Min, max, close buttons disappeared / solved
Hello,
After my last installation I cannot find anymore a normal feature to restore the windows opened in a normal state (between
maximized and minimized), after they were maximized.
Is there a shortcut to restore a window in a way to see the 3 buttons (min, max, close)?
Thanks for concrete help!
Kernel: 6.10.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=48ce8f28-090a-41e6-b029-236d9c4692ba rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.6.0
Type: Laptop System: LENOVO product: 82RN v: IdeaPad 3 15ABA7
serial: <superuser required> Chassis: type: 10 v: IdeaPad 3 15ABA7
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
part-nu: LENOVO_MT_82RN_BU_idea_FM_IdeaPad 3 15ABA7
uuid: <superuser required> UEFI: LENOVO v: JTCN42WW date: 01/10/2023
ID-1: BAT0 charge: 30.7 Wh (79.3%) condition: 38.7/38.0 Wh (101.9%)
volts: 8.0 min: 7.7 model: LGC L20L2PF0 type: Li-poly serial: <filter>
status: not charging cycles: 90
Info: model: AMD Ryzen 5 5625U with Radeon Graphics bits: 64 type: MT MCP
microcode: 0xA50000C
desc: 6x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 400 min/max: 400/4388 scaling: driver: amd-pstate-epp
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
8: 400 9: 400 10: 400 11: 400 12: 400 bogomips: 55099
Device-1: Advanced Micro Devices [AMD/ATI] Barcelo vendor: Lenovo
built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 04:00.0
chip-ID: 1002:15e7 class-ID: 0300 temp: 37.0 C
Device-2: IMC Networks Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 13d3:56ff
class-ID: 0e02
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.3-arch1.1
renoir LLVM 18.1.8 DRM 3.57 6.10.10-zen1-1-zen) device-ID: 1002:15e7
API: Vulkan v: 1.3.295 layers: 3 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.2.3-arch1.1
device-ID: 1002:15e7 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.2.3-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
Audio vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1
vendor: Lenovo driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
snd_sof_amd_acp63 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6
API: ALSA v: k6.10.10-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:c822
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:3 chip-ID: 0bda:c123
Report: btmgmt ID: hci0 rfk-id: 8 state: up address: <filter> bt-v: 5.1
Local Storage: total: 476.94 GiB used: 162.97 GiB (34.2%)
model: MZAL4512HBLU-00BL2 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 7L1QHXC7 temp: 26.9 C scheme: GPT
ID-1: / raw-size: 248.92 GiB size: 248.92 GiB (100.00%)
used: 118.64 GiB (47.7%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
used: 78.6 MiB (81.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 248.92 GiB size: 248.92 GiB (100.00%)
ID-4: /var/log raw-size: 248.92 GiB size: 248.92 GiB (100.00%)
ID-5: /var/tmp raw-size: 248.92 GiB size: 248.92 GiB (100.00%)
ID-1: swap-1 type: zram size: 13.5 GiB used: 719.5 MiB (5.2%)
System Temperatures: cpu: 45.4 C mobo: N/A gpu: amdgpu temp: 38.0 C
Memory: total: 16 GiB note: est. available: 13.5 GiB used: 4.67 GiB (34.6%)
Processes: 333 Power: uptime: 3d 6h 36m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 5 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 5.39 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1553 libs: 456
tools: gnome-software,octopi,paru pm: flatpak pkgs: 0 Compilers: gcc: 14.2.1
Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole inxi: 3.3.36
System install date:     2024-08-31
Last full system update: 2024-09-28 ↻
I am sure it’s explained more than one time in the forum.
Search for kwinrc.
↻ means reboot is needed in KDE
Looks like you’ve done some editing in the panel (looks like a spacer or two was either removed or moved?).
I would double check to make sure the Window Buttons applet is still there while you are in edit mode, and that the settings for it are how you want it (right click the window buttons edit mode and then Configure). Could try having the setting as always visible for the buttons to make sure it is working on its side.
It is a bit weird that there is a gap there where the buttons should be; it shouldn’t be taking space if the buttons aren’t visible. I’m pretty sure it doesn’t preserve this space by default as it is set up in the Garuda Default Top Panel. I would restart just in case as @sgs suggested.
If none of that helps and the buttons aren’t even showing while they are even set to always visible, you might want to try a fresh default panel. In edit mode, click the +Add Panel button and select the Garuda Default Top Panel.
edit: thought it was preserving space at first; was really hard to see in the picture, but there was just two buttons there (I can see why you added text to that picture now lol).
edit 2:
It looks like it a different button theme too… there could be some kind of buttons that don’t play nice with the applet maybe? Either way, try a Garuda Default Top Panel to troubleshoot.
Thanks all
 nano ~/.config/kwinrc
[Windows]
BorderlessMaximizedWindows=false
reboot
thumb up
