eshan
9 June 2021 07:53
1
All issues related to Garuda Linux and its assistance
when i try to install package it is saying missing package and invalid and corrupted file
error: missing package metadata in /home/eshan/Downloads/sendanywhere_latest_amd64.deb
error: '/home/eshan/Downloads/sendanywhere_latest_amd64.deb': invalid or corrupted package
Pls help me it's urgent
First of all welcome to the forum
If its really that urgent you should do some research yourself - Garuda Linux is based on Arch Linux which means .deb files cant be installed, they are not compatible also what command did you use?
eshan
9 June 2021 08:36
4
and my add/remove program is also not opening
Hi @eshan , please run the below on a terminal:
paru -S sendanywhere
And proceed with all the default options
eshan
9 June 2021 08:46
6
shivanandvp:
/home/eshan/.cache/paru/clone/electron8-bin/.gitignore
*.tar
.tar.
*.rpm
*.jar
*.exe
*.msi
*.zip
*.tgz
*.log
.log.
*.sig
it stopped here
Can you send a screenshot screenshot instead? I have a feeling that I don't have the full information of what's going on on your computer...
eshan
9 June 2021 08:54
9
When i try to post it website will say new user cannot upload image
i have copied the whole terminal and pasted it right here:
╭─eshan@Eshan in ~
╰─λ paru -S sendanywhere
:: Resolving dependencies...
:: Calculating conflicts...
:: Calculating inner conflicts...
Repo Make (2) nodejs-16.3.0-1 asar-3.0.3-1
Aur (2) electron8-bin-1:8.5.5-3 sendanywhere-21.4.2-1
:: Proceed to review? [Y/n]: y
:: Downloading PKGBUILDs...
PKGBUILDs up to date
/home/eshan/.cache/paru/clone/electron8-bin/.editorconfig
root = true
charset = utf-8
end_of_line = lf
insert_final_newline = true
indent_style = tab
tab_width = 4
# from https://github.com/github/gitignore/blob/master/ArchLinuxPackages.gitignore
*.tar
*.tar.*
*.rpm
*.jar
*.exe
*.msi
*.zip
*.tgz
*.log
*.log.*
*.sig
@eshan Okay. Rerun the paru command I posted above and this time there is no need to review PKGBUILD, and no need to review any diff. Skip those by typing n and pressing enter . In fact skip reviewing or viewing anything as it will take you somewhere else instead of proceeding to install.
eshan
9 June 2021 08:59
12
when i type n it will end process
╭─eshan@Eshan in ~
:: Proceed to review? [Y/n]: n
╭─eshan@Eshan in ~ took 7s
eshan
9 June 2021 09:02
15
╭─eshan@Eshan in ~
@eshan Okay
paru -S sendanywhere --skipreview
This should do it.
@eshan To make the terminal outputs readable follow this guide .
eshan
9 June 2021 09:09
18
Thank You! Bro You Are Great
My add / remove program is not opening pls tell me something if you can
@eshan Already answered it on your forum post .
It's better if OP search and find the answer before someone moves this thread to 4xx error
system
Closed
11 June 2021 09:18
21
