As per How does Garuda use bash but the shell is fish?
Garuda leaves the default $SHELL to bash for compat reasons and only has kterm select fish
but this leaves $SHELL reporting bash, which when in kterm/fish is incorrect, which I discovered when setting up keychain
, which when given the --eval
arg returns shell appropriate commands to feed into source
. under this setup I kept getting invalid bash commands.
The solution was simple, drop set -x SHELL /usr/bin/fish
at the top of my .fish_profile
So just here to suggest it might be a good idea to incorporate that into garuda's generated ~/.config/fish/config.fish
Thanks
