Moreover when I try to access locale settings through KDE System Settings, I get that it:
Cannot load library /usr/lib/qt/plugins/msm_locale.so (libicuuc.so.68: cannot open shared object file: No such file or directory)
libicuuc.so is dependent on icu (?), which is installed. Also the shown file path does exist. Note that I can still access the locale settings through Garuda Settings Manager, but none of the locales have the value de_BE.UTF-8, in fact they are just like the /etc/locale.conf.
I get a warning from perl that my locale settings are incorrect (falls back to en_US.UTF-8) every time I do any updates with pacman. I checked ~/.profile, and it has no overrides over the systemwide locale settings.
Sorry to drop in but I'm having same issues, after a clean install and running pacman -Syu they start appearing. Tried a pacman -Syyu and the problem still persists, any other way for me to get more info from the system?
Can you provide output that says what the issues are? An incorrect library version is fixed by an update, so if you’re having that issue then you haven’t fully updated.
(14/20) Checking which packages need to be rebuilt
LANGUAGE = “”,
LC_ALL = (unset),
LC_ADDRESS = “nl_NL.UTF-8”,
LC_NAME = “nl_NL.UTF-8”,
LC_MONETARY = “de_BE.UTF-8”,
LC_PAPER = “nl_NL.UTF-8”,
LC_IDENTIFICATION = “nl_NL.UTF-8”,
LC_TELEPHONE = “nl_NL.UTF-8”,
LC_MESSAGES = “en_US.UTF-8”,
LC_MEASUREMENT = “de_BE.UTF-8”,
LC_CTYPE = “en_US.UTF-8”,
LC_TIME = “C”,
LC_COLLATE = “de_BE.UTF-8”,
LC_NUMERIC = “C”,
LANG = “en_US.UTF-8”
perl: warning: Falling back to a fallback locale (“en_US.UTF-8”).
LANGUAGE = “”,
LC_ALL = (unset),
LC_TIME = “C”,
LC_NUMERIC = “C”,
LANGUAGE = “”,
LC_ALL = (unset),
LC_TIME = “C”,
LC_NUMERIC = “C”,
I update my system, fully, all the time. My icu version has been and is 69.1-1.
I have had this issue for a very long time, just haven’t bothered until now, IRL stuff. It really isn’t in the way of my daily ops, it would be nice to have a pristine running system.
If you include terminal outputs in your post please use the proper output format in your post. Using “~” 3 times above and “~” 3 times below the text block will provide a readable, raw look.
I'll have a look, thank you. I'm doing install through the command line anyway, I was just looking the rest of the apps to see if there was anything else that out of place.
