Edit:
Ok, actually tried this baby out, and⌠Yep. Very good stuff. The additional features are delectable. The more granular control over protections is very nice. I think I may be a convert.
But⌠âFloorpâ? How do you tell people about that when it sounds like a cat getting ready to hurl up a hairball?
It takes another cat person to know that sound. The sound that has me scrambling for the roll of paper towels. With 3 cats, thatâs a daily occurrence.
Floorpâs that good, huh? I guess I should check it out. YAIB.
I donât think I would be using this kind of terminal for a long time , even if I come from gen Z ( i.e. those who born after 2000 ) .
Because these T&C things just doesnât makes to touch it .
AMD for their part exposes much of the same tunables available under Windows but is left to just command-line controls or software to poke different ioctls directly. LACT is now the newest open-source option for those wanting an AMD graphics driver control panel for Linux.
i have since then discovered that this forum uses cloudflare which makes the previous statement false. however that doesnât change anything, these are still the only places i know of that use cloudflare that doesnât have an issue with me.
