Kernel: 5.10.6-110-tkg-bmq x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=bee10af5-3ab4-49ca-9fc2-4d268b2852d1 rw rootflags=subvol=@ quiet
Desktop: LXQt 0.16.1 tk: Qt 5.15.2 info: lxqt-panel wm: kwin_x11 dm: SDDM
Distro: Garuda Linux
Type: Desktop System: MotherBoard By ZOTAC product: MotherBoard H61MAT-C-E
v: MotherBoard 00 serial: <filter> Chassis: NA type: 3 v: NA serial: <filter>
Mobo: ZOTAC model: H61MAT-C-E v: 00 serial: <filter> UEFI: American Megatrends
v: 4.6.5 date: 03/08/2012
^[[B^[[B^[[BCPU:
Info: Dual Core model: Intel Pentium G630 bits: 64 type: MCP arch: Sandy Bridge
family: 6 model-id: 2A (42) stepping: 7 microcode: 2F L2 cache: 3 MiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 10787
Speed: 1762 MHz min/max: 1600/2700 MHz Core speeds (MHz): 1: 1762 2: 1785
IBRS_FW, STIBP: disabled, RSB filling
vendor: ZOTAC driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0102
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: intel
unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
s-diag: 414mm (16.3")
Monitor-1: VGA1 res: 1366x768 hz: 60 dpi: 85 size: 410x230mm (16.1x9.1")
diag: 470mm (18.5")
OpenGL: renderer: Mesa DRI Intel HD Graphics 2000 (SNB GT1) v: 3.3 Mesa 20.3.2
compat-v: 3.0 direct render: Yes
Device-1: Intel 6 Series/C200 Series Family High Definition Audio vendor: ZOTAC
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1c20
Sound Server: ALSA v: k5.10.6-110-tkg-bmq
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: ZOTAC
driver: r8169 v: kernel port: e000 bus ID: 02:00.0 chip ID: 10ec:8136
IF-ID-1: usb0 state: unknown speed: N/A duplex: N/A mac: <filter>
Local Storage: total: 931.51 GiB used: 15.18 GiB (1.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZEX-21WN4A0
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
serial: <filter> rev: 1A01
ID-1: / raw size: 931.22 GiB size: 931.22 GiB (100.00%) used: 15.18 GiB (1.6%)
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%) used: 560 KiB (0.2%)
fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw size: 931.22 GiB size: 931.22 GiB (100.00%)
used: 15.18 GiB (1.6%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw size: 931.22 GiB size: 931.22 GiB (100.00%)
ID-5: /var/tmp raw size: 931.22 GiB size: 931.22 GiB (100.00%)
ID-1: swap-1 type: zram size: 904.3 MiB used: 234.7 MiB (26.0%) priority: 32767
ID-2: swap-2 type: zram size: 904.3 MiB used: 232.3 MiB (25.7%) priority: 32767
dev: /dev/zram1
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Processes: 193 Uptime: 29m wakeups: 0 Memory: 1.77 GiB used: 1.62 GiB (91.9%)
Init: systemd v: 247 Compilers: gcc: 10.2.0 clang: 11.0.1 Packages:
pacman: 1188 lib: 313 Shell: Zsh v: 5.8 running in: qterminal inxi: 3.2.01
9 posts were merged into an existing topic: Audio not working in lxqt garuda
