I was wondering if anyone can help me change the transparency of the conky displays on the desktop.
I have looked through the conky.conf and cony-shcts files but my experience isn't enough to know what I need to change.
Any help appreciated.
Try running picom via terminal and see if its running.
I remember there was a missing sign in the last isos i3 picom config which prevents it starting
Picom as compositor is responsible for transparency
So, total noob question here, is that just typing picom in the terminal and hitting enter?
Yes exactly, picom will be started and error messages will be printed in the terminal. These can be pasted here to help you further
Have posted the error message above. Also tried to pacman -S picom and it puts out a conflict message with picom-iibhagwan-git. Is it ok to remve this and install picom or is there a better fix?
Well picom-ibhagwan-git
Provides blur and rounded corners
You can however try to copy the fixed picom config from
/etc/skel
To your home folder
Awesome, thanks for that. I now have transparency on my terminal but conky still has the black background.
