Nope, only pcie_aspm=off.
Garuda's PrivateBin
Visit this link to see the note. Giving the URL to anyone allows them to access the note, too.
I rebooted my laptop and opened normally. But the issue happens from time to time. I hope the solution you gave me will work. If I experience the same problem again, I will post here. Thank you guys, very kind of you.
And Garuda, which is my power animal is the best. ![]()
Hi again. My laptop crashed again when i tried to shut down it last night. It seems the solution doesn’t work. Are there any other things you can recommend?
Any chance you have RAID enabled in your BIOS ?
I’ll summarize it roughly:
The problem has existed since the beginning, it was and is only installed with garuda-dragonized and it happens with lts/zen-kernel. The system freezes during shutdown/reboot, also via terminal command.
The 1st log is from a freeze when the power supply was connected and does not contain any useful information.
The 2nd log is full of pcieport/nvme errors and is otherwise useless.
The 3rd log is just a kernel log without errors and therefore useless.
The 4th log is just a kernel log without errors and therefore useless.
Kernel logs are not helpful in the event of a kernel panic, as it is not possible to see what generally happened before and so no potential pattern can be identified. It is also impossible to determine what happens after the shutdown is triggered.
@alaz Try disabling all power saving options in the BIOS and in the KDE Plasma system settings.
If present in BIOS: disable “USB Power Share” to. Before every shutdown, try removing all USB devices, including the Logitech mouse receiver.
After the next freeze post the output again:
journalctl -b -1 --no-pager
Can you reproduce the freezes in live sessions?
@LolFlasherNoobX FakeRAID is disabled - that’s what it says in the garuda-inxi btw ![]()
It happens with both kernels zen and lts. I checked out “USB Power Share” thing in BIOS settings and found a similar one, “Enable/Disable the power support during Hibernation and Shutdown for USB Type-A port” , and disabled it. And i’ll remove my mouse from now on.
@LolFlasherNoobXFakeRAID is disabled - that’s what it says in thegaruda-inxibtw
Sorry my English not yet, I don’t understand what you mean.
Sorry, I couldn’t find a RAID setting in the BIOS.
Hi. It just freezed again and i restart my laptop and run journalctl command.
Here is output:
Thanks.
It freezes shortly after the shutdown is triggered:
May 29 13:43:29 ilker-garuda systemd[1050]: Created slice Slice /app/dbus-:1.2-org.kde.Shutdown.
May 29 13:43:29 ilker-garuda systemd[1050]: Started dbus-:1.2-org.kde.Shutdown@0.service.
May 29 13:43:29 ilker-garuda kded6[1152]: Service ":1.45" unregistered
May 29 13:43:29 ilker-garuda polkitd[859]: Unregistered Authentication Agent for unix-session:1 (system bus name :1.33, object path /org/kde/PolicyKit1/AuthenticationAgent, locale tr_TR.UTF-8) (disconnected from bus)
May 29 13:43:29 ilker-garuda kded6[1152]: Service ":1.46" unregistered
May 29 13:43:29 ilker-garuda kded6[1152]: Service ":1.51" unregistered
May 29 13:43:29 ilker-garuda plasmashell[1206]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:136: TypeError: Cannot read property 'screenGeometry' of null
May 29 13:43:29 ilker-garuda plasmashell[1206]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:250: TypeError: Cannot read property 'plasmoid' of undefined
May 29 13:43:29 ilker-garuda systemd[1050]: Stopped target plasma-workspace-x11.target.
May 29 13:43:29 ilker-garuda systemd[1050]: Stopped target KDE Plasma Workspace.
May 29 13:43:29 ilker-garuda systemd[1050]: Stopped target Startup of XDG autostart applications.
May 29 13:43:29 ilker-garuda systemd[1050]: Stopping Geoclue Demo agent...
May 29 13:43:29 ilker-garuda systemd[1050]: Stopping Accessibility...
May 29 13:43:29 ilker-garuda systemd[1050]: Stopping Accessibility services bus...
May 29 13:43:29 ilker-garuda dbus-broker[1194]: Dispatched 1843 messages @ 2(±5)μs / message.
May 29 13:43:29 ilker-garuda systemd[1050]: Stopping Actions gestures on your touchpad using libinput...
May 29 13:43:29 ilker-garuda systemd[1050]: Stopping KDE Global Shortcuts Server...
May 29 13:43:29 ilker-garuda systemd[1050]: Stopping KScreen...
May 29 13:43:29 ilker-garuda systemd[1050]: Stopping KDE Window Manager...
May 29 13:43:29 ilker-garuda systemd[1050]: Stopping Powerdevil...
May 29 13:43:29 ilker-garuda systemd[1050]: Stopping Xdg Desktop Portal For KDE...
May 29 13:43:29 ilker-garuda systemd[1050]: Stopping Portal service...
May 29 13:43:29 ilker-garuda systemd[1050]: Stopping flatpak document portal service...
May 29 13:43:29 ilker-garuda systemd[1050]: Stopping sandboxed app permission store...
May 29 13:43:29 ilker-garuda systemd[1050]: Stopping Baloo File Indexer Daemon...
May 29 13:43:29 ilker-garuda systemd[1]: run-user-1000-doc.mount: Deactivated successfully.
May 29 13:43:29 ilker-garuda systemd[1050]: Stopped KDE Global Shortcuts Server.
May 29 13:43:29 ilker-garuda systemd[1050]: Stopped Baloo File Indexer Daemon.
May 29 13:43:29 ilker-garuda systemd[1050]: Stopped Portal service.
May 29 13:43:29 ilker-garuda systemd[1050]: Stopped flatpak document portal service.
May 29 13:43:29 ilker-garuda systemd[1050]: Stopped sandboxed app permission store.
May 29 13:43:29 ilker-garuda systemd[1050]: Stopped Accessibility services bus.
May 29 13:43:29 ilker-garuda systemd[1050]: Stopped KScreen.
May 29 13:43:29 ilker-garuda systemd[1050]: Stopped Powerdevil.
May 29 13:43:29 ilker-garuda systemd[1050]: Stopped Xdg Desktop Portal For KDE.
May 29 13:43:29 ilker-garuda systemd[1050]: Stopped Geoclue Demo agent.
May 29 13:43:29 ilker-garuda systemd[1050]: Stopped Accessibility.
May 29 13:43:29 ilker-garuda systemd-logind[861]: The system will power off now!
May 29 13:43:29 ilker-garuda systemd-logind[861]: System is powering down.
After that, everything is missing, including stopping the session and the remaining KDE services.
Since you also had a freeze when you connected the power supply, I suspect at the moment that it is a KDE issue (someone here recently had a freeze when connecting the power supply).
Have you tested this:
I’m not sure what is it’s mean. I don’t use live sessions because Garuda KDE already installed.
Should I use Wayland instead of X11? Does this make a difference?
Just try both, live ISO and Wayland, we can’t do it for you ![]()
You should boot a garuda-live.iso and shut it down again, boot it and shut it down again, etc. - to test whether freezes occur during shutdown.
I just did a live logout or reboot 3 times. The 3rd time I tried unplugging the power cord and turning it off after a few seconds and it froze. I turned on my laptop and run journalctl but there was no info.
I tried turning it off with Wayland two times. The second time, when I plugged in the power cord and tried to turn it off, it froze again.
Edit: The audio hardware is not working now. ![]()
The freeze happens at exactly the same point.
It’s interesting that it also happens during a live session. It’s also interesting that somehow the connection or disconnection of the power supply always seems to play a role - regardless of whether it freezes immediately when you connect it or afterwards when you shut it down.
To narrow this down further, try to avoid connecting and disconnecting the power supply while it’s running - so only connect and disconnect the power supply when the laptop is turned off (you don’t need to test live sessions anymore, just your installed garuda).
Yesterday i upgraded BIOS and the audio hardware came back. I removed the battery from my laptop and tested performance, balance and power save modes and also tested shutdown and reboot about 15 20 times. No freezes until now. But the keyboard’s backlights were stuck at the “highest” level. I don’t know if this is related to the BIOS update or me removing the battery.
I am also facing this issue. It USUALLY happens when I shutdown my computer after using it for a few hours. I have tried running the system on integrated graphics and on Nvidia, and different kernels (linux-lts, linux-zen, linux-amd-znver3).
The system also froze ONE TIME when I close a tab in brave and ONE time when I closed dolphin.
JournalCTL
Jun 01 14:58:10 rogue krunner[300180]: steam.sh[300180]: Restarting Steam by request...
Jun 01 14:58:10 rogue krunner[300180]: steam.sh[300180]: Running Steam on garuda Soaring 64-bit
Jun 01 14:58:10 rogue krunner[300180]: steam.sh[300180]: STEAM_RUNTIME has been set by the user to: /home/aurora/.local/share/Steam/ubuntu12_32/steam-runtime
Jun 01 14:58:10 rogue krunner[307705]: setup.sh[307705]: Steam runtime environment up-to-date!
Jun 01 14:58:10 rogue krunner[300180]: steam.sh[300180]: Steam client's requirements are satisfied
Jun 01 14:58:10 rogue krunner[307762]: 06/01 14:58:10 minidumps folder is set to /tmp/dumps
Jun 01 14:58:10 rogue krunner[307762]: 06/01 14:58:10 Init: Installing breakpad exception handler for appid(steam)/version(1716584667)/tid(307762)
Jun 01 14:58:14 rogue xdg-desktop-portal-kde[5625]: xdp-kde-settings: Namespace "org.gnome.desktop.interface" is not supported
Jun 01 14:58:14 rogue krunner[307807]: steamwebhelper.sh[307798]: === Sat Jun 1 02:58:14 PM IST 2024 ===
Jun 01 14:58:14 rogue krunner[307810]: steamwebhelper.sh[307798]: Starting steamwebhelper under bootstrap sniper steam runtime at /home/aurora/.local/share/Steam/ubuntu12_64/steam-runtime->
Jun 01 14:58:14 rogue krunner[307762]: [2024-06-01 14:58:10] Startup - updater built May 24 2024 20:46:19
Jun 01 14:58:14 rogue krunner[307762]: [2024-06-01 14:58:10] Startup - Steam Client launched with: '/home/aurora/.local/share/Steam/ubuntu12_32/steam'
Jun 01 14:58:14 rogue krunner[307762]: [2024-06-01 14:58:10] Loading cached metrics from disk (/home/aurora/.local/share/Steam/package/steam_client_metrics.bin)
Jun 01 14:58:14 rogue krunner[307762]: [2024-06-01 14:58:10] Using the following download hosts for Public, Realm steamglobal
Jun 01 14:58:14 rogue krunner[307762]: [2024-06-01 14:58:10] 1. https://client-update.akamai.steamstatic.com, /, Realm 'steamglobal', weight was 1000, source = 'update_hosts_cached.vdf'
Jun 01 14:58:14 rogue krunner[307762]: [2024-06-01 14:58:10] 2. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 1, source = 'update_hosts_cached.vdf'
Jun 01 14:58:14 rogue krunner[307762]: [2024-06-01 14:58:10] 3. https://cdn.steamstatic.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
Jun 01 14:58:14 rogue krunner[307762]: [2024-06-01 14:58:10] Verifying installation...
Jun 01 14:58:14 rogue krunner[307762]: [2024-06-01 14:58:10] Verification complete
Jun 01 14:58:14 rogue krunner[307762]: UpdateUI: skip show logo
Jun 01 14:58:14 rogue krunner[307762]: Steam logging initialized: directory: /home/aurora/.local/share/Steam/logs
Jun 01 14:58:14 rogue krunner[307762]: XRRGetOutputInfo Workaround: initialized with override: 0 real: 0xdf363dc0
Jun 01 14:58:14 rogue krunner[307762]: XRRGetCrtcInfo Workaround: initialized with override: 0 real: 0xdf362500
Jun 01 14:58:14 rogue krunner[307762]: CAppInfoCacheReadFromDiskThread took 49 milliseconds to initialize
Jun 01 14:58:14 rogue krunner[307762]: Steam Runtime Launch Service: starting steam-runtime-launcher-service
Jun 01 14:58:14 rogue krunner[307762]: Steam Runtime Launch Service: steam-runtime-launcher-service is running pid 307922
Jun 01 14:58:14 rogue steam-runtime-launcher-service[307922]: bus_name=com.steampowered.PressureVessel.LaunchAlongsideSteam
Jun 01 14:58:15 rogue xdg-desktop-portal-kde[5625]: xdp-kde-settings: Namespace "org.gnome.desktop.interface" is not supported
Jun 01 14:58:16 rogue kwin_wayland[5322]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
Jun 01 14:58:17 rogue krunner[307762]: /usr/share/themes/Sweet-Dark/gtk-2.0/main.rc:727: error: unexpected identifier 'direction', expected character '}'
Jun 01 14:58:17 rogue krunner[307762]: /usr/share/themes/Sweet-Dark/gtk-2.0/apps/chrome.rc:50: error: invalid string constant "button", expected valid string constant
Jun 01 14:58:17 rogue krunner[307762]: /usr/share/themes/Sweet-Dark/gtk-2.0/apps/xfce.rc:79: error: invalid string constant "entry", expected valid string constant
Jun 01 14:58:20 rogue kded6[5503]: Registering ":1.206/org/ayatana/NotificationItem/steam" to system tray
Jun 01 14:58:20 rogue krunner[307762]: BRefreshApplicationsInLibrary 1: 1ms
Jun 01 14:58:20 rogue krunner[307762]: BuildCompleteAppOverviewChange: 331 apps
Jun 01 14:58:20 rogue krunner[307762]: RegisterForAppOverview 1: 13ms
Jun 01 14:58:20 rogue krunner[307762]: RegisterForAppOverview 2: 13ms
Jun 01 14:58:20 rogue kwin_wayland[5322]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
Jun 01 14:58:21 rogue kwin_wayland[5322]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
Jun 01 14:58:30 rogue kwin_wayland[5322]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
Jun 01 14:58:34 rogue systemd[4999]: app-mpv-da7111c2183e4602a2040a472c8ddbf0.scope: Consumed 1.544s CPU time.
Jun 01 14:58:34 rogue plasmashell[5544]: kf.coreaddons: Failed to open "/home/aurora/1.pdf" No such file or directory
Jun 01 14:58:34 rogue plasmashell[5544]: kf.coreaddons: Failed to open "/home/aurora/2.pdf" No such file or directory
Jun 01 14:58:34 rogue plasmashell[5544]: kf.coreaddons: Failed to open "/home/aurora/3.pdf" No such file or directory
Jun 01 14:58:34 rogue plasmashell[5544]: kf.coreaddons: Failed to open "/home/aurora/GST_CERTIFICATE.pdf" No such file or directory
Jun 01 14:58:34 rogue plasmashell[5544]: kf.coreaddons: Failed to open "/home/aurora/new.pdf" No such file or directory
Jun 01 14:58:34 rogue plasmashell[5544]: qt.dbus.integration: QDBusConnection: error: could not send message to service "org.freedesktop.portal.Documents" path "/org/freedesktop/portal/doc>
Jun 01 14:58:34 rogue plasmashell[5544]: kf.coreaddons: Some files could not be exported. QDBusError("org.freedesktop.DBus.Error.Failed", "Marshalling failed: Invalid file descriptor pass>
Jun 01 14:58:34 rogue xdg-document-portal[5338]: removing transfer 10941149535270043867 for dead peer :1.175
Jun 01 14:58:34 rogue systemd[4999]: app-org.kde.dolphin-047c0ab699864b92a29838c1c6f8ec40.scope: Consumed 6.386s CPU time.
Jun 01 14:58:35 rogue kwin_wayland[5322]: kwin_core: Failed to focus 0x2c00038 (error 8)
Jun 01 14:58:38 rogue krunner[307762]: [2024-06-01 14:58:36] Shutdown
Jun 01 14:58:38 rogue kded6[5503]: Service ":1.206" unregistered
Jun 01 14:58:39 rogue systemd-logind[938]: Creating /run/nologin, blocking further logins...
Jun 01 14:58:39 rogue systemd-logind[938]: System is powering down.
Jun 01 14:58:39 rogue asusd[921]: INFO: RogPlatform reloading panel_od
-- Boot 949e4b78e09e4f8cae346b41304f05fd --
Jun 01 15:09:29 rogue kernel: Linux version 6.6.32-1-lts (linux-lts@archlinux) (gcc (GCC) 14.1.1 20240522, GNU ld (GNU Binutils) 2.42.0) #1 SMP PREEMPT_DYNAMIC Sat, 25 May 2024 20:20:51 +0>
Jun 01 15:09:29 rogue kernel: Command line: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts root=UUID=a3ed4574-408f-4802-8fc7-dded1b46b1ac rw rootflags=subvol=@ resume=UUID=21ea485a-d6f1-4646-b304-bc>
Jun 01 15:09:29 rogue kernel: BIOS-provided physical RAM map:
System info:
Kernel: 6.6.32-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
resume=UUID=21ea485a-d6f1-4646-b304-bca6967a48e0 loglevel=3
mitigations=off ibt=off
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Laptop System: ASUSTeK product: ROG Strix G713QM_G713QM v: 1.0
Mobo: ASUSTeK model: G713QM v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: G713QM.331
date: 02/24/2023
ID-1: BAT0 charge: 52.4 Wh (61.1%) condition: 85.8/90.0 Wh (95.4%)
volts: 15.7 min: 15.9 model: AS3GWAF3KC GA50358 type: Li-ion
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 2S
microcode: 0xA50000B
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1157 high: 2553 min/max: 400/4463 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1916 2: 400 3: 1987
4: 400 5: 2031 6: 400 7: 1953 8: 400 9: 400 10: 400 11: 400 12: 400
13: 1972 14: 400 15: 2500 16: 2553 bogomips: 102241
link-max: gen: 4 speed: 16 GT/s ports: active: HDMI-A-1 off: eDP-1
empty: none bus-ID: 06:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 48.0 C
Monitor-1: HDMI-A-1 res: 1920x1200 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.8-arch1.1
renoir LLVM 17.0.6 DRM 3.54 6.6.32-1-lts) device-ID: 1002:1638
API: Vulkan v: 1.3.279 layers: 14 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.0.8-arch1.1
device-ID: 1002:1638 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.8-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
Device-1: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.1 chip-ID: 1002:1637
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
API: ALSA v: k6.6.32-1-lts status: kernel-api with: aoss
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:3 chip-ID: 8087:0029
Local Storage: total: 2.77 TiB used: 1.29 TiB (46.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate
model: XPG GAMMIX S70 BLADE size: 1.86 TiB block-size: physical: 512 B
fw-rev: 3.2.F.83 temp: 50.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B4QFXO7 temp: 44.9 C
ID-1: / raw-size: 500 GiB size: 500 GiB (100.00%) used: 280.88 GiB (56.2%)
fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:5
used: 588 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:4
ID-3: /home raw-size: 500 GiB size: 500 GiB (100.00%)
used: 280.88 GiB (56.2%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:5
ID-4: /var/log raw-size: 500 GiB size: 500 GiB (100.00%)
ID-5: /var/tmp raw-size: 500 GiB size: 500 GiB (100.00%)
ID-1: swap-1 type: partition size: 33.85 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p4 maj-min: 259:7
ID-2: swap-2 type: zram size: 30.77 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 57.4 C mobo: N/A gpu: amdgpu temp: 50.0 C
Memory: total: 32 GiB note: est. available: 30.77 GiB used: 4.51 GiB (14.7%)
Processes: 375 Power: uptime: 8m states: freeze,mem,disk suspend: s2idle
image: 12.27 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 255 default: graphical tool: systemctl
Packages: 2341 pm: pacman pkgs: 2326 libs: 597 tools: octopi,paru
pm: flatpak pkgs: 15 Compilers: clang: 17.0.6 gcc: 14.1.1 alt: 13
Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole inxi: 3.3.34
System install date: 2024-03-16
Last full system update: 2024-05-31
Hi again. I just changed power settings from balance to performance and tried to restart, and it froze. With X11 and linux-zen kernel.
If the battery is still removed, then we can rule out anything related to that. At the moment everything points to issues with power management. In the last log it goes a few steps further and apparently freezes when the session ends.
Just a shot in the dark: System Settings → Session - select “Start with an empty session” → Apply.
But that won’t help much because you also have the freezes in a live environment. Either you have a hardware problem, a problem with the BIOS or KDE is the problem.
Can you please download the garuda-cinnamon-edition and use this live.iso to test whether the laptop also freezes when shutting down? If it also freezes in this live environment, then we can rule out KDE.
I already applied this when i installed Garuda.
I use Garuda Cinnamon live and tested several times shutdown and restart. No freezes. Also i think i’m going to install it instead of KDE for a while and want to see what will be happens. If it works properly, I will reluctantly switch to Cinnamon.
