Hello Garuda users.
I have recently installed Garuda Cinnamon on my desktop and laptop, and I am loving it, with one small exception. On my desktop I have two monitors, and they are exhibiting a stubborn refusal to stay where I put them (logically of course). They keep switching their left and right positions!
I used Nvidia x-server settings to orient them they way they are placed on my desk, and clicked apply, confirmed that yes this how I want the layout to be, but 'Save to X configuration File' would not stick, as 'you have to be root to save this file', or similar.
So I sudo'ed the nvidia-settings command, and repeated the steps, and was able to save the x configuration file (or so I thought). The setting holds only until I either reboot or the screen goes to sleep, then they are reversed again.
I saw a post somewhere where someone said use arandr to make this change, so i tried that too. Same situation - setting works, but only until reboot or screen timeout.
I even tried switching out the DisplayPort cables on them - no dice. Garuda saw that immediately and 'fixed' what I did.
Kernel: 5.18.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=ef16f983-62b4-4910-a14d-c334ec8ca9b7 rw rootflags=subvol=@
resume=UUID=2a54b60f-a88d-45d5-9353-fe3c532df102 loglevel=3 ibt=off
Desktop: Cinnamon v: 5.4.2 tk: GTK v: 3.24.34 wm: Mutter vt: 7
dm: LightDM v: 1.30.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: Gigabyte model: B365M DS3H WIFI v: x.x
serial: <superuser required> UEFI: American Megatrends v: F1 Y1
date: 05/14/2019
Info: model: Intel Core i7-9700F bits: 64 type: MCP arch: Coffee Lake
gen: core 9 built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158)
stepping: 0xD (13) microcode: 0xF0
Topology: cpus: 1x cores: 8 smt: <unsupported> cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 4269 high: 4589 min/max: 800/4700 scaling:
driver: intel_pstate governor: performance cores: 1: 3458 2: 4577 3: 4589
4: 4551 5: 4399 6: 3629 7: 4449 8: 4501 bogomips: 48000
Type: mmio_stale_data mitigation: Clear CPU buffers; SMT disabled
Device-1: NVIDIA TU104 [GeForce RTX 2070 SUPER] vendor: ASUSTeK
driver: nvidia v: 515.48.07 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Turing process: TSMC 12nm
built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1e84 class-ID: 0300
Device-2: Microsoft Microsoft LifeCam Cinema type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-8.4:9 chip-ID: 045e:0812
class-ID: 0102
Display: x11 server: X.Org v: 21.1.3 driver: X: loaded: nvidia
unloaded: modesetting alternate: fbdev,nouveau,nv,vesa gpu: nvidia
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.00x11.26")
s-diag: 1055mm (41.55")
Monitor-1: DP-0 pos: right res: 1920x1080 hz: 144 dpi: 82
Monitor-2: DP-4 pos: primary,left res: 1920x1080 hz: 144 dpi: 81
size: 600x340mm (23.62x13.39") diag: 690mm (27.15") modes: N/A
Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 1-8.4:9 bus-ID: 00:1f.3
chip-ID: 045e:0812 chip-ID: 8086:a2f0 class-ID: 0102 class-ID: 0403
Device-2: NVIDIA TU104 HD Audio vendor: ASUSTeK driver: snd_hda_intel
Device-3: Microsoft Microsoft LifeCam Cinema type: USB
Sound Server-1: ALSA v: k5.18.6-zen1-1-zen running: yes
lanes: 1 port: d000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak]
driver: iwlwifi v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 08:00.0 chip-ID: 8086:24fb class-ID: 0280
IF: wlp8s0 state: up mac: <filter>
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-11:6 chip-ID: 8087:0aa7 class-ID: e001
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0
port: f020 bus-ID: 00:17.0 chip-ID: 8086:2822 rev: class-ID: 0104
Local Storage: total: 2.71 TiB used: 446.25 GiB (16.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
ID-2: /dev/sdb maj-min: 8:16 vendor: Apacer model: AS340 480GB
type: SSD serial: <filter> rev: .2 scheme: GPT
model: WD10EURX-63FH1Y0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: N/A serial: <filter> rev: 1A01
scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST1000DM010-2EP102
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: CC43
ID-1: / raw-size: 431.04 GiB size: 431.04 GiB (100.00%)
used: 11.67 GiB (2.7%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 431.04 GiB size: 431.04 GiB (100.00%)
ID-4: /var/log raw-size: 431.04 GiB size: 431.04 GiB (100.00%)
ID-5: /var/tmp raw-size: 431.04 GiB size: 431.04 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.29 GiB used: 22 MiB (0.1%) priority: 100
ID-2: swap-2 type: partition size: 34.42 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 41.0 C mobo: N/A gpu: nvidia temp: 49 C
Processes: 340 Uptime: 1d 16h 8m wakeups: 0 Memory: 31.29 GiB
used: 4.72 GiB (15.1%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 Packages: pacman: 1329 lib: 316
Shell: fish v: 3.4.1 default: Bash v: 5.1.16 running-in: gnome-terminal
inxi: 3.3.19
Garuda (2.6.4-2):
System install date: 2022-06-24
Last full system update: 2022-06-25 ↻
Thank in advance to any help thrown my way, I really don't want to have to physically swap these monitors on the stand!
Shane
