I am seeing an issue where the window buttons are being passed to latte dock but not disappearing at the top of a window like they normally do.
Here is my settings info as requested.
Kernel: 5.16.2-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=d42c7a39-5e07-4c69-b652-a230f397013d rw rootflags=subvol=@
Type: Laptop System: LENOVO product: 20LB0021US v: ThinkPad P52s
Mobo: LENOVO model: 20LB0021US v: SDK0J40697 WIN
serial: <superuser required> UEFI: LENOVO v: N27ET41W (1.27 )
date: 10/26/2020
ID-1: BAT0 charge: 28.8 Wh (99.7%) condition: 28.9/32.0 Wh (90.3%)
volts: 16.9 min: 15.3 model: SMP 00UR891 type: Li-poly serial: <filter>
status: N/A cycles: 361
ID-2: BAT1 charge: 9.4 Wh (48.5%) condition: 19.4/24.1 Wh (80.5%)
volts: 10.5 min: 11.4 model: Celxpert 01AV424 type: Li-poly
serial: <filter> status: Discharging cycles: 782
Info: model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xEA
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 799 high: 800 min/max: 400/4000 scaling:
driver: intel_pstate governor: powersave cores: 1: 799 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 bogomips: 31999
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: NVIDIA GP108GLM [Quadro P500 Mobile] vendor: Lenovo
driver: nvidia v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 02:00.0
chip-ID: 10de:1d33 class-ID: 0302
Device-3: Acer SunplusIT Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-8:3 chip-ID: 5986:2113 class-ID: 0e02
loaded: modesetting display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142
Sound Server-1: ALSA v: k5.16.2-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.44 running: yes
Device-1: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d8 class-ID: 0200
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel
bus-ID: 04:00.0 chip-ID: 8086:24fd class-ID: 0280
Local Storage: total: 465.76 GiB used: 38.92 GiB (8.4%)
ID-1: /dev/sda maj-min: 8:0 model: Genuine 500GB size: 465.76 GiB
serial: <filter> rev: 2A0 scheme: GPT
ID-1: / raw-size: 70 GiB size: 70 GiB (100.00%) used: 38.89 GiB (55.6%)
fs: btrfs dev: /dev/sda6 maj-min: 8:6
used: 25.9 MiB (10.1%) fs: vfat dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 70 GiB size: 70 GiB (100.00%)
used: 38.89 GiB (55.6%) fs: btrfs dev: /dev/sda6 maj-min: 8:6
ID-4: /var/log raw-size: 70 GiB size: 70 GiB (100.00%)
ID-5: /var/tmp raw-size: 70 GiB size: 70 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.08 GiB used: 2.2 MiB (0.0%)
System Temperatures: cpu: 47.0 C pch: 44.5 C mobo: N/A
Fan Speeds (RPM): fan-1: 0
Processes: 307 Uptime: 53m wakeups: 3 Memory: 31.08 GiB
used: 6.63 GiB (21.3%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1564 lib: 375 Shell: fish
Garuda:
System install date: 2022-01-27
Last full system update: 2022-01-27
Using TLP: No
Snapshots: Timeshift
