I have used Garuda Rani to install Lutris and Bottles. The install scripts are running without errors, but both apps won’t start. Double-clicking on other (installed) apps in Rani is starting them. So what is probably missing? I had some issues with Steam the last couple of weeks (with Debian based distros) and i wanted to try out something new. But first i have to get at least one of the wrappers to work to test some games.
Could you provide your garuda-inxi output? (you might just need to restart but who knows much without seeing it)
bottles has been difficult to maintain outside of the official Flatpak, as the developers keep putting code into it that is pretty Flatpak specific. There are recent comments in the AUR about having trouble running it or doing any configurations:
Also there are recent threads about it like this one: Can't get into Bottles settings
I thought i saw a subcategory, where you can add your inxi output and link to it. Can’t find it anymore. Posting as a codeblock is still awfully huge.
We have close it, an garuda-inxi from yesterday is useless ![]()
Nope, use the preformatted text </>
garuda-inxiin the body of the post (not linked externally, or collapsed with the “hide details” feature)
garuda-inxi) as a code block by clicking the preformatted text button (</>) , or put three tildes (~) above and below the text
Kernel: 6.14.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=5dd8532b-e82d-44fb-811e-1ecae67f4cb6 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.3.4 tk: Qt v: N/A info: frameworks v: 6.12.0
Type: Laptop System: LENOVO product: 82WM v: Legion Pro 5 16ARX8
serial: <superuser required> Chassis: type: 10 v: Legion Pro 5 16ARX8
Mobo: LENOVO model: LNVNB161216 v: SDK0T76461 WIN
serial: <superuser required> part-nu: LENOVO_MT_82WM_BU_idea_FM_Legion Pro
5 16ARX8 uuid: <superuser required> UEFI: LENOVO v: LPCN56WW
date: 11/01/2024
ID-1: BAT0 charge: 41.0 Wh (48.9%) condition: 83.8/80.0 Wh (104.7%)
power: 40.7 W volts: 14.9 min: 15.4 model: Sunwoda L22D4PC0 type: Li-poly
serial: <filter> status: discharging cycles: 8
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master
Info: model: AMD Ryzen 9 7945HX with Radeon Graphics bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x61 (97) stepping: 2 microcode: 0xA601209
Topology: cpus: 1x dies: 2 clusters: 2x1 cores: 16 threads: 32 tpc: 2
smt: enabled cache: L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 16 MiB
desc: 16x1024 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 1480 min/max: 400/5462 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1480 2: 1480 3: 1480
4: 1480 5: 1480 6: 1480 7: 1480 8: 1480 9: 1480 10: 1480 11: 1480 12: 1480
13: 1480 14: 1480 15: 1480 16: 1480 17: 1480 18: 1480 19: 1480 20: 1480
21: 1480 22: 1480 23: 1480 24: 1480 25: 1480 26: 1480 27: 1480 28: 1480
29: 1480 30: 1480 31: 1480 32: 1480 bogomips: 159703
Device-1: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile] vendor: Lenovo
driver: nvidia v: 570.133.07 alternate: nouveau,nvidia_drm
non-free: 550/565.xx+ status: current (as of 2025-01) arch: Lovelace
code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4
speed: 16 GT/s lanes: 8 ports: active: none empty: DP-1, DP-2, HDMI-A-1,
eDP-1 bus-ID: 01:00.0 chip-ID: 10de:28e0 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: Lenovo
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-2
empty: Writeback-1 bus-ID: 05:00.0 chip-ID: 1002:164e class-ID: 0300
temp: 46.0 C
Device-3: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.4:3 chip-ID: 04f2:b7b6
gpu: amdgpu display-ID: 0
Monitor-1: eDP-2 model: Tianma Micro 0x2038 serial: <filter> built: 2023
res: mode: 2560x1600 hz: 240 scale: 125% (1.25) to: 2048x1280 dpi: 188
gamma: 1.2 size: 345x215mm (13.58x8.46") diag: 407mm (16") ratio: 16:10
modes: max: 2560x1600 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia nouveau drv: nvidia drv: amd radeonsi
platforms: device: 0 drv: nvidia device: 1 drv: radeonsi device: 2
drv: nouveau device: 3 drv: swrast gbm: drv: kms_swrast surfaceless:
drv: nvidia wayland: drv: radeonsi x11: drv: radeonsi
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 25.0.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon 610M (radeonsi
raphael_mendocino LLVM 19.1.7 DRM 3.61 6.14.2-zen1-1-zen)
device-ID: 1002:164e memory: 500 MiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.309 layers: 6 device: 0 type: integrated-gpu name: AMD
Radeon 610M (RADV RAPHAEL_MENDOCINO) driver: N/A device-ID: 1002:164e
surfaces: xcb,xlib,wayland device: 1 type: discrete-gpu name: NVIDIA
GeForce RTX 4060 Laptop GPU driver: N/A device-ID: 10de:28e0
Device-1: NVIDIA AD107 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 8 bus-ID: 01:00.1 chip-ID: 10de:22be
vendor: Lenovo driver: snd_rpl_pci_acp6x v: kernel alternate: snd_pci_acp3x,
snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_pci_ps,
bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.14.2-zen1-1-zen status: kernel-api tools: N/A
vendor: Lenovo driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 03:00.0 chip-ID: 14c3:0616 class-ID: 0280
port: 2000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: Foxconn / Hon Hai Bluetooth 5.2 Adapter [MediaTek MT7922]
driver: btusb v: 0.8 type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 5-1.1:3 chip-ID: 0489:e0d8 class-ID: e001 serial: <filter>
Report: btmgmt ID: hci0 rfk-id: 6 state: up address: <filter> bt-v: 5.2
Local Storage: total: 953.87 GiB used: 12.12 GiB (1.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFS001TEJ9X115N
lanes: 4 tech: SSD serial: <filter> fw-rev: 51020A12 temp: 30.9 C
used: 12.09 GiB (1.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 32.6 MiB (10.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 14.8 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 32
System Temperatures: cpu: 55.9 C mobo: 30.5 C gpu: amdgpu temp: 46.0 C
Memory: total: 16 GiB note: est. available: 14.8 GiB used: 5.23 GiB (35.4%)
Processes: 610 Power: uptime: 1d 8h 0m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 3 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 5.85 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1464 libs: 418
tools: gnome-software,octopi,paru Compilers: gcc: 14.2.1 Shell: garuda-inxi
default: fish v: 4.0.1 running-in: konsole inxi: 3.3.37
System install date: 2025-04-14
Last full system update: 2025-04-14 ↻
Failed units: nmb.service
hi
you can also open the Terminal and start Bottles and Lutris over it. you can see some errors maybe why it dont open the apps. I have both and they are working on my pc but like SGS sayed Bottles is more tricky outside the flatpack version. Did you try Heroic Launcher too for your games ? Maybe this want start ![]()
