How to fix this?
If you haven't made many customizations, I think such things can be reset with the Restore Config button in the Garuda Assistant
Does restarting the latte process help?
No, restarting did not help
I noticed it after i installed picom for desktop system status
OK, so reseting the config would not help most likely...
I see picom is a compositor, so I have no idea of how it relates with the rest of the system, sorry...
How? Isnโt picom a compositor? How does it help with desktop system status?
And, it is meant for WMs which donโt provide compositing - archwiki
Kwin, which is the default Garuda KDE Dragonized WM, provides compositing.
When you need to start picom
, you have to stop the Kwin compositor, which will interfere with Kwin, which manages your windows and the latte panel.
my bad : picom-ibhagwan-git
Is that beautiful status monitor Conky? If it is, it can also be transparent with the Kwin compositor.
Forum search:
yes i did read this , thats why i used picom-ibhagwan-git
I removed the buttons
At least its not that mixed anymore
ok ok, the problem is that is always associated to i3wm or other windows managers.
I've not found a post related to KDE, although I didn't search in deep...
Uninstalled picom-ibhagwan-git
