My latte dock is stuck in panel mode. I can't change it back with the dock/panel button in the edit menu either, the option is greyed out. I can only fix it with reset configs in the Garuda Assistant but this is very annoying, I have to replace my launchers on the dock every single time. On top of it, when this issue occurs it takes a long time to get from logging in at sddm to getting to my desktop. This issue happens sometimes when I close a game or long in. I have tried reinstalling latte dock via pacman my terminal but it does not help. Can someone help me?
inxi -Faz System: Kernel: 5.13.13-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=39ef41aa-7170-4e45-928b-20e167ab35e6
rw [email protected] rd.udev.log_priority=3 vt.global_cursor_default=0
systemd.unified_cgroup_hierarchy=1 resume=UUID=6168f51b-00de-48e1-ab08-0eedb3c6380c loglevel=3
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop Mobo: Micro-Star model: B550M PRO-VDH WIFI (MS-7C95) v: 1.0 serial: <filter>
UEFI: American Megatrends LLC. v: 2.71 date: 02/26/2021
CPU: Info: 6-Core model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3 family: 19 (25)
model-id: 21 (33) stepping: 0 microcode: A201009 cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 88793
Speed: 3594 MHz min/max: 2200/3700 MHz boost: enabled Core speeds (MHz): 1: 3594 2: 3682
3: 3633 4: 3596 5: 3789 6: 3594 7: 3596 8: 3587 9: 3596 10: 3723 11: 3613 12: 3694
mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: always-on, RSB filling
Graphics: Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590] vendor: Micro-Star MSI
driver: amdgpu v: kernel bus-ID: 2b:00.0 chip-ID: 1002:67df class-ID: 0300
Device-2: WaveRider USB Live camera type: USB driver: snd-usb-audio,uvcvideo bus-ID: 3-3:2
chip-ID: 0c46:64ab class-ID: 0102 serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: amdgpu,ati
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 507x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: HDMI-A-0 res: 1920x1080 dpi: 30 size: 1600x900mm (63.0x35.4") diag: 1836mm (72.3")
OpenGL:
renderer: AMD Radeon RX 480 Graphics (POLARIS10 DRM 3.41.0 5.13.13-zen1-1-zen LLVM 12.0.1)
v: 4.6 Mesa 21.2.1 direct render: Yes
Audio: Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 2b:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus-ID: 2d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: WaveRider USB Live camera type: USB driver: snd-usb-audio,uvcvideo bus-ID: 3-3:2
Sound Server-1: ALSA v: k5.13.13-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.34 running: yes
Network: Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi v: kernel
bus-ID: 29:00.0 chip-ID: 8086:24fb class-ID: 0280
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI
driver: r8169 v: kernel port: f000 bus-ID: 2a:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp42s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Bluetooth: Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-9:6
chip-ID: 8087:0aa7 class-ID: e001
Drives: Local Storage: total: 1.82 TiB used: 267.05 GiB (14.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102 size: 1.82 TiB
serial: <filter> rev: 0001 scheme: GPT
Partition: ID-1: / raw-size: 1.8 TiB size: 1.8 TiB (100.00%) used: 267.05 GiB (14.5%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.45%) used: 562 KiB (0.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 1.8 TiB size: 1.8 TiB (100.00%) used: 267.05 GiB (14.5%) fs: btrfs
ID-4: /var/log raw-size: 1.8 TiB size: 1.8 TiB (100.00%) used: 267.05 GiB (14.5%) fs: btrfs
ID-5: /var/tmp raw-size: 1.8 TiB size: 1.8 TiB (100.00%) used: 267.05 GiB (14.5%) fs: btrfs
ID-1: swap-1 type: zram size: 15.55 GiB used: 1.73 GiB (11.1%) priority: 100 dev: /dev/zram0
ID-2: swap-2 type: partition size: 17.11 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3
maj-min: 8:3
Sensors: System Temperatures: cpu: 52.1 C mobo: N/A gpu: amdgpu temp: 71.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 715
Info: Processes: 353 Uptime: 2h 14m wakeups: 0 Memory: 15.55 GiB used: 7.54 GiB (48.5%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1388 lib: 384
Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
