Hello, I'm having trouble booting garudalinux.
Timeline:
Firefox crashed(nothing unusual) -> I restarted the system.
The system got stuck on the screen:
Booting Garuda Linux
Loading linux linux-zen
Loading initial ramdisk.
I tried to restore the system using recovery snapshots. I tried all recovery times. The system never boots. Different error messages show up each time. Like:
failed to start network manager online
Failed to start Deactivate Plymouth Boot Screen.
Failed to start Rotate log files.
Failed to start Samba NMB Daemon.
Failed to start Samba SMB Deamon.
and more...
Can you please advise me how to fix the problem?
SGS
22 November 2021 20:06
2
Again!
Hello.
Post your terminal/konsole in- and output as text (no pictures ) from:
inxi -Faz
Before you open a new help request, read relevant sections of the Arch and Garuda wiki .
Welcome to Garuda Linux
I'm so sorry, but I'm new to Linux.
I can't get into the system, so I can't open a terminal and run a command. I don't know how else I can run the command.
SGS
22 November 2021 20:36
4
Use live ISO, open garuda-assistant und chroot to your system and update your system
Use forum search too.
From Grub fails after update - #3 by librewish
Some unlucky times that your system is not bootable and the only advised option is to use chroot from a Live ISO to repair the installed system (for example, to (re)install the bootloader), here is the suggested method:
steps required to chroot to your installed Garuda installation (btrfs)
Boot to a Garuda usb Live ISO
Start a terminal and
Find your installed system (btrfs) partition, you need the /dev/<something> part.
lsblk -f
Warning: Remem…
This happened to me recently when the update process was interrupted (gnome-shell froze part-way through the update and I killed it, but hooks didn't run even though pacman is supposed to survive parent processes being killed, ... or something else odd happened).
You'll need to boot a live installer environment (or other Linux boot disk) and chroot into your installation, then:
pacman -Syu linux-zen
mkinitcpio -p linux-zen
update-grub
This should restore linux-zen to operation - adjust that …
While there are many potential reasons why your installation doesn’t boot to a desktop, the primary reason is that the graphics drivers haven’t loaded correctly so your login/display manager (DM) doesn’t start. This is why you get a “black screen” or stuck at an
[ OK ] Started some service
message.
The normal reason for this is that you have the incorrect driver version for the kernel. This can happens when the mirror you are updating from is not fully synchronised, or times out, and so y…
Oh, thank you for your patience. Here is the result of the command:
root@garuda-dr460nized /]# inxi -Faz
12System: 12Kernel 5.12.12-zen1-1-zen x86_64 12bits 64 12compiler gcc 12v 11.1.0
12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=garuda misolabel=GARUDA_DR460NIZED_SOARING_ quiet systemd.show_status=1
driver=nonfree nouveau.modeset=0 i915.modeset=1 radeon.modeset=1
12Console N/A 12Distro Garuda Linux 12base Arch Linux
12Machine: 12Type Desktop 12System Gigabyte 12product X470 AORUS ULTRA GAMING 12v N/A 12serial N/A
12Mobo Gigabyte 12model X470 AORUS ULTRA GAMING-CF 12v x.x 12serial N/A
12UEFI American Megatrends 12v F6 12date 01/25/2019
(upower:27): UPower-WARNING **: 21:42:08.715: Cannot connect to upowerd: Could not connect: No such file or directory
12Battery: 12Device-1 hidpp_battery_0 12model Logitech Wireless Keyboard PID:0065 12serial N/A
12charge High 12status Discharging
12Device-2 hidpp_battery_1 12model Logitech Wireless Mouse PID:003f 12serial N/A
12charge Normal 12status Discharging
12CPU: 12Info 8-Core 12model AMD Ryzen 7 2700X 12socket AM4 12bits 64 12type MT MCP 12arch Zen+
12family 17 (23) 12model-id 8 12stepping 2 12microcode 800820D 12cache 12L1 768 KiB 12L2 4 MiB
12L3 16 MiB
12flags avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm 12bogomips 118387
12Speed 2957 MHz 12min/max 2200/3700 MHz 12base/boost 3700/4350 12boost enabled 12volts 1.2 V
12ext-clock 100 MHz 12Core speeds (MHz) 121 2957 122 3206 123 2420 124 2880 125 2410 126 2568 127 2416
128 2514 129 2477 1210 2573 1211 3227 1212 3497 1213 2703 1214 2387 1215 2746 1216 2582
12Vulnerabilities 12Type itlb_multihit 12status Not affected
12Type l1tf 12status Not affected
12Type mds 12status Not affected
12Type meltdown 12status Not affected
12Type spec_store_bypass
12mitigation Speculative Store Bypass disabled via prctl and seccomp
12Type spectre_v1 12mitigation usercopy/swapgs barriers and __user pointer sanitization
12Type spectre_v2
12mitigation Full AMD retpoline, IBPB: conditional, STIBP: disabled, RSB filling
12Type srbds 12status Not affected
12Type tsx_async_abort 12status Not affected
12Graphics: 12Device-1 NVIDIA GP106 [GeForce GTX 1060 6GB] 12vendor ASUSTeK 12driver nvidia 12v 465.31
12bus-ID 0a:00.0 12chip-ID 10de:1c03 12class-ID 0300
12Display 12server X.org 1.20.13 12compositor kwin_x11 12driver 12loaded nvidia 12tty N/A
12Message Advanced graphics data unavailable in console for root.
12Audio: 12Device-1 NVIDIA GP106 High Definition Audio 12vendor ASUSTeK 12driver snd_hda_intel
12v kernel 12bus-ID 0a:00.1 12chip-ID 10de:10f1 12class-ID 0403
12Device-2 AMD Family 17h HD Audio 12vendor Gigabyte 12driver snd_hda_intel 12v kernel
12bus-ID 0c:00.3 12chip-ID 1022:1457 12class-ID 0403
12Sound Server-1 ALSA 12v k5.12.12-zen1-1-zen 12running yes
12Sound Server-2 JACK 12v 1.9.19 12running no
12Sound Server-3 PulseAudio 12v 15.0 12running no
12Sound Server-4 PipeWire 12v 0.3.37 12running yes
12Network: 12Device-1 Intel I211 Gigabit Network 12vendor Gigabyte 12driver igb 12v kernel 12port f000
12bus-ID 07:00.0 12chip-ID 8086:1539 12class-ID 0200
12IF enp7s0 12state down 12mac <filter>
12Bluetooth: 12Device-1 Cambridge Silicon Radio Bluetooth Dongle (HCI mode) 12type USB 12driver btusb
12v 0.8 12bus-ID 5-4:3 12chip-ID 0a12:0001 12class-ID e001
12Report bt-adapter 12ID hci0 12rfk-id 0 12state up 12address N/A
12Drives: 12Local Storage 12total 2.49 TiB 12used 258.59 GiB (10.1%)
12ID-1 /dev/nvme0n1 12maj-min 259:0 12vendor Samsung 12model SSD 970 EVO Plus 250GB
12size 232.89 GiB 12block-size 12physical 512 B 12logical 512 B 12speed 31.6 Gb/s 12lanes 4
12type SSD 12serial <filter> 12rev 1B2QEXM7 12temp 37.9 C
12SMART yes 12health PASSED 12on 213d 4h 12cycles 2,388 12read-units 47,889,581 [24.5 TB]
12written-units 88,510,237 [45.3 TB]
12ID-2 /dev/sda 12maj-min 8:0 12vendor Samsung 12model SSD 850 EVO 250GB 12family based SSDs
12size 232.89 GiB 12block-size 12physical 512 B 12logical 512 B 12sata 3.1 12speed 6.0 Gb/s
12type SSD 12serial <filter> 12rev 2B6Q 12temp 33 C
12SMART yes 12state enabled 12health PASSED 12on 1y 235d 5h 12cycles 4925 12written 9.15 TiB
12ID-3 /dev/sdb 12maj-min 8:16 12vendor Seagate 12model ST2000DM008-2FR102 12family BarraCuda 3.5
12size 1.82 TiB 12block-size 12physical 4096 B 12logical 512 B 12sata 3.1 12speed 6.0 Gb/s 12type HDD
12rpm 7200 12serial <filter> 12rev 0001 12temp 34 C
12SMART yes 12state enabled 12health PASSED 12on 373d 5h 12cycles 2378 12read 18.99 TiB
12written 9.35 TiB 12Pre-Fail 12attribute Spin_Retry_Count 12value 100 12worst 100 12threshold 97
12ID-4 /dev/sdc 12maj-min 8:32 12type USB 12vendor A-Data 12model SD600Q 12size 223.57 GiB
12block-size 12physical 4096 B 12logical 512 B 12type N/A 12serial <filter> 12rev 9304
12SMART Message Unknown USB bridge. Flash drive/Unsupported enclosure?
12Partition: 12ID-1 / 12raw-size 232.42 GiB 12size 232.42 GiB (100.00%) 12used 158.36 GiB (68.1%) 12fs btrfs
12block-size 4096 B 12dev /dev/nvme0n1p1 12maj-min 259:1
12ID-2 /boot/efi 12raw-size 474.2 MiB 12size 473.2 MiB (99.80%) 12used 580 KiB (0.1%) 12fs vfat
12block-size 512 B 12dev /dev/nvme0n1p2 12maj-min 259:2
12ID-3 /home 12raw-size 232.42 GiB 12size 232.42 GiB (100.00%) 12used 158.36 GiB (68.1%)
12fs btrfs 12block-size 4096 B 12dev /dev/nvme0n1p1 12maj-min 259:1
12ID-4 /var/log 12raw-size 232.42 GiB 12size 232.42 GiB (100.00%) 12used 158.36 GiB (68.1%)
12ID-5 /var/tmp 12raw-size 232.42 GiB 12size 232.42 GiB (100.00%) 12used 158.36 GiB (68.1%)
12Swap: 12Kernel 12swappiness 10 (default 60) 12cache-pressure 75 (default 100)
12ID-1 swap-1 12type zram 12size 1.96 GiB 12used 0 KiB (0.0%) 12priority 32767 12dev /dev/zram0
12ID-2 swap-2 12type zram 12size 1.96 GiB 12used 0 KiB (0.0%) 12priority 32767 12dev /dev/zram1
12ID-3 swap-3 12type zram 12size 1.96 GiB 12used 0 KiB (0.0%) 12priority 32767 12dev /dev/zram2
12ID-4 swap-4 12type zram 12size 1.96 GiB 12used 0 KiB (0.0%) 12priority 32767 12dev /dev/zram3
12ID-5 swap-5 12type zram 12size 1.96 GiB 12used 0 KiB (0.0%) 12priority 32767 12dev /dev/zram4
12ID-6 swap-6 12type zram 12size 1.96 GiB 12used 0 KiB (0.0%) 12priority 32767 12dev /dev/zram5
12ID-7 swap-7 12type zram 12size 1.96 GiB 12used 0 KiB (0.0%) 12priority 32767 12dev /dev/zram6
12ID-8 swap-8 12type zram 12size 1.96 GiB 12used 0 KiB (0.0%) 12priority 32767 12dev /dev/zram7
12ID-9 swap-9 12type zram 12size 1.96 GiB 12used 0 KiB (0.0%) 12priority 32767 12dev /dev/zram8
12ID-10 swap-10 12type zram 12size 1.96 GiB 12used 0 KiB (0.0%) 12priority 32767 12dev /dev/zram9
12ID-11 swap-11 12type zram 12size 1.96 GiB 12used 0 KiB (0.0%) 12priority 32767 12dev /dev/zram10
12ID-12 swap-12 12type zram 12size 1.96 GiB 12used 0 KiB (0.0%) 12priority 32767 12dev /dev/zram11
12ID-13 swap-13 12type zram 12size 1.96 GiB 12used 0 KiB (0.0%) 12priority 32767 12dev /dev/zram12
12ID-14 swap-14 12type zram 12size 1.96 GiB 12used 0 KiB (0.0%) 12priority 32767 12dev /dev/zram13
12ID-15 swap-15 12type zram 12size 1.96 GiB 12used 0 KiB (0.0%) 12priority 32767 12dev /dev/zram14
12ID-16 swap-16 12type zram 12size 1.96 GiB 12used 0 KiB (0.0%) 12priority 32767 12dev /dev/zram15
12Sensors: 12System Temperatures 12cpu 52.8 C 12mobo N/A
12Fan Speeds (RPM) N/A
12Info: 12Processes 384 12Uptime 3m 12wakeups 4 12Memory 31.36 GiB 12used 3.7 GiB (11.8%) 12Init systemd
12v 249 12tool systemctl 12Compilers 12gcc 11.1.0 12clang 12.0.1 12Packages 1612 12pacman 1566
12lib 372 12flatpak 46 12Client Unknown Client: systemd 12inxi 3.3.06
From Live-ISO
SGS
22 November 2021 21:07
6
When did these errors start, update, force power-off?
Vejv-cz:
wakeups 4
Check the links above, backup your data, if you can’t implement any of these, reinstall.
Vejv-cz:
From Live-ISO
Did you miss this suggestion?
system
Closed
7 December 2021 16:58
8
