Yes, when i open it from latte,
journalctl -b -p3 ::
feb 07 23:07:54 MSIGARUDA kernel: x86/cpu: SGX disabled by BIOS.
feb 07 23:07:55 MSIGARUDA kernel: tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [m>
feb 07 23:07:55 MSIGARUDA kernel: Bluetooth: hci0: Failed to read codec capabilities (-56)
feb 07 23:07:55 MSIGARUDA systemd-tmpfiles[471]: Failed to write file "/sys/module/pcie_aspm/parameters/policy": Operation not permitted
feb 07 23:07:56 MSIGARUDA libvirtd[519]: cannot open directory '/run/media/jurosic_park/2ndSSD/VMs': No such file or directory
feb 07 23:07:56 MSIGARUDA libvirtd[519]: internal error: Failed to autostart storage pool '2ndSSD': cannot open directory '/run/media/ju>
feb 07 23:07:56 MSIGARUDA libvirtd[519]: cannot open directory '/run/media/jurosic_park/DISK M-PC': No such file or directory
feb 07 23:07:56 MSIGARUDA libvirtd[519]: internal error: Failed to autostart storage pool 'DISK_M-PC': cannot open directory '/run/media>
feb 07 23:07:57 MSIGARUDA kernel:
feb 07 23:07:57 MSIGARUDA kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 495.46 Wed Oct 27 16:31:33 UTC 2021
feb 07 23:07:58 MSIGARUDA nmbd[1900]: [2022/02/07 23:07:58.606532, 0] ../../source3/nmbd/nmbd.c:901(main)
feb 07 23:07:58 MSIGARUDA nmbd[1900]: nmbd version 4.15.4 started.
feb 07 23:07:58 MSIGARUDA nmbd[1900]: Copyright Andrew Tridgell and the Samba Team 1992-2021
feb 07 23:07:58 MSIGARUDA smbd[1932]: [2022/02/07 23:07:58.704586, 0] ../../source3/smbd/server.c:1734(main)
feb 07 23:07:58 MSIGARUDA smbd[1932]: smbd version 4.15.4 started.
feb 08 07:53:50 MSIGARUDA kernel: Bluetooth: hci0: Failed to read codec capabilities (-56)
feb 08 07:54:31 MSIGARUDA kernel: NVRM: GPU at PCI:0000:01:00: GPU-63f4bd47-9605-c863-2296-278181802e42
feb 08 07:54:31 MSIGARUDA kernel: NVRM: Xid (PCI:0000:01:00): 31, pid=8254, Ch 00000060, intr 10000000. MMU Fault: ENGINE HOST0 HUBCLIENT_HOST_CPU faulted @ 0x1_041fc000. Fault is of type FAULT_PTE ACCESS_TYPE_WRITE
feb 08 07:54:32 MSIGARUDA kernel: NVRM: Xid (PCI:0000:01:00): 31, pid=8254, Ch 00000060, intr 10000000. MMU Fault: ENGINE HOST0 HUBCLIENT_HOST_CPU faulted @ 0x1_041fc000. Fault is of type FAULT_PTE ACCESS_TYPE_WRITE
feb 08 07:57:52 MSIGARUDA nmbd[1900]: [2022/02/08 07:57:52.128030, 0] ../../source3/nmbd/nmbd_become_lmb.c:398(become_local_master_stage2)
feb 08 07:57:52 MSIGARUDA nmbd[1900]: *****
feb 08 07:57:52 MSIGARUDA nmbd[1900]: Samba name server MSIGARUDA is now a local master browser for workgroup WORKGROUP on subnet 192.168.1.72
feb 08 11:17:27 MSIGARUDA kernel: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
feb 08 11:17:27 MSIGARUDA kernel: CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
feb 08 11:17:33 MSIGARUDA kernel: CIFS: VFS: multichannel is not supported on this protocol version, use 3.0 or above
feb 08 11:17:35 MSIGARUDA kernel: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
feb 08 11:17:35 MSIGARUDA kernel: CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
feb 08 11:17:35 MSIGARUDA kernel: CIFS: VFS: multichannel is not supported on this protocol version, use 3.0 or above
feb 08 13:00:31 MSIGARUDA pipewire-pulse[5108]: mod.protocol-pulse: server 0x561888648210: client 0x56188947efc0 [Chromium] error -104 (Connection reset by peer)
journalctl -b -1 -p3 ::
feb 08 07:54:31 MSIGARUDA kernel: NVRM: Xid (PCI:0000:01:00): 31, pid=8254, Ch 00000060, intr 10000000. MMU Fault: ENGINE HOST0 HUBCLIEN>
feb 08 07:54:32 MSIGARUDA kernel: NVRM: Xid (PCI:0000:01:00): 31, pid=8254, Ch 00000060, intr 10000000. MMU Fault: ENGINE HOST0 HUBCLIEN>
feb 07 22:04:17 MSIGARUDA kernel: tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfed40000-0xfed4087f flags 0x200] vs fed40080 f80
feb 07 22:04:17 MSIGARUDA kernel: Bluetooth: hci0: Failed to read codec capabilities (-56)
feb 07 22:04:18 MSIGARUDA systemd-tmpfiles[472]: Failed to write file "/sys/module/pcie_aspm/parameters/policy": Operation not permitted
feb 07 22:04:22 MSIGARUDA nmbd[595]: [2022/02/07 22:04:22.615880, 0] ../../source3/nmbd/nmbd.c:901(main)
feb 07 22:04:22 MSIGARUDA nmbd[595]: nmbd version 4.15.4 started.
feb 07 22:04:22 MSIGARUDA nmbd[595]: Copyright Andrew Tridgell and the Samba Team 1992-2021
feb 07 22:04:22 MSIGARUDA libvirtd[540]: cannot open directory '/run/media/jurosic_park/DISK M-PC': No such file or directory
feb 07 22:04:22 MSIGARUDA libvirtd[540]: internal error: Failed to autostart storage pool 'DISK_M-PC': cannot open directory '/run/media/jurosic_park/DISK M-PC': No such file or directory
feb 07 22:04:22 MSIGARUDA libvirtd[540]: cannot open directory '/run/media/jurosic_park/2ndSSD/VMs': No such file or directory
feb 07 22:04:22 MSIGARUDA libvirtd[540]: internal error: Failed to autostart storage pool '2ndSSD': cannot open directory '/run/media/jurosic_park/2ndSSD/VMs': No such file or directory
feb 07 22:04:22 MSIGARUDA smbd[601]: [2022/02/07 22:04:22.709276, 0] ../../source3/smbd/server.c:1734(main)
feb 07 22:04:22 MSIGARUDA smbd[601]: smbd version 4.15.4 started.
feb 07 22:04:22 MSIGARUDA smbd[601]: Copyright Andrew Tridgell and the Samba Team 1992-2021
feb 07 22:04:23 MSIGARUDA kernel:
feb 07 22:04:23 MSIGARUDA kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 495.46 Wed Oct 27 16:31:33 UTC 2021
feb 07 22:04:33 MSIGARUDA sddm-helper[4024]: gkr-pam: unable to locate daemon control file
feb 07 22:04:38 MSIGARUDA kernel: Bluetooth: hci0: Failed to read codec capabilities (-56)
feb 07 22:04:45 MSIGARUDA nmbd[595]: [2022/02/07 22:04:45.531813, 0] ../../source3/nmbd/nmbd_become_lmb.c:398(become_local_master_stage2)
feb 07 22:04:45 MSIGARUDA nmbd[595]: *****
feb 07 22:04:45 MSIGARUDA nmbd[595]: Samba name server MSIGARUDA is now a local master browser for workgroup WORKGROUP on subnet 192.168.1.72
