Hello Garuda users.
i'm using a hp chromebook 14a-na0142nd. with a Intel Celeron/Pentium Silver Processor High Definition Audio. (garuda kde Dr460nized) and my problem is that my headphone willn't be detected but both of my speakers from my chromebook will be work only the jack input willn't be worl.
Kernel: 5.19.2-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=99c21d0e-b3b1-4a4e-8ad6-87220531d225 rw rootflags=subvol=@
resume=UUID=77fb1fac-55dd-408a-933c-e04c5986e4b2 loglevel=3
Type: Laptop System: Google product: Blooglet v: rev4
Mobo: HP model: Blooglet v: rev4 serial: <superuser required>
UEFI: coreboot v: MrChromebox-4.17.2 date: 07/18/2022
ID-1: BAT0 charge: 18.1 Wh (45.0%) condition: 40.2/47.4 Wh (84.9%)
volts: 8.2 min: 7.7 model: 333-1D- GH02047 type: Li-ion serial: <filter>
status: charging cycles: 43
Info: model: Intel Celeron N4020 bits: 64 type: MCP arch: Goldmont Plus
built: 2017 process: Intel 14nm family: 6 model-id: 0x7A (122) stepping: 8
microcode: 0x20
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 112 KiB
desc: d-2x24 KiB; i-2x32 KiB L2: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1498 high: 1753 min/max: 800/2800 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1244 2: 1753
bogomips: 4377
filling, PBRSB-eIBRS: Not affected
Device-1: Intel GeminiLake [UHD Graphics 600] driver: i915 v: kernel
empty: DP-1,DP-2 bus-ID: 00:02.0 chip-ID: 8086:3185 class-ID: 0380
Device-2: Luxvisions Innotech HP Wide Vision HD Camera type: USB
driver: uvcvideo bus-ID: 1-7:3 chip-ID: 30c9:0016 class-ID: 0e02
Monitor-1: eDP-1 model: LG Display 0x060f built: 2018 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics 600 (GLK 2) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
driver: sof-audio-pci-intel-apl
alternate: snd_hda_intel,snd_soc_skl,snd_soc_avs,snd_sof_pci_intel_apl
bus-ID: 00:0e.0 chip-ID: 8086:3198 class-ID: 0401
Sound Server-1: ALSA v: k5.19.2-zen1-2-zen running: yes
vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 01:00.0
Device-1: Realtek 802.11ac WLAN Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-3:2 chip-ID: 0bda:b00c class-ID: e001 serial: <filter>
Local Storage: total: 58.31 GiB used: 17.38 GiB (29.8%)
ID-1: /dev/mmcblk0 maj-min: 179:0 vendor: Kingston model: TA2964
size: 58.31 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 0x8 scheme: MBR
ID-1: / raw-size: 19.53 GiB size: 19.53 GiB (100.00%) used: 16.44 GiB
(84.2%) fs: btrfs dev: /dev/mmcblk0p3 maj-min: 179:3
ID-2: /boot/efi raw-size: 1000 MiB size: 998 MiB (99.80%) used: 608 KiB
(0.1%) fs: vfat dev: /dev/mmcblk0p1 maj-min: 179:1
ID-3: /home raw-size: 29.99 GiB size: 29.99 GiB (100.00%) used: 967.2 MiB
(3.1%) fs: btrfs dev: /dev/mmcblk0p4 maj-min: 179:4
ID-4: /var/log raw-size: 19.53 GiB size: 19.53 GiB (100.00%) used: 16.44
GiB (84.2%) fs: btrfs dev: /dev/mmcblk0p3 maj-min: 179:3
ID-5: /var/tmp raw-size: 19.53 GiB size: 19.53 GiB (100.00%) used: 16.44
ID-1: swap-1 type: zram size: 3.7 GiB used: 1.84 GiB (49.7%)
ID-2: swap-2 type: partition size: 7.81 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/mmcblk0p2 maj-min: 179:2
System Temperatures: cpu: 75.0 C mobo: N/A
Processes: 235 Uptime: 2h 43m wakeups: 64741 Memory: 3.7 GiB used: 2.44 GiB
(66.0%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pacman: 1679 lib: 441 Shell: fish v: 3.5.1
Garuda (2.6.6-1):
System install date: 2022-09-05
Last full system update: 2022-09-05 ↻
