Microphone Volume Automatically Gets Down
Same as Microphone volume/boosts resets automatically.
My mic volume automatically goes from 60% to 50% gradually each time I speak loud, it’s so annoying because I’ve been in meetings and I have to raise the volume each 10-15 seconds because it always goes down and reaches like 10%. I haven’t enabled anything like auto-adjust mic volume (Garuda doesn’t integrate it into settings), so if you could help me, would be so useful
sudo garuda-inxi:
Kernel: 6.10.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=110bfeb9-8982-41d5-8228-1e349f3e6005 rw rootflags=subvol=@
quiet loglevel=3 psi=1 ibt=off
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A wm: kwin_wayland with: krunner
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop M1603QA_M1603QA
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: M1603QA v: 1.0 serial: <filter>
uuid: 16acb14b-55ba-634d-8173-e24aba7e118b UEFI: American Megatrends LLC.
v: M1603QA.306 date: 11/21/2022
ID-1: BAT0 charge: 28.8 Wh (63.7%) condition: 45.2/50.0 Wh (90.4%)
power: 12.7 W volts: 11.9 min: 11.9 model: ASUSTeK ASUS Battery type: Li-ion
serial: N/A status: discharging cycles: 147
Info: model: AMD Ryzen 5 5600H with Radeon Graphics socket: FP6 bits: 64
type: MT MCP arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000D
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2802 high: 3370 min/max: 400/4280 base/boost: 3300/4250
scaling: driver: amd-pstate-epp governor: performance volts: 1.2 V
ext-clock: 100 MHz cores: 1: 3278 2: 3270 3: 3259 4: 400 5: 3263 6: 400
7: 3265 8: 3269 9: 3268 10: 3319 11: 3370 12: 3266 bogomips: 79055
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 03:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 46.0 C
Device-2: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:3 chip-ID: 13d3:5463
Display: unspecified server: X.Org v: 24.1.2 with: Xwayland v: 24.1.2
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x318mm (20.00x12.52")
s-diag: 599mm (23.6")
Monitor-1: eDP-1 model: AU Optronics 0x459d built: 2022 res: 1920x1200
hz: 60 dpi: 142 gamma: 1.2 size: 344x215mm (13.54x8.46") diag: 406mm (16")
ratio: 16:10 modes: max: 1920x1200 min: 640x480
device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.2-arch1.1
renoir LLVM 18.1.8 DRM 3.57 6.10.10-zen1-1-zen) device-ID: 1002:1638
memory: 500 MiB unified: no
API: Vulkan v: 1.3.295 layers: 3 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.2.2-arch1.1
device-ID: 1002:1638 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.2-arch1.1 (LLVM
speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
snd_sof_amd_acp63 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.10.10-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.3 status: n/a (root, process) with:
Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
lanes: 1 bus-ID: 01:00.0 chip-ID: 14c3:7961 class-ID: 0280
Info: services: httpd, NetworkManager, nginx, wpa_supplicant
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:2 chip-ID: 13d3:3563
Local Storage: total: 476.94 GiB used: 49.84 GiB (10.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNU512GZ
lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 29.9 C scheme: GPT
SMART: yes health: PASSED on: 34d 0h cycles: 984
read-units: 11,920,092 [6.10 TB] written-units: 10,629,396 [5.44 TB]
ID-1: / raw-size: 117.56 GiB size: 117.56 GiB (100.00%)
used: 40.84 GiB (34.7%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p5
maj-min: 259:5
used: 25.8 MiB (26.9%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 117.56 GiB size: 117.56 GiB (100.00%)
maj-min: 259:5
ID-4: /var/log raw-size: 117.56 GiB size: 117.56 GiB (100.00%)
maj-min: 259:5
ID-5: /var/tmp raw-size: 117.56 GiB size: 117.56 GiB (100.00%)
maj-min: 259:5
ID-1: swap-1 type: zram size: 15.03 GiB used: 512 KiB (0.0%) priority: 100
System Temperatures: cpu: 56.1 C mobo: 48.0 C gpu: amdgpu temp: 45.0 C
Fan Speeds (rpm): cpu: 2100
Memory: total: 16 GiB note: est. available: 15.03 GiB used: 7.88 GiB (52.4%)
Processes: 364 Power: uptime: 3h 53m states: freeze,mem,disk
suspend: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 6 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1679 libs: 430 tools: pamac,paru Compilers:
gcc: 14.2.1 Shell: garuda-inxi (sudo) default: Bash v: 5.2.32
System install date:     2024-05-14
Last full system update: 2024-09-16
Relevant software:       snapper NetworkManager dracut grub-customizer
Windows dual boot:       Yes
