mtsbh
26 October 2023 18:08
1
Hello! I just came across this post and I have a desire to do it, but I’m having similar problems like those, above and below, and also after git cloned the repo my colors file also is known as SGS-blue. Are there any new files? Because I can make it from those. It changed only the settings and windows but the rest is pink.
I also don’t have Sweetified-blue color scheme.
SGS
26 October 2023 18:20
2
Let me check
in ~/.config
changes are in gtk-3.0, gtk-4.0 and kvantum, maybe more.
Give me some time.
In the meantime post your garuda-inxi, please.
mtsbh
26 October 2023 18:22
3
sure, thank you.
root=UUID=d90b4f07-4d0e-4a4a-bc42-3659e33df70c rw rootflags=subvol=@
Type: Desktop Mobo: Micro-Star model: B450 TOMAHAWK MAX II (MS-7C02) v: 3.0
serial: <superuser required> UEFI: American Megatrends LLC. v: H.B1
date: 06/10/2023
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 2575 high: 3700 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3594 2: 2567
3: 2200 4: 2200 5: 2873 6: 2775 7: 3700 8: 2200 9: 2200 10: 2200 11: 2200
12: 2200 bogomips: 88801
Device-1: NVIDIA GA104 [GeForce RTX 3060] vendor: PNY driver: nvidia
v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-09) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-23 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 26:00.0 chip-ID: 10de:2487
compositor: kwin_x11 driver: X: loaded: modesetting,nouveau,nvidia
Screen-1: 0 s-res: 6960x1920 s-dpi: 109 s-size: 1622x447mm (63.86x17.60")
s-diag: 1682mm (66.24")
Monitor-1: DP-0 pos: bottom-r res: 1920x1080 hz: 60 dpi: 92
Monitor-2: DP-2 pos: top-left res: 1200x1920 hz: 60 dpi: 94
size: 324x518mm (12.76x20.39") diag: 611mm (24.05") modes: N/A
Monitor-3: DP-4 pos: primary,top-center res: 3840x1600 hz: 60 dpi: 111
size: 879x366mm (34.61x14.41") diag: 952mm (37.49") modes: N/A
Monitor-4: None-1-1 size-res: N/A modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: gbm: drv: nvidia
API: OpenGL v: 4.6.0 vendor: nvidia v: 535.113.01 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
memory: 11.72 GiB
API: Vulkan v: 1.3.269 layers: 4 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: nvidia v: 535.113.01
device-ID: 10de:2487 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
Device-1: NVIDIA GA104 High Definition Audio vendor: PNY
link-max: gen: 4 speed: 16 GT/s bus-ID: 26:00.1 chip-ID: 10de:228b
bus-ID: 28:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Yamaha [] driver: snd-usb-audio type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1.1:4 chip-ID: 0499:170f
class-ID: 0103
Device-4: Intel [] driver: hid-generic,snd-usb-audio,usbhid type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-2:3 chip-ID: 8086:0808
IF-ID-1: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
Device-1: TP-Link [] driver: btusb v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-2:2 chip-ID: 2357:0604 class-ID: e001
lmp-v: 10 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 4.1 TiB used: 1.98 TiB (48.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520
SDAPNUW-512G-1014 size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
fw-rev: 20110000 temp: 47.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
ID-3: /dev/sdb maj-min: 8:16 vendor: Toshiba model: HDWD120 size: 1.82 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: HDD
rpm: 7200 serial: <filter> fw-rev: ACF0 scheme: GPT
used: 37.42 GiB (7.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.27 GiB used: 202.2 MiB (0.6%)
System Temperatures: cpu: 47.2 C mobo: N/A gpu: nvidia temp: 58 C
Processes: 306 Uptime: 7m wakeups: 0 Memory: total: 32 GiB
available: 31.27 GiB used: 4.64 GiB (14.8%) Init: systemd v: 254
pm: pacman pkgs: 1776 libs: 538 tools: octopi,pamac,paru Shell: fish
v: 3.6.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2023-10-24
Last full system update: 2023-10-26 ↻
SGS
26 October 2023 18:25
4
On KDE it’s needed often to restart, ↻, for complete the theming.
mtsbh
26 October 2023 18:28
5
Yes, already restarted a couple of times. It was one small update from the KDE Discover that I clicked on. I will restart again.
I also saw that I don’t have .kde4 folder in ~
Should I manually create it?
SGS
26 October 2023 18:30
6
Just wait, I will update the git.
SGS
26 October 2023 19:14
7
So, make backups from your configs first.
GitLab.com
try my files, but maybe you must fix some parts, dpi, font, coursor, etc…
You can use meld to check differences.
mtsbh
26 October 2023 19:17
8
Great, thank you. But where exactly should I place them? In /usr/share/themes/ ?
SGS
26 October 2023 19:21
9
No, in your home folder
.config
After all restart and check dolphin, right click menues, must be blue
If I missed something?
I am using breeze, breeze-dark and “colors” sweetified-blue (sweet-blue) in appearance system settings.
.local/share/color-schemes/
mtsbh
26 October 2023 19:49
10
Thanks a lot! It’s all good now I think.
I edited the config files by leaving my custom ones and changed the rest.
Sweet in Kvantum and gtk-2.0 folders were missing from my .config folder.
I didn’t had an assets folder in gtk-3.0, also.
I think those were the things that prevented my success without contacting the forum
Anyway, I think it’s all good now.
It’s only missing a couple of stuff - like the borders and that too-transparent things, but I will find a way to fix it. At least it’s not pink anymore and my eyes are not hurting.
Appreciated!
SGS
26 October 2023 19:52
11
use
appearance in system settings.
SGS
26 October 2023 19:57
12
Thank you @Kayo but it work also on hyprland
mtsbh
13
I don’t have sweetified-blue in colors, but the breeze application style fixed the transparency and borders. Thank you!
SGS
26 October 2023 20:00
14
sweet-blue?
I am not good in KDE
I edit Sweet, change all pink to blue, and save to Sweet-blue.
Maybe some one know where these files are stored?
Kayo?
Color Scheme Files
Kayo
26 October 2023 20:08
15
https://docs.kde.org/stable5/en/kate/katepart/color-themes.html
Under the heading " The Color Themes JSON Format" I think is what your are talking about.
SGS
26 October 2023 21:02
16
Missing
/usr/share/org.kde.syntax-highlighting/themes/
qtpaths --paths GenericDataLocation
/home/sgs/.local/share:/usr/local/share:/usr/share
sudo find -iname sweet-blue
./usr/share/icons/Sweet-Blue
I edit the git and add .local/share/themes/ files and add also the .config folder.
Don’t hit me use what you need
Many stand on it, I altogether also up to the pink stuff, there we are both brothers in spirit, uh, eye
Maybe @FDG has an idea, whether it is also easier to implement?
mtsbh
26 October 2023 21:17
17
Great!
^ Now if I find a way of changing these colors without completely changing the window decorations border would be awesome.
SGS
26 October 2023 21:19
18
Use plastik ore others , also in appearance. window decorations.
Ups, I think changing the dot colors is not possible.
white-sur(e) theme?
Edit:
Added on Gitlab color schemes.
system
Closed
28 October 2023 21:20
19
