lutris doesn’t work anymore now it won’t open
Please
- Describe your issue in detail. The more we know, the better we can help
- Show us the results of your searches, and what you’ve tried
in the body of the post (not linked externally, or collapsed with the “hide details” feature) - Format terminal output (including your
) as a code block by clicking the preformatted text button (</>) , or put three tildes (~) above and below the text
sorry for being a pain but I don`t know what to do what you said to do, its my first time doing that, I am still quite new to linux so I still have a lot to learn
This may still be acceptable in the garage, but we are all not clairvoyant.
But without further details, no one can help.
Have you ever started lutris from the terminal?
If error messages appear there, search for them on the web and if there is nothing there, post the log here, possibly under https://bin.garudalinux.org/
BTW, it works here
ok will do that
ok no problem I guess I need to do more reading and learn more about linux .
ok now I understand the gaurda -inxi
Ok I started lutris from the terminal it give me errors and it says its my windows vista theme is causing conflict.
Ok found the problem it was my windows vista icons option, I went back to the breeze icons and lutris works now.
I am really enjoying wayland now since I got a amd 7900xt I can finally use wayland now. I had a 1080ti before
see, it wasn’t so bad after all, a little reading and trial and error helps in most cases.
and if that doesn’t help, share all the information you’ve gathered so far so that others know what you’ve tried and can then help you
Please,
do not post here in the forum, like in chat forums like Telegram.
As long as no one has responded to your post, you can edit your post.
Ok got it.
When you open a progam from the terminal will it show errors of all progams you open like what happen with lutris with me? I ask so I know what to do next time.
Yes it does, this is the first step finding out what the problem might be. For it will throw up errors, which can then be googled to provide answers, often simple enough for novice users to fix their issues.
Cheers
