Hey fam,
I'm sad about the KDE 5.26 update. It's screwed up my renderer and now my main monitor does not work after login. I wanted to ask here (i know it's not kde forum, but again, i figure i can't be the only one with the issue and someone's bound to have tried something) before I leap here about downgrading back to 5.25. I already tried a snapshot before my last garuda-update, and it did not restore functionality. I didn't expect it to, but i still wanted to try.
I did search the forum here, arch wiki and forums. I'll be honest i need someone to hold my hand because I have a deadline to meet by monday, so i just need to be rescued at this point... I shouldn't have run an update when i knew a new KDE Plasma was launching... ![]()
Will this work to downgrade? Should i be trying something different?:
pacman -U /var/cache/pacman/pkg/plasma-*5.25.5*.pkg.tar.zst /var/cache/pacman/pkg/kdeplasma-addons-5.25.5-1-x86_64.pkg.tar.zst /var/cache/pacman/pkg/kde*5.25.5*.pkg.tar.zst
╭─me@pc in /var/cache/pacman/pkg🔒 took 85ms
╰─λ garuda-inxi (base)
Kernel: 6.0.1-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=f6cccf9c-8580-435e-8f33-927e3e31bb2d rw rootflags=subvol=@
resume=UUID=2e9cba84-8fd3-4884-995e-6ac1c54716ad loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.26.0 tk: Qt v: 5.15.6 info: latte-dock
Type: Desktop System: Gigabyte product: X570 AORUS ELITE v: -CF
Mobo: Gigabyte model: X570 AORUS ELITE v: x.x
serial: <superuser required> UEFI: American Megatrends LLC. v: F34
date: 06/10/2021
ID-1: hidpp_battery_0 charge: 61% condition: N/A volts: 3.9 min: N/A
Info: model: AMD Ryzen 9 3950X bits: 64 type: MT MCP arch: Zen 2 gen: 3
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 3502 high: 3593 min/max: 2200/4761 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3500 2: 3500
3: 3500 4: 3500 5: 3500 6: 3500 7: 3593 8: 3500 9: 3500 10: 3500 11: 3500
12: 3500 13: 3500 14: 3500 15: 3500 16: 3500 17: 3500 18: 3500 19: 3500
20: 3500 21: 3500 22: 3500 23: 3500 24: 3500 25: 3500 26: 3500 27: 3500
28: 3500 29: 3500 30: 3500 31: 3500 32: 3500 bogomips: 223572
protection
Device-1: NVIDIA TU104 [GeForce RTX 2070 SUPER] vendor: Micro-Star MSI
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 515.xx+
process: TSMC 12nm built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 0a:00.0 chip-ID: 10de:1e84
Device-2: Focusrite-Novation Scarlett 2i2 Camera type: USB
driver: snd-usb-audio bus-ID: 7-2:2 chip-ID: 1235:8210 class-ID: 0102
Device-3: Logitech C922 Pro Stream Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 7-3.3:7 chip-ID: 046d:085c
Screen-1: 0 s-res: 2560x1440 s-dpi: 107 s-size: 608x342mm (23.94x13.46")
s-diag: 698mm (27.46")
Monitor-1: DP-0 pos: primary res: 2560x1440 dpi: 109
Monitor-2: DP-2 size-res: N/A modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 2070 SUPER/PCIe/SSE2 v: 4.6.0 NVIDIA
520.56.06 direct render: Yes
Device-1: YUAN High-Tech Development vendor: Corsair Memory driver: N/A
pcie: bus-ID: 7-2:2 gen: 1 chip-ID: 1235:8210 class-ID: 0102
speed: 2.5 GT/s serial: <filter> lanes: 1 bus-ID: 06:00.0
chip-ID: 12ab:0380 class-ID: 0480
Device-2: NVIDIA TU104 HD Audio vendor: Micro-Star MSI
bus-ID: 0a:00.1 chip-ID: 10de:10f8 class-ID: 0403
Device-3: AMD Starship/Matisse HD Audio vendor: Gigabyte
Device-4: Focusrite-Novation Scarlett 2i2 Camera type: USB
Device-5: Logitech C922 Pro Stream Webcam type: USB
Device-6: Texas Instruments ATH-G1WL type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 7-3.4:8 chip-ID: 0451:16ba
Sound API: ALSA v: k6.0.1-zen2-1-zen running: yes
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0
Device-1: TP-Link UB500 Adapter type: USB driver: btusb v: 0.8
bus-ID: 7-4:4 chip-ID: 2357:0604 class-ID: e001 serial: <filter>
Local Storage: total: 4.57 TiB used: 905.48 GiB (19.3%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: SanDisk model: ADATA SX6000PNP
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: V9002s85
temp: 35.9 C scheme: GPT
model: WDS100T1XHE-00AFY0 size: 931.51 GiB block-size: physical: 512 B
rev: 614600WD temp: 40.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
model: WD20EARX-00ZUDB0 size: 1.82 TiB block-size: physical: 4096 B
rev: 0A80 scheme: GPT
ID-1: / raw-size: 896.73 GiB size: 896.73 GiB (100.00%) used: 419.57 GiB
(46.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 592 KiB
ID-3: /home raw-size: 896.73 GiB size: 896.73 GiB (100.00%) used: 419.57
GiB (46.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 896.73 GiB size: 896.73 GiB (100.00%) used: 419.57
ID-5: /var/tmp raw-size: 896.73 GiB size: 896.73 GiB (100.00%) used: 419.57
ID-1: swap-1 type: zram size: 31.28 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 34.49 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 42.2 C mobo: 31.0 C gpu: nvidia temp: 35 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 24%
Processes: 499 Uptime: 16m wakeups: 2 Memory: 31.28 GiB used: 3.91 GiB
(12.5%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 alt: 11 clang: 14.0.6 Packages: pm: pacman
pkgs: 2530 libs: 564 tools: octopi,pamac,paru Shell: fish v: 3.5.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.22
Garuda (2.6.8-1):
System install date: 2022-01-22
Last full system update: 2022-10-15
