Hi all,
This installation finished without giving me a desktop. I do have the bottom icons and the Garuda Assistant etc but not anything else. There's no application menu and a left or right mouse click doesn't show anything. I would have given you the info from "garuda-inxi" but I can't find how to get into the terminal. Perhaps there's a keyboard shortcut? Anyway, I'm assuming that is a starting point. Thaks in advance.
Richard
Is there a wallpaper?
What are you expecting the desktop to be?
I think Alt+F1 or F2 should open the launcher (I'm not in front of my computer to double-check that).
Try Ctrl+Alt+T, Meta+Enter, or Meta+T.
Thanks for the keyboard shortcut. I couldnt get the terminal up directly but managed to access the search function for the application menu. It looks like someone had the same problem 20 days ago and it probably describes my situation better than my post. My screen is black only with the cairo dock. My intention - no intention - just did the installation and hoping to customize once all is loaded. I did nothing special with the installation - just followed the prompts. I had to choose the open source drivers at the installation prompt as proprietary ones just stall the system. Here is the garuda-inxi:
Kernel: 6.2.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=4845379e-865e-43ee-970f-bb199a8a64fb rw [email protected]
Desktop: KDE Plasma v: 5.27.3 tk: Qt v: 5.15.8 info: cairo-dock
Type: Desktop System: ASUS product: All Series v: N/A
Mobo: ASUSTeK model: B85M-G v: Rev X.0x serial: <superuser required>
UEFI: American Megatrends v: 0501 date: 07/31/2013
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
Info: model: Intel Core i3-4130 bits: 64 type: MT MCP arch: Haswell
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 798 high: 800 min/max: 800/3400 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 798 2: 798 3: 799 4: 800
bogomips: 27140
Device-1: NVIDIA GF116 [GeForce GTX 550 Ti] vendor: eVga.com.
driver: nouveau v: kernel non-free: series: 390.xx+ status: legacy-active
(EOL~late 2022) arch: Fermi code: GF1xx process: 40/28nm built: 2010-16
pcie: gen: 1 speed: 2.5 GT/s lanes: 16 ports: active: DVI-I-1
empty: DVI-I-2,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1244 class-ID: 0300
temp: 43.0 C
compositor: kwin_x11 driver: X: loaded: nouveau unloaded: modesetting
alternate: fbdev,nv,vesa dri: nouveau gpu: nouveau display-ID: :0
Monitor-1: DVI-I-1 model: Sony TV serial: <filter> built: 2009
res: 1920x1080 hz: 60 dpi: 30 gamma: 1.2 size: 1600x900mm (62.99x35.43")
diag: 1836mm (72.3") ratio: 16:9 modes: max: 1920x1080 min: 640x480
missing.
Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
Device-2: NVIDIA GF116 High Definition Audio vendor: eVga.com.
bus-ID: 01:00.1 chip-ID: 10de:0bee class-ID: 0403
Sound API: ALSA v: k6.2.7-zen1-1-zen running: yes
vendor: ASUSTeK H81M-C driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
Device-2: Linksys AE3000 802.11abgn (3x3) Wireless Adapter [Ralink RT3573]
type: USB driver: rt2800usb bus-ID: 3-9:5 chip-ID: 13b1:003b class-ID: 0000
IF: wlp0s20u9 state: up mac: <filter>
Local Storage: total: 991 GiB used: 3.93 GiB (0.4%)
model: WD Blue SA510 2.5 500GB size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: SSD serial: <filter> rev: 0100
model: WD5000AAKX-00ERMA0 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: N/A serial: <filter> rev: 1H15
ID-3: /dev/sdd maj-min: 8:48 type: USB vendor: Lexar
model: SD USB 3 0 Read size: 59.48 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: LX01 scheme: MBR
used: 3.93 GiB (0.8%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 608 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-1: swap-1 type: zram size: 15.56 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 42.0 C mobo: N/A gpu: nouveau temp: 44.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 1380
Processes: 178 Uptime: 1d 20h 35m wakeups: 11 Memory: 15.56 GiB
used: 1.26 GiB (8.1%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1152
libs: 310 tools: octopi,paru Shell: Bash v: 5.1.16 running-in: qterminal
inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2023-05-07
Last full system update: 2023-05-07
Thanks
