my monitor shows up as Unknown-1 in system settings. it was fine before i restarted my pc. now its named that an it wont allow me to change my refresh rate to 144hz. its stuck at 60 an wont let me select anything else. if anyone has ha this issue before please feel free to help. if there is anyway i can sen someone any form of error logs etc please let me know what an how to do that exactly
Please provide your garuda-inxi, as required by the template.
Did this happen after an update?
If so, you could try restoring the latest working snapshot.
can you show me where to exactly find the ini? im new to linux so idk where to look. well it happened after i restarted my pc. i believe i did update something but i am unsure as to what is was.
Open a terminal, tyoe garuda-inxi, copy the result and paste it here, between
Text
You can also find your garuda-inxi in the Garuda Assistant, system specs.
╭─sicko@sicko in ~
╰─λ garuda-inxi
root=UUID=51a0f4b8-1148-4165-9b1e-99707b3be8d2 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Type: Desktop Mobo: ASUSTeK model: TUF Z390M-PRO GAMING (WI-FI) v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2417
date: 06/03/2019
Info: model: Intel Core i7-9700K bits: 64 type: MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xD (13) microcode: 0xFA
Topology: cpus: 1x cores: 8 smt: <unsupported> cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 800 min/max: 800/5000 scaling: driver: intel_pstate
8: 800 bogomips: 57600
Device-1: NVIDIA TU104 [GeForce RTX 2070 SUPER] vendor: ZOTAC driver: nvidia
v: 545.29.02 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
(as of 2023-10; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 10de:1e84 class-ID: 0300
compositor: kwin_wayland driver: X: loaded: modesetting,nouveau,nvidia
alternate: fbdev,nv,vesa gpu: nvidia display-ID: 0
Monitor-1: Unknown-1 res: 1920x1080 size: N/A modes: N/A
drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: swrast
x11: drv: swrast inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: llvmpipe (LLVM 16.0.6 256 bits)
device-ID: ffffffff:ffffffff memory: 15.17 GiB unified: yes
display-ID: :1.0
API: Vulkan v: 1.3.269 layers: 8 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 2070 SUPER driver: nvidia v: 545.29.02 device-ID: 10de:1e84
surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe (LLVM 16.0.6 256
bits) driver: mesa llvmpipe v: 23.2.1-arch1.2 (LLVM 16.0.6)
Device-2: NVIDIA TU104 HD Audio vendor: ZOTAC driver: snd_hda_intel
Server-1: PipeWire v: 0.3.84 status: active with: 1: pipewire-pulse
Device-2: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
IF: eno2 state: up speed: 1000 Mbps duplex: full mac: <filter>
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:4
lmp-v: 10 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 4.2 TiB used: 219.53 GiB (5.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT500P1SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P3CR013 temp: 36.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC43 scheme: GPT
model: WD30EZRX-00MMMB0 size: 2.73 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: 0A80
scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: Corsair model: Force GT
tech: SSD serial: <filter> fw-rev: 5.02 scheme: MBR
used: 11.6 GiB (2.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 45.0 C mobo: N/A
Processes: 242 Uptime: 42m wakeups: 0 Memory: total: 16 GiB
available: 15.54 GiB used: 2.79 GiB (18.0%) Init: systemd v: 254
pm: pacman pkgs: 1470 libs: 479 tools: octopi,paru Shell: fish v: 3.6.1
Garuda (2.6.17-1):
System install date: 2023-11-05
Last full system update: 2023-11-05 ↻
so i dont think i have snapshot set up or does it come set up out of the box?
They are included by default, you can select them from the GRUB.
This means that a reboot is pending
You never can say…
Try also logging in an x11 session.
i did this and now it works fine i appreciate your help. two more questions do i just login into an x11 session from now on everytime i boot up my pc? or do i go back to wayland. and how do i avoid this issue in the future?
You’d better keep on using x11 for a while (the last mode used should be offered by default). It smells like a bug in the Wayland world, so I think efforts to make it work might be too big…
You could try again in a while after updates.
To be precise, you should open a bug report, probably at KDE, but chances are this has already been notified or will be soon.
Next time you try with Wayland, remember adding this kernel boot parameter:
alright then looks like i will stay on x11 for a while while i learn this os. thanks again for your help
