Garuda mix by Sway Sway
I will start a new topic for this I promise but I'm just wondering about a few things we need.
- So I need to create the config's and and store them in like you do for wayfire and i3. So under etc/skel for stuff that would normally be under ~/.config and usr ~~ for anything I need there.
- Then I need to turn that into a PGKBUILD so it be in the repo.
- Then I need to create an iso-profile - with Packages-Desktop and profile.conf.
- Now I'm slightly confused so I need to add anything to Garuda-Tools? or LiveCD?
I read this instruction above...
- install garuda-tools-iso-git
sudo pacman -S garuda-tools-iso-git
- git clone the iso-profiles
git clone https://gitlab.com/garuda-linux/tools/iso-profiles.git
- build the iso using following command
buildiso -f -p sway
Will this built the iso? Or do I need to change anything more?
Other than that I think I will start a new topic a few hours to now to see what the community will like with theming etc;!
Thank you!
just an idea, I have a 64GB USB drive, but I think the max is around 4GB , I used rufus 3.17 to burn iso images for booting and installing to this drive, when I am not storing my data on it, it burns it using the DD method, in any case, I have downloaded the gaming edition of garuda and the wayfire edition too to check them out, but my drive or I could download bigger images in case in the future garuda makes them with more in them otherwise it's a great OS.
also, if I recall there are some distros of Linux that have in the desktop environments the correct sound drivers, but you can't change them to 5.1 or 7.1 they only include the stereo 2.0 option, which bugs me since I do need the 5.1 option for my sound system with subwoofer option is also missing in a few distros that I tried based on a few different desktop environments. but also related to garuda desktop environments, some of them may have limited support for the sound driver maybe. also garuda wayfire will not work with the NVidia drivers I tried, only working is open source NVidia drivers, also its installer was missing when I tried garuda-wayfire-linux-zen-211129.iso 2.29GB in size. I downloaded it with free download manager and used mirror options I think but used sources garuda had for it I think, that the one that I had also added mirror download links to it if that caused the problem with the installer was missing from wayfire.edited my post to make it more clear, also gnome iso is working correctly besides the kde one for garuda but I can't say for sure the rest of them are working correctly on my system.
I like cinnamon environments, kde, gnome, deepin and Pantheon
also like cinnamon and mate, and wayfire and xfce
I tried Pantheon in other linux distro, I have yet to try it in garuda linux, any idea if its stable on arch. anyway, once I have time, I try to install it. on garuda gaming.
from my understanding of deepin that not stable in arch but only like ubuntu.
Pantheon - ArchWiki (archlinux.org)
How to Install Pantheon Desktop in Arch Linux (Elementary OS's desktop) (debugpoint.com)
garuda could use a livedvd or iso of Pantheon as one of its Desktop environments in the future, I think its a liked desktop anyway like budgie too.
Budgie - ArchWiki (archlinux.org)
which is another desktop environment that could be put into an garuda livedvd iso image. I don't think this one is yet created for the desktop systems, can be installed but not included as a offical livedvd like the above one I am written about here.
Hello, you are very welcome
We have no shortage of ideas on what else to install as a Garuda Linux desktop environment.
But there is a lack of maintainers.
From first post.
"If anyone wants to take the part in ISO creation, they are welcome."
A post was split to a new topic: In any case I know it's a bit off topic
A post was split to a new topic: Eayfire problem
Since you enjoy links: ![]()
https://wiki.archlinux.org/title/PulseAudio/Examples#Surround_sound_systems
