I'm using KDE Dragonized. Every time CPU is a lil bit over than 25-30% but not too much, desktop starts lagging. For example, start menu animation is sluggish as well all of latte integrations. Everything related to the compositor lags.
My specs are: B450M pro4, Ryzen 3 3200G, 16 GB Ram 3200Mhz, 128gb SSD
Any way to solve this issue?
SGS
21 March 2021 20:01
2
My very old Hardware work fine with zen kernel, maybe use other kernel if your hardware is realy new?
Integrated GPU?
Sorry, IDK every hardware specs in the world
so post inxi like below.
Read
Writing a well formatted post in the forum (Discource powered) is important, if you want readers to easily read and understand.
It's especially important for terminal output.
Here is a brief tutorial.
Terminal output
For terminal output, text output with special characters, always use code wrapping (Pre-formated text).
Select all of the text and do one of these:
Hit the </> button in Discource Post Toolbar.
Press CtrlShift+C on your keyboard.
Manually with markdown
After you Copy yo…
please
and post
inxi -Fxxxza
as text!
and
Thanks for the fast reply. Yeah, it's integrated graphics with Vega 8
System: Kernel: 5.11.7-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=d42679fc-cbba-4a55-a567-6c3ee3cbfb56 rw rootflags=subvol=@ quiet splash
resume=UUID=fefe0540-ba15-4281-a8a9-1e8608f972e2 loglevel=3
Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop Mobo: ASRock model: B450M Pro4 serial: <filter>
UEFI-[Legacy]: American Megatrends v: P4.30 date: 07/14/2020
CPU: Info: Quad Core model: AMD Ryzen 3 3200G with Radeon Vega Graphics bits: 64 type: MCP
arch: Zen/Zen+ note: check family: 17 (23) model-id: 18 (24) stepping: 1
microcode: 8108109 cache: L2: 2 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 28746
Speed: 3149 MHz min/max: 1400/3600 MHz boost: enabled Core speeds (MHz): 1: 3149
2: 3184 3: 3170 4: 3159
Graphics: Device-1: AMD Picasso driver: amdgpu v: kernel bus-ID: 06:00.0 chip-ID: 1002:15d8
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: amdgpu,ati
s-diag: 582mm (22.9")
Monitor-1: HDMI-A-1 res: 1920x1080 hz: 60 dpi: 102 size: 477x268mm (18.8x10.6")
diag: 547mm (21.5")
OpenGL:
renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.40.0 5.11.7-zen1-1-zen LLVM 11.1.0)
v: 4.6 Mesa 20.3.4 direct render: Yes
Audio: Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel v: kernel
bus-ID: 06:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel v: kernel
bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: HDR webcam HDR webcam type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 3-3:4 chip-ID: 1d6c:0103 class-ID: 0102
Sound Server-1: ALSA v: k5.11.7-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.24 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASRock
driver: r8169 v: kernel port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Bluetooth: Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB driver: btusb
v: 0.8 bus-ID: 1-9:3 chip-ID: 0a12:0001 class-ID: e001
Report: ID: hci0 state: up address: <filter>
Drives: Local Storage: total: 585 GiB used: 63.81 GiB (10.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500LM000-1EJ162 size: 465.76 GiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm
serial: <filter> rev: DEM7 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: MZYTY128HDHP-000L2
rotation: SSD serial: <filter> rev: 1L1Q scheme: MBR
Partition: ID-1: / raw-size: 104.3 GiB size: 104.3 GiB (100.00%) used: 23.47 GiB (22.5%)
fs: btrfs dev: /dev/sdb1 maj-min: 8:17
ID-2: /home raw-size: 104.3 GiB size: 104.3 GiB (100.00%) used: 23.47 GiB (22.5%)
ID-3: /var/log raw-size: 104.3 GiB size: 104.3 GiB (100.00%) used: 23.47 GiB (22.5%)
ID-4: /var/tmp raw-size: 104.3 GiB size: 104.3 GiB (100.00%) used: 23.47 GiB (22.5%)
ID-1: swap-1 type: partition size: 14.94 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb2 maj-min: 8:18
ID-2: swap-2 type: zram size: 3.4 GiB used: 4.3 MiB (0.1%) priority: 32767
ID-3: swap-3 type: zram size: 3.4 GiB used: 4.3 MiB (0.1%) priority: 32767
dev: /dev/zram1
ID-4: swap-4 type: zram size: 3.4 GiB used: 4.1 MiB (0.1%) priority: 32767
dev: /dev/zram2
ID-5: swap-5 type: zram size: 3.4 GiB used: 4 MiB (0.1%) priority: 32767
dev: /dev/zram3
Sensors: System Temperatures: cpu: 45.1 C mobo: N/A gpu: amdgpu temp: 45.0 C
Info: Processes: 297 Uptime: 6h 07m wakeups: 14 Memory: 13.59 GiB used: 4.84 GiB (35.6%)
Init: systemd v: 247 tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages:
pacman: 1768 lib: 541 Shell: fish v: 3.2.0 running-in: alacritty inxi: 3.3.0e
I've changed the linux kernel to linux lts with grub but the same problem occurs. Any other kernel in mind that may do the trick?
I think you should try linux-tkg-bmq-zen. As ryzen 3200 is with zen+ architecture, right?
Yeah it is. I see it isnt available with pacman. Do i have to clone it?
No, you can change it with GUI in garuda settings manager
Ohhh, you mean the default one. Well, i guess that causes fps drops as well. It's just called linux-zen though.
No, not the default one. I was confused with this too, as there is both zen as a cpu architecture and a separate responsive kernel, as well as tkg kernel tuned to work better with zen architecture. I mean exactly linux-tkg-bmq-zen
I see. Problem is it isn't available in kernel settings. Is there some kind of procedure to enable it?
In garuda settings manager, on the "kernel" page there is a button "refresh", probably it uses some kind of pacman command, but I'm not sure which one. Anyways, it should update the available kernels
I guess I'm out of luck. Hitting refresh and nothing changes.
well that's odd. Is there any other tkg kernels with zen postfix?
Try reinstalling garuda-settings-manager
Perfect! That did the trick. A gazillion kernels have appeared. I will try it out and let you know
Wow. I'm impressed. I think it definetely is an improvement. Thanks a lot.
system
Closed
24 March 2021 19:21
20
