thor1
15 December 2021 19:16
1
Hello.
After the Update yesterday and manual interception via pacman -Sy chaotic-keyring and ‘garuda-update’ which fixed the Problem, my Monitor didn’t work anymore after a reboot.
I found this other Post where @ filo suggested reinstalling ‘optimus-manager’ and reboot which didn’t work.
‘Nvidia drivers install ’
GPU NVIDIA GeForce GTX 1660 Ti
after updating the system sudo garuda-update
the second monitor didn't work after the reboot
how to fix this issue
or
from this list which are the programs that should be installed for the dual monitors' setup?
[Screenshot_6]
edit 1
inxi -Faz
System: Kernel: 5.15.7-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=2da9e79d-6e5d-49cd-850a-8ce0674aaa20
rw rootflags=subvol=@ quiet splash rd.udev.…
I don’t know what I could try to solve the Monitor Problem so help would be very much appreciated .
I can’t open Nvidia settings via menu or via Terminal which gives me this error:
'nvidia-settings'
(nvidia-settings:99160): Gtk-WARNING **: 20:12:18.941: Theme parsing error: gtk-dark.css:5822:26: '-shadow' is
not a valid color name
(nvidia-settings:99160): Gtk-WARNING **: 20:12:18.941: Theme parsing error: gtk-dark.css:5825:14: not a number
(nvidia-settings:99160): Gtk-WARNING **: 20:12:18.941: Theme parsing error: gtk-dark.css:5826:13: not a number
(nvidia-settings:99160): Gtk-WARNING **: 20:12:18.941: Theme parsing error: gtk-dark.css:5827:11: Expected a l
ength
ERROR: Unable to load info from any available system
'inxi -Faz'
Kernel: 5.15.8-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=a9c31d33-eed7-4527-8146-96db878ccfee rw rootflags=subvol=@
Type: Laptop System: Dell product: G5 5590 v: N/A
Mobo: Dell model: 0T3CD6 v: A00 serial: <superuser required> UEFI: Dell
v: 1.17.1 date: 10/05/2021
ID-1: BAT0 charge: 41.0 Wh (100.0%) condition: 41.0/60.0 Wh (68.3%)
volts: 16.9 min: 15.2 model: BYD DELL HYWXJ8C type: Li-poly
serial: <filter> status: Full
Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEA
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 4013 high: 4065 min/max: 800/4100 scaling:
driver: intel_pstate governor: performance cores: 1: 4065 2: 4047 3: 3993
4: 4003 5: 4001 6: 4000 7: 4000 8: 4001 9: 4000 10: 3992 11: 4055
12: 4003 bogomips: 52799
Type: l1tf
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Dell
driver: nvidia v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1f11 class-ID: 0300
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 0c45:671f class-ID: 0e02
loaded: modesetting display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142
v: 4.6 Mesa 21.3.1 direct render: Yes
Device-2: NVIDIA TU106 High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f9
Sound Server-1: ALSA v: k5.15.8-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.41 running: yes
Device-2: Realtek vendor: Dell driver: r8169 v: kernel port: 3000
bus-ID: 3c:00.0 chip-ID: 10ec:2502 class-ID: 0200
IF: enp60s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-14:5 chip-ID: 8087:0aaa class-ID: e001
address: <filter>
Local Storage: total: 1.36 TiB used: 919.63 GiB (65.8%)
rev: 2B2QEXM7 temp: 45.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
type: SSD serial: <filter> rev: 4B6Q scheme: MBR
ID-1: / raw-size: 80.51 GiB size: 80.51 GiB (100.00%)
used: 75.35 GiB (93.6%) fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
ID-2: /boot/efi raw-size: 650 MiB size: 646 MiB (99.38%)
used: 66.5 MiB (10.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 80.51 GiB size: 80.51 GiB (100.00%)
ID-4: /var/log raw-size: 80.51 GiB size: 80.51 GiB (100.00%)
ID-5: /var/tmp raw-size: 80.51 GiB size: 80.51 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.44 GiB used: 4.5 MiB (0.0%)
System Temperatures: cpu: 53.0 C pch: 63.0 C mobo: N/A
Processes: 314 Uptime: 10m wakeups: 1139 Memory: 15.44 GiB
used: 4.18 GiB (27.1%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: 1485 pacman: 1478 lib: 382 flatpak: 7
Shell: fish v: 3.3.1 default: Bash v: 5.1.12 running-in: konsole
inxi: 3.3.10
thor1:
It looks like some people are having problems with 495.46 - but for other people it’s working fine (and there doesn’t seem to be any obvious pattern).
You could try downgrading all your nvidia packages (nvidia-dkms, nvidia-settings) to the previous 495.44 version to see if that helps.
Same here, only on a GeForce RTX 3050 Mobile.
inxi -Faz
root=UUID=7b6e96df-621e-4aaf-a245-80007eef5efa rw rootflags=subvol=@
quiet
cryptdevice=UUID=15025ade-dda6-4f32-a486-4a0b51903fa0:luks-15025ade-dda6-4f32-a486-4a0b51903fa0
root=/dev/mapper/luks-15025ade-dda6-4f32-a486-4a0b51903fa0 splash
Type: Laptop System: LENOVO product: 82JF v: Legion 5 Pro 16ITH6
serial: <superuser required> Chassis: type: 10 v: Legion 5 Pro 16ITH6
Mobo: LENOVO model: LNVNB161216 v: SDK0R32862 WIN
serial: <superuser required> UEFI: LENOVO v: H1CN26WW date: 05/22/2021
ID-1: BAT0 charge: 78.1 Wh (95.0%) condition: 82.2/80.0 Wh (102.8%)
volts: 17.2 min: 15.4 model: Celxpert L20C4PC1 type: Li-poly
serial: <filter> status: N/A cycles: 23
Device-1: hidpp_battery_0 model: Logitech M570 serial: <filter>
Use of uninitialized value $val2 in string eq at /usr/bin/inxi line 6943.
Use of uninitialized value $val2 in split at /usr/bin/inxi line 6948.
Use of uninitialized value $val2 in concatenation (.) or string at /usr/bin/inxi line 6950.
Use of uninitialized value $val2 in concatenation (.) or string at /usr/bin/inxi line 6953.
Use of uninitialized value $val2 in concatenation (.) or string at /usr/bin/inxi line 6954.
charge: 50% rechargeable: yes status:
Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
arch: Tiger Lake family: 6 model-id: 0x8D (141) stepping: 1 microcode: 0x32
L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 1701 high: 4232 min/max: 800/4600 scaling:
driver: intel_pstate governor: performance cores: 1: 1644 2: 801 3: 1873
4: 1606 5: 856 6: 1912 7: 800 8: 800 9: 801 10: 3101 11: 801 12: 4218
13: 2176 14: 801 15: 801 16: 4232 bogomips: 73728
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Lenovo driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:9a60 class-ID: 0300
Device-2: NVIDIA GA107BM [GeForce RTX 3050 Mobile] vendor: Lenovo
chip-ID: 10de:25e2 class-ID: 0300
Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 3-6:3 chip-ID: 13d3:56bb class-ID: 0e02
Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.7x16.7")
s-diag: 798mm (31.4")
Monitor-1: eDP-1 res: 2560x1600 hz: 165 dpi: 188
size: 345x215mm (13.6x8.5") diag: 407mm (16")
Device-1: Intel Tiger Lake-H HD Audio vendor: Lenovo driver: snd_hda_intel
chip-ID: 8086:43c8 class-ID: 0403
Device-2: NVIDIA vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:2291 class-ID: 0403
Device-3: Logitech Blue Microphones type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-10:6 chip-ID: 046d:0ab7
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.41 running: yes
vendor: Lenovo driver: r8169 v: kernel port: 3000 bus-ID: 58:00.0
IF: enp88s0 state: down mac: <filter>
bus-ID: 3-14:8 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 2.29 TiB used: 230.43 GiB (9.8%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: SK Hynix model: HFS512GDE9X084N
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 41010C22
temp: 37.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Crucial model: CT2000P5SSD8
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: P4CR311 temp: 29.9 C scheme: GPT
ID-1: / raw-size: 476.68 GiB size: 476.68 GiB (100.00%)
used: 88.8 GiB (18.6%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-15025ade-dda6-4f32-a486-4a0b51903fa0
used: 16.7 MiB (6.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
used: 141.61 GiB (7.6%) fs: btrfs dev: /dev/dm-1 maj-min: 254:1
mapped: luks-a4ed31b6-55c7-4c61-86fd-10848d8a80d9
ID-4: /var/log raw-size: 476.68 GiB size: 476.68 GiB (100.00%)
ID-5: /var/tmp raw-size: 476.68 GiB size: 476.68 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.41 GiB used: 4.2 MiB (0.0%)
System Temperatures: cpu: 32.0 C mobo: N/A
Processes: 395 Uptime: 46m wakeups: 7 Memory: 15.41 GiB
used: 4.45 GiB (28.9%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1949 lib: 445 Shell: fish
v: 3.3.1 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.10
thor1
16 December 2021 18:40
4
Hello Jonathon,
Downgrading the nvidia-dkmsPackage via the downgrade command didn't work because it depends on the nvidia-utils Package.
Downgrading the Nvidia-Utils Package dint work either because it depends on nvidia-dkms.
I read, that the nvidia driver version is tied to the Kernel version that's why but I have no clue.
I ended up Timeshifting back before the Update with the Python thing and it's working again. I guess I have to wait for a patch and update then. Is there a way to exclude the nvidia drivers from an update so I can update the other packages maybe? IgnorePkg nvidia-dkms didn't did the trick.
What about downgrading them both rather than separately?
That’s also a valid temporary workaround.
Partial upgrades are not a good idea. However, it doesn’t make sense that the Python update is still creating issues - all packages should now be rebuilt.
I too used timeshif to get my second monitor working. I also followed the advice in this thread which suggested doing the upgrade, then reinstalling optimus-manager before rebooting. I did that but it didn't work for me.
TechTalk:
it didn’t work for me.
That implies you have a different problem, unrelated to optimus-manager. Unless, of course, you reinstalled an old version?
Okay, thank you jonathon. I will start a new thread.
system
Closed
7 January 2022 16:39
9
