Hi me again yet with another problem after updates but looking through some of the other forums just to name a few that I have visited as follows it seams to be the norm with most of the community saying the same thing from time to time things will break its just the natural order of things when having to deal with open source software which I guess always makes for a good challenge.
My problem today is last update broke dependencies fluidsynth and now my updates look like this
╭─username@GarudPC in ~ took 5s
╰─λ update
[sudo] password for username:
garuda is up to date
core 117.9 KiB 307 KiB/s 00:00 [------------------------------] 100%
extra 7.2 MiB 6.12 MiB/s 00:01 [------------------------------] 100%
multilib is up to date
chaotic-aur 760.6 KiB 615 KiB/s 00:01 [------------------------------] 100%
garuda downloading...
core downloading...
extra downloading...
multilib downloading...
chaotic-aur downloading...
spawn pacman -Su
resolving dependencies...
:: installing fluidsynth (2.3.6-1) breaks dependency 'fluidsynth=2.3.5' required by lib32-fluidsynth
╭─username@GarudPC in ~ as 🧙 took 1m
I ran it through octopi as per one of the forums suggested it would help with fixing the problem, Nope! As it can’t be installed I cannot remove it either
Edit Note:
Just a quick edit note here I was able to uninstall fluidsynth here it was removing just the updated fluidsynth 2.3.6-1 and its dependencies, so I just hit OK to remove the updating pkg as shown with the orange square.
╭─username@GarudPC in ~ took 20ms
╰─λ sudo /usr/lib/octopi/octphelper -ts
garuda
core is up to date
extra 2.7 KiB 0.00 B/s --:-- [C o o o o o o o o o o o o o o ] 0%
multilib 1360.0 B 0.00 extra 1802.4 KiB 2.93 garuda is up to date
extra 5.4 MiB 6.44 extra 7.2 MiB 5.42 chaotic-aur 16.0 KiB 0.00 chaotic-aur 760.6 KiB 535:: Starting full system upgrade...-------------------------] 100%
PAKtC
╭─username@GarudPC in ~ as 🧙 took 19s
╰─λ
╰─λ garuda-inxi
Kernel: 6.10.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=d0f8eb0a-2d16-4cc4-9be1-6a244d1ed372 rw rootflags=subvol=@
loglevel=3 splash ibt=off
Desktop: KDE Plasma v: 6.1.3 tk: Qt v: N/A info: frameworks v: 6.4.0
Type: Desktop Mobo: Gigabyte model: Z270X-Gaming 5
UEFI-[Legacy]: American Megatrends v: F4 date: 11/18/2016
Info: model: Intel Core i7-6700K bits: 64 type: MT MCP arch: Skylake-S
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1400 min/max: 800/4200 scaling: driver: intel_pstate
governor: powersave cores: 1: 1400 2: 1400 3: 1400 4: 1400 5: 1400 6: 1400
7: 1400 8: 1400 bogomips: 63999
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Gigabyte driver: nvidia
v: 555.58.02 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
(as of 2024-06; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 2
link-max: lanes: 16 ports: active: none off: DP-1,HDMI-A-2,HDMI-A-3
empty: DVI-D-1,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1c82 class-ID: 0300
d-rect: 5760x1080 display-ID: 0
Monitor-1: DP-1 pos: right res: 1920x1080 size: N/A modes: N/A
Monitor-2: HDMI-A-2 pos: primary,left res: 1920x1080 size: N/A modes: N/A
Monitor-3: HDMI-A-3 pos: center res: 1920x1080 size: N/A modes: N/A
x11: drv: zink inactive: device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2
memory: 3.91 GiB display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 14 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1050 Ti driver: nvidia v: 555.58.02 device-ID: 10de:1c82
18.1.8 256 bits) driver: mesa llvmpipe v: 24.1.5-arch1.1 (LLVM 18.1.8)
Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte
Device-2: NVIDIA GP107GL High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 2
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Device-3: SteelSeries ApS Arctis Nova 7
lanes: 1 mode: 1.1 bus-ID: 1-13:4 chip-ID: 1038:2202 class-ID: 0300
API: ALSA v: k6.10.2-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.2 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
Device-2: Qualcomm Atheros Killer E2500 Gigabit Ethernet vendor: Gigabyte
driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 06:00.0 chip-ID: 1969:e0b1 class-ID: 0200
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5
Local Storage: total: 8.42 TiB used: 278.56 GiB (3.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 950 PRO 256GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B0QBXX7 temp: 35.9 C
scheme: MBR
model: WD40EFRX-68WT0N0 size: 3.64 TiB block-size: physical: 4096 B
fw-rev: 0A80 scheme: GPT
model: WD40EFRX-68N32N0 size: 3.64 TiB block-size: physical: 4096 B
fw-rev: 0A82 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 840 EVO 1TB
tech: SSD serial: <filter> fw-rev: DB6Q scheme: MBR
used: 278.54 GiB (29.9%) fs: btrfs dev: /dev/sdc1 maj-min: 8:33
ID-1: swap-1 type: zram size: 62.75 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 23.0 C mobo: N/A
Fan Speeds (rpm): cpu: 0 fan-2: 0 fan-3: 0
Power: 12v: N/A 5v: N/A 3.3v: 3.36 vbat: 3.27
Memory: total: 64 GiB note: est. available: 62.75 GiB used: 5.9 GiB (9.4%)
Processes: 366 Power: uptime: 5h 53m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 25.04 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2173 libs: 554 tools: octopi,pamac,paru
Compilers: clang: 18.1.8 gcc: 14.1.1 Shell: garuda-inxi default: fish
v: 3.7.1 running-in: konsole inxi: 3.3.35
System install date: 2024-06-19
Last full system update: 2024-08-04
The forums visited so far:-
This forum suggested to remove the file but in my case this is not possible as there are way to many important dependencies
https://bbs.archlinux.org/viewtopic.php?id=281019
https://bbs.archlinux.org/viewtopic.php?id=281968
I used Garuda assistance, clear cashes, clear packages, 4 packages removed, remove data base keys, remove orphans nothing removed here, reboot.
The links visited so far keep coming back to this one
Archlinux no matter how old the link or forum
https://archlinux.org/packages/extra/x86_64/fluidsynth/
OK! If you need more info just ask.
