Hi everyone from Turkey. I’ve been using Garuda Linux KDE for about a year now and I really like it. I even prepared a review article about Garuda KDE and published it on donanimhaber.com, a very popular and large forum site in my country.
The link to the article is at Garuda Linux Kurulum Ve İncelemesi | DonanımHaber Forum
I bought myself a new notebook about 6 months ago. MSI Stealth 17M. This notebook is elegant and has a very powerful processor and graphics card. I installed the Garuda KDE distribution as soon as I received my device. Apparently it was working fine. However, after I started using my device, from time to time when I wanted to turn it off, the device would crash. Meanwhile, the small light on the CapsLock key was constantly blinking. I also had to press the power button for a long time to turn off my computer.
After using this method a few times to shut down my computer, when I turned it back on I noticed that the audio hardware was not working. First, I tried to reinstall the operating system to solve this problem, but it did not work. Then I went to the MSI official website and downloaded the BIOS upgrade file for my device, and when I applied the BIOS upgrade on my device, the audio hardware started working again.
However, as I continued to use my device, the same error repeated itself many times, and I continued to solve the problem by applying BIOS updates each time. Finally, the last time I had this audio hardware not working issue, I resorted to applying a BIOS update again. This time the BIOS update was interrupted before it could complete and my device refused to turn on again. It was not possible to enter the BIOS settings. Then I took my device to the technical service and they disassembled the computer there; They found the BIOS integrated circuit and rewrote the BIOS using the necessary equipment.
I placed an applications menu and a SHUTDOWN or SWITCH applet in the iconic task manager at the bottom of the desktop. I removed the App Launcher from the top panel and replaced it with an App Menu. If I tried to shut down or restart my computer using these items or the command line, this error would appear from time to time. There may be a relationship between the emergence of these errors and the fact that I put extra Application Menu and SHUTDOWN or SWITCH applets on the panels. Because I started experiencing almost all of the problems after making these adjustments. But it could also be a coincidence.
Although I have installed LTS next to it from time to time, I generally use the Linux Zen kernel. I keep my operating system up to date.
When Garuda started using Wayland, I had some problems shutting down or logging out. Also, VokoScreen screen recording program does not work with Wayland. That’s why I continue to stay on X11.
I have never used an operating system other than Garuda KDE on my device.
I would appreciate any information regarding this issue and am open to suggestions. I really like Garuda Linux KDE and want to continue using it. I’ll be happy if you can help me.
I wrote this text in my own language and translated it with Google Translate. There may have been some glitches in the translation. Thank you very much.
Operating System: Garuda Linux
KDE Plasma Version: 6.0.4
KDE Frameworks Version: 6.2.0
Qt Version: 6.7.0
Kernel Version: 6.8.9-zen1-2-zen (64-bit)
Graphics Platform: X11
Processors: 20 × 12th Gen Intel® Core™ i7-1280P
Memory: 15.3 GiB of RAM
Graphics Processor: Mesa Intel® Graphics
Manufacturer: Micro-Star International Co., Ltd.
Product Name: Stealth 17M A12UE
System Version: REV:1.0
Edit: I did’t know about garuda-inxi sorry. Here is:
Kernel: 6.8.9-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=e6639c04-e04f-4f0b-bc16-1233722763e4 rw rootflags=subvol=@
quiet resume=UUID=94adc4e7-21df-4d37-a002-4b1d6afc414f loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Laptop System: Micro-Star product: Stealth 17M A12UE v: REV:1.0
Mobo: Micro-Star model: MS-17R1 v: REV:1.0 serial: <superuser required>
part-nu: 17R1.1 uuid: <superuser required> UEFI: American Megatrends LLC.
v: E17R1IMS.10F date: 01/17/2024
ID-1: BAT1 charge: 47.6 Wh (88.0%) condition: 54.1/63.2 Wh (85.5%)
volts: 15.5 min: 15.2 model: MSI BIF0_9 type: Li-ion serial: N/A
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
Info: model: 12th Gen Intel Core i7-1280P bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
microcode: 0x432
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 426 high: 500 min/max: 400/4700:4800:3600 scaling:
driver: intel_pstate governor: powersave cores: 1: 468 2: 400 3: 481 4: 400
5: 494 6: 493 7: 400 8: 400 9: 487 10: 400 11: 500 12: 400 13: 400 14: 400
15: 400 16: 400 17: 400 18: 400 19: 400 20: 400 bogomips: 79872
Device-1: Intel Alder Lake-P GT2 [Iris Xe Graphics] vendor: Micro-Star MSI
driver: i915 v: kernel alternate: xe arch: Gen-12.2 process: Intel 10nm
built: 2021-22+ ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:46a6 class-ID: 0300
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q]
vendor: Micro-Star MSI driver: nvidia v: 550.78
alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of
2024-04; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-2023 pcie: gen: 4 speed: 16 GT/s lanes: 4 link-max: lanes: 16
ports: active: none empty: DP-1 bus-ID: 01:00.0 chip-ID: 10de:2520
Device-3: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 5986:2149
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 23.2.6
Monitor-1: eDP-1 model: BOE Display 0x09a4 built: 2020 res: 1920x1080
hz: 144 dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46")
diag: 438mm (17.3") ratio: 16:9 modes: 1920x1080
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.0.7-arch1.3
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
device-ID: 8086:46a6 memory: 14.97 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 4 device: 0 type: integrated-gpu name: Intel
Graphics (ADL GT2) driver: mesa intel v: 24.0.7-arch1.3
device-ID: 8086:46a6 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 Laptop GPU driver: nvidia v: 550.78
device-ID: 10de:2520 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.7-arch1.3 (LLVM
vendor: Micro-Star MSI driver: sof-audio-pci-intel-tgl
chip-ID: 8086:51c8 class-ID: 0401
Device-2: NVIDIA GA106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 4
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
API: ALSA v: k6.8.9-zen1-2-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.6 status: active with: 1: pipewire-pulse
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4 chip-ID: 8087:0026
Local Storage: total: 1.82 TiB used: 308.08 GiB (16.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SFYRD2000G
lanes: 4 tech: SSD serial: <filter> fw-rev: EIFK31.6 temp: 31.9 C
ID-1: / raw-size: 100.59 GiB size: 100.59 GiB (100.00%) used: 7.2 GiB (7.2%)
used: 584 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 1.03 TiB size: 1.03 TiB (100.00%)
used: 3.79 GiB (0.4%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-4: /var/log raw-size: 100.59 GiB size: 100.59 GiB (100.00%)
used: 7.2 GiB (7.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-5: /var/tmp raw-size: 100.59 GiB size: 100.59 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.06 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p4 maj-min: 259:4
ID-2: swap-2 type: zram size: 15.33 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 20 dev: /dev/zram0
System Temperatures: cpu: 42.0 C mobo: N/A
Memory: total: 16 GiB note: est. available: 15.33 GiB used: 5.68 GiB (37.0%)
Processes: 417 Power: uptime: 2h 59m states: freeze,mem,disk
suspend: s2idle avail: deep wakeups: 0 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 6.09 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1438 libs: 426 tools: octopi,pamac,paru
Compilers: gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date: 2024-05-14
Last full system update: 2024-05-18 ↻
