HughF
27 June 2022 09:39
#1
The Display applet has vanished from the latest Cinnamon update (the one that was pushed a few days ago). I've had to revert to a pre-update snapshot to get it back. Every time I run an update, it vanishes...
Most odd, and totally annoying as I need to set fractional scaling for my in-laptop-display and setup my docked setup for my 34" ultrawide at work.
Hi @HughF , your post has been moved to a new thread since it is an unrelated issue.
Please post the output of
and add any additional troubleshooting information that may be relevant to people trying to help.
HughF
27 June 2022 11:55
#3
This is pre-upgrade:
Kernel: 5.18.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=167b0d8e-27dd-4c93-b4b5-833a9f401ef3 rw [email protected]
Desktop: Cinnamon v: 5.2.7 tk: GTK v: 3.24.34 wm: muffin vt: 7
dm: LightDM v: 1.30.0 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: ASUSTeK product: ROG Zephyrus G14 GA401IV_GA401IV
Mobo: ASUSTeK model: GA401IV v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: GA401IV.220 date: 03/14/2022
ID-1: BAT0 charge: 50.7 Wh (79.0%) condition: 64.2/76.0 Wh (84.5%)
Info: model: AMD Ryzen 9 4900HS with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600104
L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 1607 high: 2362 min/max: 1400/3000 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 1558 2: 1397
3: 1728 4: 1416 5: 1397 6: 1396 7: 1396 8: 1396 9: 1397 10: 2133 11: 1453
12: 1658 13: 1434 14: 2362 15: 2204 16: 1397 bogomips: 95818
Device-1: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1 off: eDP-1 empty: none
bus-ID: 04:00.0 chip-ID: 1002:1636 class-ID: 0300
Device-2: Chicony HP HD Camera type: USB driver: uvcvideo
bus-ID: 5-1.3.1:23 chip-ID: 04f2:b5bd class-ID: 0e02
Device-3: Chicony HP IR Camera type: USB driver: uvcvideo
bus-ID: 5-1.3.2:24 chip-ID: 04f2:b5be class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 driver: X: loaded: amdgpu
unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu display-ID: :0
Screen-1: 0 s-res: 6880x2880 s-dpi: 96 s-size: 1820x762mm (71.65x30.00")
s-diag: 1973mm (77.68")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: primary model: HP ENVY 34
serial: <filter> built: 2017 res: 6880x2880 dpi: 219 gamma: 1.2
size: 797x333mm (31.38x13.11") diag: 864mm (34") modes: max: 3440x1440
min: 720x400
Monitor-2: eDP-1 mapped: eDP note: disabled model: AU Optronics 0xe68c
built: 2019 res: 6880x2880 dpi: 210 gamma: 1.2
size: 309x174mm (12.17x6.85") diag: 355mm (14") ratio: 16:9 modes:
max: 2560x1440 min: 640x480
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 04:00.1
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: N/A
snd_acp_pci, snd_sof_amd_renoir
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 04:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-4: HP ENVY 34 type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 5-1.3.4:25 chip-ID: 03f0:0c47 class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.18.1-zen1-1-zen running: yes
Sound Server-2: JACK v: 1.9.21 running: no
Sound Server-3: PulseAudio v: 16.0 running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
bus-ID: 5-4:11 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 953.87 GiB used: 88.06 GiB (9.2%)
model: PC SN530 SDBPNPZ-1T00-1002 size: 953.87 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 21106000 temp: 33.9 C scheme: GPT
ID-1: / raw-size: 467.61 GiB size: 467.61 GiB (100.00%)
used: 88.04 GiB (18.8%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
used: 25.9 MiB (10.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 467.61 GiB size: 467.61 GiB (100.00%)
ID-4: /var/log raw-size: 467.61 GiB size: 467.61 GiB (100.00%)
ID-5: /var/tmp raw-size: 467.61 GiB size: 467.61 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.11 GiB used: 2.2 MiB (0.0%)
System Temperatures: cpu: 44.0 C mobo: N/A gpu: amdgpu temp: 39.0 C
Fan Speeds (RPM): cpu: 2400
Processes: 410 Uptime: 2h 22m wakeups: 3 Memory: 15.11 GiB
used: 7.13 GiB (47.2%) Init: systemd v: 251 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1583 lib: 373 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.16
Garuda (2.6.3-2):
System install date: 2021-03-24
Last full system update: 2022-06-06
Snapshots: Timeshift (maybe)
Failed units: systemd-guest-user.service
And have you checked for any Cinnamon -related bug reports, specifically regarding that Cinnamon Applet ? Those things will be out of the hands of Garuda developers most generally.
HughF:
Hi and welcome, what happens after updating and rebooting?
The display settings should be getting changed through System Settings -> Display .
If you click the menu button on the taskbar or hit the meta key and type "settings" or "system settings" it should come right up. On my system the display settings window looks like this:
Is this the option you are missing, or have you been using something else to configure your display?
HughF
27 June 2022 12:40
#7
System Settings -> Display is not present post-upgrade.
This is the applet that I have used for years to configure my displays, and I've been using Cinnamon for a long time now.
Naman
27 June 2022 13:06
#9
I am facing similar issue, and as I have to switch between refresh rates regularly on my laptop, I can understand your problem.
One of the workaround, as mentioned, is Cinnamon Settings -> Display
It is accessible on my side.
Also, I will try to figure out some solution to the issue ASAP.
Thanks for reporting the bug.
Naman
1 July 2022 14:30
#10
Sorry, I forgot to update
Solution
Run
sudo sed 's/cinnamon-control-panel/cinnamon-settings/' /usr/share/applications/cinnamon-display-panel.deskto
And logout/reboot.
Explanation
For some reason that I don't know, Cinnamon devs have changed cinnamon-settings to cinnamon-control-panel in applet. This command replaces cinnamon-control-panel with cinnamon-settings in the applet.
PS : Marking it solved now.
system
closed
3 July 2022 14:30
#11
