Monitor blurry and zoomed in on start-up
hello, every time i startup mu computer my monitor becomes a bit zoomed in and gets blurry, to fix this i just have to run xrandr --output eDP1 --auto which is tedious to have to run every time i turn on the computer. Is there any settings to fix this? Is it possible to run a batch script on start-up?
output:
Kernel: 5.16.3-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=3d7f37ea-6ec9-4e7c-abfb-36c47e2e627b rw rootflags=subvol=@
Type: Laptop System: Dell product: Latitude E7470 v: N/A
Mobo: Dell model: 0T6HHJ v: A00 serial: <superuser required>
UEFI-[Legacy]: Dell v: 1.31.3 date: 10/13/2021
ID-1: BAT0 charge: 48.0 Wh (100.0%) condition: 48.0/55.0 Wh (87.4%)
volts: 8.4 min: 7.6 model: SMP DELL MC34Y51 type: Li-poly serial: <filter>
status: Full
ID-2: hidpp_battery_0 charge: 53% condition: N/A volts: 3.8 min: N/A
Info: model: Intel Core i5-6300U bits: 64 type: MT MCP arch: Skylake
family: 6 model-id: 0x4E (78) stepping: 3 microcode: 0xEA
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1200 min/max: 400/3000 scaling: driver: intel_pstate
governor: powersave cores: 1: 1200 2: 1200 3: 1200 4: 1200 bogomips: 19999
Type: l1tf
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell Latitude E7470
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-2:3 chip-ID: 0bda:5686 class-ID: 0e02 serial: <filter>
Device-3: Microsoft Microsoft LifeCam Cinema type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-4.1:7 chip-ID: 045e:0812
class-ID: 0102
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.9x11.2")
s-diag: 1052mm (41.4")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 157
size: 310x170mm (12.2x6.7") diag: 354mm (13.9")
Monitor-2: HDMI1 res: 1920x1080 hz: 60 dpi: 92
size: 530x300mm (20.9x11.8") diag: 609mm (24")
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell Latitude E7470
Device-2: Logitech G935 Gaming Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-3:4 chip-ID: 046d:0a87
class-ID: 0102
Sound Server-1: ALSA v: k5.16.3-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.44 running: yes
Device-1: Intel Ethernet I219-LM vendor: Dell Latitude E7470 driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:156f class-ID: 0200
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel bus-ID: 01:00.0
chip-ID: 8086:24f3 class-ID: 0280
bus-ID: 1-8:8 chip-ID: 8087:0a2b class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 5 state: up address: <filter>
v: 3.0 port: f060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A
class-ID: 0104
Local Storage: total: 465.76 GiB used: 19.71 GiB (4.2%)
model: WDS500G2B0B-00YS70 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 00WD
scheme: MBR
ID-1: / raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
used: 19.71 GiB (4.2%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-3: /var/log raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-4: /var/tmp raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.3 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 59.0 C pch: 51.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 236 Uptime: 5h 20m wakeups: 42 Memory: 15.3 GiB
used: 4.93 GiB (32.2%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1447 lib: 423 Shell: fish
Garuda (2.5.3-1):
System install date:     2022-01-30
Last full system update: 2022-01-31
Again.
Hello.
From your previous thread, Monitor not working after running xrandr
Do the DE's display settings not help here?
BTW, define your "future"
To be fair, he didn't say when in the future... :joy:
no, nothing of what i have tried worked, but i can always give it another look ig, also the colour is off before i run xrandr.
This is just as helpful as the missing issue of garuda-inxi in the first post.
I am quite calm,
it breathes me,
nothing can shake me,
I feel better from day to day.
I am completely calm,
Ive tried the different resolutions, but as the colour is off as well i dont think thats the problem, and i have googled around but xrander is the only "real" solution ive found. What is garuda-inxi?
like this? `viktors@viktor-latitudee7470
.%;888:8898898: ----------------------------
x;XxXB%89b8:b8%b88: OS: Garuda Linux
.8Xxd 8X:. Host: Latitude E7470
.8Xx; 8x:. Kernel: 5.16.3-zen1-1-zen
.tt8x .d x88; Uptime: 5 hours, 10 mins
.@8x8; .db: xx@; Packages: 1447 (pacman)
,tSXX° .bbbbbbbbbbbbbbbbbbbB8x@; Shell: bash
.SXxx bBBBBBBBBBBBBBBBBBBBbSBX8; DE: Plasma 5.23.5
,888S pd! WM: KWin
8X88/ q WM Theme: Sweet-Dark
GBB. Terminal: konsole
x%88 d888@8@X@X@X88X@@XX@@X@8@X. CPU: Intel i5-6300U (4) @ 3.0GHz
dxXd dB8b8b8B8B08bB88b998888b88x. GPU: Intel Skylake GT2 [HD Graphics 520]
dxx8o .@@;. Memory: 4.91GiB / 15.30GiB
dx88 .t@x.
d:SS@8ba89aa67a853Sxxad.
.d988999889889899dd.
viktors@viktor in ~
λ xrandr --output eDP1 --auto
viktors@viktor in ~ took 4ms
λ xrandr --output HDMI1 --auto
viktors@viktor in ~ took 59ms
viktors@viktor in ~ took 68ms
λ`?
or should it be the output from garuda -inix?
No, this is taken from the terminal on the right when you open it (neofetch).
You should type garuda-inxi and copy the result here, with
before and after that text block.
its on the post now :slight_smile:
Maybe you could start from here and create a proper /etc/X11/xorg.conf.d/10-monitor.conf based on the suggestions here:
https://wiki.archlinux.org/title/Xrandr#Permanently_adding_undetected_resolutions
It is going to be a little challenging, but it could be a good learning exercise…
PS: I took the freedom to format your inxi as suggested above with ~~~
:slight_smile:
i tried going to the folder and right click create new, but i cant click it, and after googleing how to create a folder from the terminal i found the touch command, however it gives me this error touch: cannot touch '10-monitor.conf': Permission denied
sudo micro /etc/X11/xorg.conf.d/10-monitor.conf
If needed check how to use micro here
is there a good way to see what options my monitor is using?
Maybe
xrandr -q
could help...
Read also that wiki page in general, and maybe also
https://wiki.archlinux.org/title/Multihead
i've read the article and watched a yt tutorial on how to do it, I made a conf file which sets the resolution to 1920x1080, but this isnt fixing it, the colour is still off and its a bit zoomed in, is there any command/tool which i could use to automatically create a conf file from my current xrandr settings?
As far as I can say, as an alternative approach, you could consider using Autostart in the System Settings and add an application launching xrandr --output eDP1 --auto.
The same you could do with a login script or a systemd service.
i guess, but that would still make the login screen have the bad settings? I'll try to look into it more tomorrow and if u cant find how to do it from the conf file i guess ill have to resort to this
For this, you should check this
which you could use also for your xrandr --output eDP1 --auto if necessary… but probably is already handled there.
