Hello everyone,
when I attempt to update my system, I get the following error:
:: libretro-meta and libretro-mame-git are in conflict. Remove libretro-mame-git? [y/N] y
:: installing db (6.2.32-1) breaks dependency 'db=5.3.28' required by lib32-db
I have searched the forum and found the following topic, where a similar issue was handled:
However, after following the advice of TNE (post 17), my system returned:
resolving dependencies...
:: pipewire-support and pulseaudio-equalizer are in conflict. Remove pulseaudio-equalizer? [y/N] y
:: pipewire-support and pulseaudio-jack are in conflict. Remove pulseaudio-jack? [y/N] y
:: pipewire-support and pulseaudio-lirc are in conflict. Remove pulseaudio-lirc? [y/N] y
:: pipewire-support and pulseaudio-rtp are in conflict. Remove pulseaudio-rtp? [y/N] y
:: pipewire-support and pulseaudio-support are in conflict. Remove pulseaudio-support? [y/N] y
:: pipewire-support and pulseaudio-zeroconf are in conflict. Remove pulseaudio-zeroconf? [y/N] y
:: pipewire-support and jack2 are in conflict. Remove jack2? [y/N] y
:: pipewire-support and lib32-jack2 are in conflict. Remove lib32-jack2? [y/N] y
:: pipewire-alsa and pulseaudio-alsa are in conflict. Remove pulseaudio-alsa? [y/N] y
:: pipewire-pulse and pulseaudio are in conflict. Remove pulseaudio? [y/N] y
:: pipewire-pulse and pulseaudio-bluetooth are in conflict. Remove pulseaudio-bluetooth? [y/N] y
:: removing lib32-jack2 breaks dependency 'libjack.so=0-32' required by lib32-fluidsynth
:: removing lib32-jack2 breaks dependency 'libjack.so=0-32' required by lib32-portaudio
:: removing lib32-jack2 breaks dependency 'lib32-jack' required by wineasio
So, before I wildly delete packages, I'd like a second opinion.
Here is my inxi:
Kernel: 6.0.11-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=8b782b3f-9cd5-4d15-8596-8ef5e81954cf rw [email protected]
systemd.unified_cgroup_hierarchy=1 loglevel=3 ibt=off
Type: Desktop Mobo: Micro-Star model: Z370 PC PRO (MS-7B49) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.00
date: 09/04/2017
Info: model: Intel Core i5-8600K bits: 64 type: MCP arch: Coffee Lake
desc: 1x9 MiB
Speed (MHz): avg: 4022 high: 4299 min/max: 800/4300 scaling:
driver: intel_pstate governor: performance cores: 1: 4200 2: 4237 3: 4299
4: 3600 5: 4200 6: 3600 bogomips: 43200
disabled
Type: mmio_stale_data mitigation: Clear CPU buffers; SMT disabled
PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: Micro-Star MSI
driver: nvidia v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 520.xx+
status: current (as of 2022-10) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1c03 class-ID: 0300
compositor: kwin_x11 driver: N/A display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 93 s-size: 524x292mm (20.63x11.50")
s-diag: 600mm (23.62")
Monitor-1: DP-2 res: 1920x1080 hz: 60 dpi: 94
size: 521x293mm (20.51x11.54") diag: 598mm (23.53") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 525.60.11 renderer: NVIDIA GeForce GTX 1060
6GB/PCIe/SSE2 direct render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel bus-ID: 1-3:2 v: kernel chip-ID: 0951:16a4
bus-ID: 00:1f.3 class-ID: 0300 chip-ID: 8086:a2f0 class-ID: 0403
Device-2: NVIDIA GP106 High Definition Audio vendor: Micro-Star MSI
bus-ID: 01:00.1 chip-ID: 10de:10f1 class-ID: 0403
Device-3: Kingston HyperX 7.1 Audio type: USB
Sound API: ALSA v: k6.0.11-zen1-1-zen running: yes
Sound Server-1: JACK v: 1.9.21 running: no
Sound Server-2: PulseAudio v: 16.1 running: yes
Sound Server-3: PipeWire v: 0.3.61 running: yes
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
Device-2: Qualcomm Atheros AR93xx Wireless Network Adapter driver: ath9k
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0
chip-ID: 168c:0030 class-ID: 0280
Local Storage: total: 2.27 TiB used: 765.07 GiB (32.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD1
type: SSD serial: <filter> rev: 023 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: DT01ACA200
type: HDD rpm: 7200 serial: <filter> rev: ABB0 scheme: GPT
ID-1: / raw-size: 406.91 GiB size: 406.91 GiB (100.00%)
used: 214 GiB (52.6%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%)
used: 25.5 MiB (10.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 406.91 GiB size: 406.91 GiB (100.00%)
ID-4: /var/log raw-size: 406.91 GiB size: 406.91 GiB (100.00%)
ID-5: /var/tmp raw-size: 406.91 GiB size: 406.91 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.3 GiB used: 1.8 MiB (0.0%) priority: 100
System Temperatures: cpu: 43.0 C mobo: N/A gpu: nvidia temp: 38 C
Processes: 266 Uptime: 31m wakeups: 0 Memory: 31.3 GiB used: 5 GiB (16.0%)
Init: systemd v: 252 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 clang: 14.0.6 Packages: 2163 pm: pacman pkgs: 2158 libs: 573
tools: pamac,paru pm: flatpak pkgs: 5 Shell: fish v: 3.5.1 default: Zsh
v: 5.9 running-in: konsole inxi: 3.3.23
Garuda (2.6.10-1):
System install date: 2021-04-02
Last full system update: 2022-12-07
Snapshots: Timeshift (maybe)
Failed units: bluetooth-autoconnect.service systemd-guest-user.service
As you can see, the last update was quite a while ago (away from PC for quite some time)
Thanks a lot in advance!
