Oh yes, I’m using it as well (with KwinFT). I’m impressed about the development of KDE.
Unfortunately for me it’s not enough to switch to Wayland ![]()
Interestingly enough they did not yet import the code for appmenus to KwinFT I think (which explains why it wasnt working with that one), so Im using regular Kwin-git for now ![]()
This morning I was almost forced to switch back to X11 due to Kwin restarting when doing git commits with the sign option
Filed a bugreport, learned how to compile packages with debug symbols and was able to provide a backtrace so the bug was fixed quite fast
Still astonished by how fast! ![]()
https://bugs.kde.org/show_bug.cgi?id=437138
The last thing I’m really missing now is proper screenshot support
But it really has progressed since the last releases, can’t deny that.
More than spectacle? It seems working ![]()
Tells me "Could not take a screenshot" with every option
I started just today messing with wayland. I was logged in KDE wayland when I read your post and used the same (as in Xorg) shortcut for spectacle and worked.
BTW I use Arch ![]()
Seriously, I have no idea what the problem may be. It works for my session (now…
). Wayland on KDE has a lot of glitches but for the (little) time I use it, it is usable. Noone knows what happens tomorrow. ![]()
Did you also set proper environment variables to force the usage of Wayland?
MOZ_ENABLE_WAYLAND=1
QT_QPA_PLATFORM=wayland
I am really shocked and confused on this. I did nothing of these and FF works in Wayland (checked in about:).
I see nothing in /etc/environment, or /etc/profile.d.
I may have the good ghosts in my laptop… ![]()
The Arch wiki suggests this so I added them.
Also I was testing Firefox like that (about:support), it showed xwayland without having added MOZ_ENABLE_WAYLAND=1 to /etc/environment so I guess its needed
Do you mean the packages? or the envvar?
I get this
$ env | grep -i qt
PLASMA_USE_QT_SCALING=1
QT_WAYLAND_FORCE_DPI=96
QT_AUTO_SCREEN_SCALE_FACTOR=0
$ env | grep -i wayland
DESKTOP_SESSION=plasmawayland
XDG_SESSION_TYPE=wayland
WAYLAND_DISPLAY=wayland-0
$ pacman -Qs wayland
local/kwayland 5.82.0-1 (kf5)
Qt-style Client and Server library wrapper for the Wayland libraries
local/kwayland-integration 5.21.5-1 (plasma)
Provides integration plugins for various KDE frameworks for the wayland windowing system
local/kwayland-server 5.21.5-1 (plasma)
Wayland server components built on KDE Frameworks
local/libva 2.11.0-1
Video Acceleration (VA) API for Linux
local/plasma-wayland-session 5.21.5-1
Plasma Wayland session
local/qt5-wayland 5.15.2+kde+r22-1 (qt qt5)
Provides APIs for Wayland
local/sddm 0.19.0-6
QML based X11 and Wayland display manager
local/wayland 1.19.0-1
A computer display server protocol
local/wayland-protocols 1.21-1
Specifications of extended Wayland protocols
local/xorg-xwayland 21.1.1-1 (xorg)
run X clients under wayland
Maybe my sin is I have been using Gnome on Wayland on the same account, just before I start using KDE wayland...
I D K
I mean the variables, added to /etc/environment ![]()
λ env env | grep -i qt
QT_LINUX_ACCESSIBILITY_ALWAYS_ON=1
I’m pretty sure the missing QT_QPA_PLATFORM=wayland in your envvars is what makes spectacle work for you ![]()
This var is empty on me.
Edit:
How can I find out if QT apps (KDE and such) are running on wayland or on fake wayland?
One indicator for me was broken screenshot support on every application I tried, all Qt applications. Flameshot, Ksnip & Spectacle, all working fine on X11 are kind of broken on Wayland (just "capture current window*" works on Ksnip)
Additionally, launching Ksnip gives
Warning: Wayland does not support QWindow::requestActivate()
so I think its safe to assume its running on Wayland
I tried kate from terminal and works normally.
kate -platform wayland
kf.sonnet.core: Sonnet: Unable to load plugin "/usr/lib/qt/plugins/kf5/sonnet/sonnet_hspell.so" Error: "Cannot load library /usr/lib/qt/plugins/kf5/sonnet/sonnet_hspell.so: (libhspell.so.0:cannot open shared object file: Δεν υπάρχει τέτοιο αρχείο ή κατάλογος)"
kf.sonnet.core: Sonnet: Unable to load plugin "/usr/lib/qt/plugins/kf5/sonnet/sonnet_voikko.so" Error: "Cannot load library /usr/lib/qt/plugins/kf5/sonnet/sonnet_voikko.so: (libvoikko.so.1:cannot open shared object file: Δεν υπάρχει τέτοιο αρχείο ή κατάλογος)"
kf.sonnet.core: Unable to handle language from dictionary "gr" "C"
qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
Wow, in the next post you can see a picture that shows the "Millennial Gate" of Gilimanuk. How many times have I been through there ...
Looks promising, doesn't it?
Prices still seem a bit too high to me, even for the DIY version, but maybe over time....
In Russia he's actually considered our home-brewed Elon Musk, but that doesn't excuse Telegram for not using it's own weird encryption 90% of the time.
