatrends LLC. v: P.90 date: 03/26/2025
Info: model: AMD Ryzen 7 5700X3D bits: 64 type: MT MCP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 2 microcode: 0xA201213
desc: 8x512 KiB L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 3691 min/max: 575/4151 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3691 2: 3691 3: 3691
4: 3691 5: 3691 6: 3691 7: 3691 8: 3691 9: 3691 10: 3691 11: 3691 12: 3691
13: 3691 14: 3691 15: 3691 16: 3691 bogomips: 96001
Device-1: NVIDIA TU102 [GeForce RTX 2080 Ti Rev. A] vendor: Micro-Star MSI
driver: nvidia v: 575.64.03 alternate: nouveau,nvidia_drm
arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie:
gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16 ports: active: none
off: DP-2,DP-3,HDMI-A-1 empty: DP-1,Unknown-2 bus-ID: 2b:00.0
chip-ID: 10de:1e07 class-ID: 0300
Device-2: webcamvendor NexiGo N60 FHD Webcam Audio
driver: snd-usb-audio,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 1-1:2 chip-ID: 3443:60bb class-ID: 0102 serial: <filter>
gpu: nvidia,nvidia-nvswitch d-rect: 7680x4320 display-ID: 0
Monitor-1: DP-2 pos: top-right model: Dell P2414H serial: <filter>
built: 2014 res: mode: 1920x1080 hz: 60 scale: 178% (1.78) to: 1080x1920
dpi: 93 gamma: 1.2 size: 527x297mm (20.75x11.69") diag: 605mm (23.8")
Monitor-2: DP-3 pos: middle-c model: YMG-4K32-01 serial: <filter>
built: 2021 res: mode: 3840x2160 hz: 60 scale: 145% (1.45) to: 2648x1490
dpi: 139 gamma: 1.2 size: 700x390mm (27.56x15.35") diag: 801mm (31.5")
ratio: 16:9 modes: max: 3840x2160 min: 640x480
Monitor-3: HDMI-A-1 pos: bottom-l model: Dell U2713HM serial: <filter>
built: 2014 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 82 gamma: 1.2
max: 1920x1080 min: 640x480
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 575.64.03
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2080 Ti/PCIe/SSE2
memory: 10.74 GiB display-ID: :1.0
API: Vulkan v: 1.4.313 layers: 11 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 2080 Ti driver: nvidia v: 575.64.03 device-ID: 10de:1e07
surfaces: N/A device: 1 type: cpu name: llvmpipe (LLVM 20.1.7 256 bits)
driver: mesa llvmpipe v: 25.1.5-arch1.1 (LLVM 20.1.7)
Device-1: NVIDIA TU102 High Definition Audio vendor: Micro-Star MSI
link-max: lanes: 16 bus-ID: 2b:00.1 chip-ID: 10de:10f7 class-ID: 0403
speed: 16 GT/s lanes: 16 bus-ID: 2d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: webcamvendor NexiGo N60 FHD Webcam Audio
Device-4: Medeli WMT800 Microphone
lanes: 1 mode: 1.1 bus-ID: 5-2:3 chip-ID: 0a67:d061 class-ID: 0300
API: ALSA v: k6.15.5-zen1-1-zen status: kernel-api with: aoss
IF: enp42s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 1.86 TiB used: 82.94 GiB (4.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Silicon Power
model: SPCC M.2 PCIe SSD size: 1.86 TiB block-size: physical: 512 B
fw-rev: SN26904 temp: 37.9 C scheme: GPT
ID-1: / raw-size: 635.81 GiB size: 635.81 GiB (100.00%)
used: 82.94 GiB (13.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 635.81 GiB size: 635.81 GiB (100.00%)
ID-4: /var/log raw-size: 635.81 GiB size: 635.81 GiB (100.00%)
ID-5: /var/tmp raw-size: 635.81 GiB size: 635.81 GiB (100.00%)
System Temperatures: cpu: 43.1 C mobo: N/A
Memory: total: 32 GiB available: 31.26 GiB used: 4.51 GiB (14.4%)
Processes: 364 Power: uptime: 7m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.45 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2101 libs: 523 tools: octopi,paru Compilers:
clang: 20.1.7 gcc: 15.1.1 Shell: garuda-inxi default: fish v: 4.0.2
Garuda (2.7.3-1):
System install date:     2025-07-02
Last full system update: 2025-07-07
Thanks for your time and attention!
EDIT:
Noticing that at in my top icons bar it has what appears to be a rectangle containing a square and circle with a question mark.
Clicking it brings up a window called “Plasma Renderer.”
It lists:
Rendering Backend as “Software”
Render Loop as “Automatic”
GL Core Profile has a box labeled “Force” that is disabled.
Maybe, check system setting wallpaper
change background type to picture and set again your wallpaper.
Okay.
It looks as though changing the Wallpaper Type from Active-Blur to Image allowed me to set each of the images back again.
So wallpaper is back. Yay!
Thankies!~
Set the rendering backend to “Automatic”. These are the correct settings:
Take a look at this topic:
I’m so glad to see that the background image previews with Active blur selected for Wallpaper type is also all white boxes instead of the preview of the actual image for you as well, because I thought I was going crazy and figured I’d just live with it. Any ideas why this happened? If I switch Wallpaper type to Image all the background image previews load just fine, but not when Active Blur is selected. I have similar screenshots posted in another topic here: KDE Active Blur wallpaper plugin appers broken, black desktop background - though I fixed the issue I was experiencing on that post.
