Hello Brothers hope you well. I am writing this post because currently i am running into a problem and that is microphone not working. I guess it happened due to the kernel update. I did perform an update yesterday. I saw that linux-zen package is updating. After that update i fall into this problem. As a newbie i read other post on this forum i did not understand those fixes. I am using pulseaudio as my sound driver in my Dragonized edition. So i check though pulseaudio volume control and no input device there. Sound is working fine but microphone did not work. Also just to let you know that there is not configaration file under etc/modprobe.d/. I added some screenshot clearence. I request you to please help me to fix this problem.
Post your terminal/konsole in- and output as text (nopictures) from:
inxi -Faz
I see many people are using PulseAudio and Pipewire together, so there must be a solution.
Personally, I moved to pipewire only. But you should make sure that at least pipewire-pulse is installed for the complete replacement.
I’m copying below a couple of references for using pipewire, but you can search in the forum (I’m not an audio expert, a normal set-up of audio with internal and an external wired headset with microphone works for me).
I faced a different problem with pipewire which is if I switch different audio output devices such as my headphone to external device then it not switching the sound to my external audio speaker. That's why i switched pulseaudio. It solved my problem completely. So what can i do now. Any recommendation?
I don't want to force you to test something that maybe breaks your setup
Maybe those two suggestions above (pipewire-pulse and pavucontrol) could really help (unless you already used them in the past).
If you feel confident with testing the new set-up (an if necessary maybe restore a snapshot) maybe you could give it a try. Otherwise, just wait for someone more experienced than me
