Hi all,
I’ve updated a few times in the past week or so, and in that time some Windows games that I’ve been playing through Proton have suddenly started crashing. I’ve tried using different compatibility settings: Glorious Eggroll, Proton Experimental, etc; none of that seems to have helped. Running Steam from the terminal I can see the following error:
wine: using kernel write watches, use_kernel_writewatch 1.
Setting breakpad minidump AppID = 614570
Steam_SetMinidumpSteamID: Caching Steam ID: 76561198013843861 [API loaded no]
Fossilize INFO: Overriding serialization path: "/home/kestrel/.local/share/Steam/steamapps/shadercache/614570/fozpipelinesv6/steamapprun_pipeline_cache".
amdgpu_device_initialize: DRM version is 1.6.0 but this driver is only compatible with 3.x.x.
wine: setpriority 4 for pid -1 failed: 3
That makes me think something’s up with the AMD driver, but I’m not sure where to go from there. Any help is appreciated. In case it’s relevant, the two games I’ve seen this on so far are Guild Wars 2 and Dishonored: Death of the Outsider.
Here’s the garuda-inxi:
╭─kestrel@gurgeh in ~
╰─λ garuda-inxi
Kernel: 6.8.9-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=0fed58b0-5df8-4f4e-bb81-6c319af09561 rw rootflags=subvol=@
wm: kwin_x11 with: krunner vt: 2 dm: SDDM Distro: Garuda base: Arch Linux
Type: Desktop Mobo: Gigabyte model: Z790 UD AC v: x.x
Megatrends LLC. v: F3k date: 01/05/2023
Info: model: 13th Gen Intel Core i9-13900K bits: 64 type: MST AMCP
microcode: 0x122
Topology: cpus: 1x cores: 24 mt: 8 tpc: 2 st: 16 threads: 32 smt: enabled
cache: L1: 2.1 MiB desc: d-16x32 KiB, 8x48 KiB; i-8x32 KiB, 16x64 KiB
L2: 32 MiB desc: 8x2 MiB, 4x4 MiB L3: 36 MiB desc: 1x36 MiB
Speed (MHz): avg: 1860 high: 5536 min/max: 800/5500:5800:4300 scaling:
driver: intel_pstate governor: performance cores: 1: 800 2: 5500 3: 800
4: 800 5: 5500 6: 800 7: 5500 8: 800 9: 5500 10: 5500 11: 800 12: 5536
13: 800 14: 800 15: 2984 16: 800 17: 800 18: 800 19: 4300 20: 800 21: 800
22: 800 23: 800 24: 800 25: 800 26: 800 27: 800 28: 800 29: 800 30: 800
31: 800 32: 800 bogomips: 191692
Device-1: Intel Raptor Lake-S GT1 [UHD Graphics 770] vendor: Gigabyte
driver: i915 v: kernel alternate: xe arch: Gen-13 process: Intel 7 (10nm)
built: 2022+ ports: active: none empty: DP-1,HDMI-A-1,HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:a780 class-ID: 0300
Device-2: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX/7900M] driver: amdgpu
v: kernel arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm) built: 2022+
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-4,HDMI-A-3
empty: DP-2,DP-3,Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:744c
Device-3: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6.1.3:13
chip-ID: 046d:0892 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 23.2.6
compositor: kwin_x11 driver: X: loaded: amdgpu,modesetting unloaded: radeon
alternate: fbdev,intel,vesa dri: radeonsi,iris gpu: amdgpu display-ID: :0
Screen-1: 0 s-res: 4920x2160 s-dpi: 96 s-size: 1300x571mm (51.18x22.48")
s-diag: 1420mm (55.9")
Monitor-1: DP-4 mapped: DisplayPort-3 pos: primary,left
model: Acer XB273K GP serial: <filter> built: 2020 res: 3840x2160 dpi: 163
gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
modes: max: 3840x2160 min: 640x480
Monitor-2: HDMI-A-3 mapped: HDMI-A-2 pos: right model: VG245
serial: <filter> built: 2020 res: 1080x1920 hz: 60 dpi: 92 gamma: 1.2
size: 299x531mm (11.77x20.91") diag: 609mm (24") ratio: 16:9 modes:
API: EGL v: 1.5 hw: drv: intel iris drv: amd radeonsi platforms: device: 0
drv: iris device: 1 drv: radeonsi device: 2 drv: swrast surfaceless:
drv: iris x11: drv: radeonsi inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.6-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7900 XT (radeonsi
navi31 LLVM 17.0.6 DRM 3.57 6.8.9-zen1-2-zen) device-ID: 1002:744c
memory: 19.53 GiB unified: no
API: Vulkan v: 1.3.279 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XT (RADV NAVI31) driver: mesa radv v: 24.0.6-arch1.2
device-ID: 1002:744c surfaces: xcb,xlib device: 1 type: integrated-gpu
name: Intel Graphics (RPL-S) driver: mesa intel v: 24.0.6-arch1.2
device-ID: 8086:a780 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.6-arch1.2 (LLVM
Device-1: Intel Raptor Lake High Definition Audio vendor: Gigabyte
Device-2: AMD Navi 31 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
Device-3: SteelSeries ApS Arctis 7
lanes: 1 mode: 1.1 bus-ID: 1-5:3 chip-ID: 1038:12ad class-ID: 0300
Device-4: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.8.9-zen1-2-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.6 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtw_8821ce v: N/A modules: rtw88_8821ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 06:00.0
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 07:00.0
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:14
chip-ID: 13d3:3533 class-ID: e001 serial: <filter>
Local Storage: total: 9.08 TiB used: 3.41 TiB (37.6%)
model: WD BLACK SN850X 2000GB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 620281WD temp: 52.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWR460 size: 5.46 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: HDD
rpm: 7200 serial: <filter> fw-rev: 0601 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1500DL003-9VT16L
size: 1.36 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5900 serial: <filter> fw-rev: CC3C scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: Intel model: SSDSC2BP480G4
tech: SSD serial: <filter> fw-rev: 0420 scheme: GPT
ID-1: / raw-size: 60 GiB size: 60 GiB (100.00%) used: 27.56 GiB (45.9%)
used: 584 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 1.76 TiB size: 1.76 TiB (100.00%)
used: 1.3 TiB (74.0%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-4: /var/log raw-size: 60 GiB size: 60 GiB (100.00%)
used: 27.56 GiB (45.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-5: /var/tmp raw-size: 60 GiB size: 60 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.11 GiB used: 803 MiB (2.5%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 32 dev: /dev/zram0
System Temperatures: cpu: 50.0 C mobo: 37.0 C gpu: amdgpu temp: 45.0 C
mem: 62.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 502
Memory: total: 32 GiB note: est. available: 31.11 GiB
used: 11.08 GiB (35.6%)
Processes: 565 Power: uptime: 8h 26m states: freeze,mem,disk suspend: deep
Packages: pm: pacman pkgs: 2055 libs: 582 tools: octopi,paru Compilers:
clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi default: Bash v: 5.2.26
System install date: 2023-08-26
Last full system update: 2024-05-11 ↻
Thanks in advance for any insights!
Edit: I’ve also tried both Wayland and X11.
