Back on 5 December I posted Slow system after update. Long story short, my laptop was locked at 400MHz following an update of the Zen kernel.
In the end I downloaded CPUpower and this revealed that the driver had been changed to amd-pstate...
cpupower frequency-info
analyzing CPU 0:
driver: amd-pstate
CPUs which run at the same hardware frequency: 0
CPUs which need to have their frequency coordinated by software: 0
maximum transition latency: 131 us
hardware limits: 400 MHz - 4.06 GHz
available cpufreq governors: conservative ondemand userspace powersave performance schedutil
current policy: frequency should be within 400 MHz and 4.06 GHz.
The governor "powersave" may decide which speed to use
within this range.
current CPU frequency: Unable to call hardware
current CPU frequency: 409 MHz (asserted by call to kernel)
boost state support:
Supported: yes
Active: yes
AMD PSTATE Highest Performance: 255. Maximum Frequency: 4.06 GHz.
AMD PSTATE Nominal Performance: 132. Nominal Frequency: 2.10 GHz.
AMD PSTATE Lowest Non-linear Performance: 70. Lowest Non-linear Frequency: 1.11 GHz.
AMD PSTATE Lowest Performance: 26. Lowest Frequency: 400 MHz.
I got things working correctly after a lot of help and head scratching. I was happy that my laptop idled at 400MHz as it was good for battery life.
I updated the kernel again earlier today, and my laptop has reverted to idling at 1.4GHZ...
analyzing CPU 0:
driver: acpi-cpufreq
maximum transition latency: Cannot determine or is not supported.
hardware limits: 1.40 GHz - 4.06 GHz
available frequency steps: 2.10 GHz, 1.70 GHz, 1.40 GHz
current policy: frequency should be within 1.40 GHz and 2.10 GHz.
The governor "conservative" may decide which speed to use
within this range.
current CPU frequency: 1.40 GHz (asserted by call to kernel)
Supported: yes
Active: no
I am at a loss.
