Hello!
I've been dealing with this since installing Garuda and have tried searching and solving this problem multiple times already. My latte-dock keeps freezing randomly, sometimes a few minutes after booting up, sometimes multiple hours later. Yesterday for example, I only had a freeze when booting up. I had to do killall latte-dock && latte-dock -d, then it worked well for the rest of the day.
Today, it froze up on boot and hasn't stopped freezing since. In the past hour, I've had to kill and restart latte-dock four times. Each time I kill it and restart it, it gets increasingly longer for it to start being responsive. At boot for example, everything is ready within a few seconds. After having it killed a fourth time, it took almost two minutes for the new process to become responsive again.
Anytime this happens, the taskbar and status bar are completely unresponsive, and even the clock freezes. As I'm writing this, the clock is 20 minutes behind, meaning that latte-dock has been frozen for a while now and isn't recovering on its own. When killing and restarting latte-dock with -d, I can look at the logs when the freeze occurs but usually nothing is particularly telling about what could cause it.
Around the time latte-dock froze, only these two lines are present:
[Warning : 10:06:49.713713] - "QXcbConnection: XCB error: 3 (BadWindow), sequence: 46360, resource id: 90179417, major code: 3 (GetWindowAttributes), minor code: 0"
[Warning : 10:06:49.713713] - "QXcbConnection: XCB error: 3 (BadWindow), sequence: 46361, resource id: 90179417, major code: 2 (ChangeWindowAttributes), minor code: 0"
I've tried updating latte-dock and switching to latte-dock-git. I first thought it was caused by a CUPS (printer service) error that kept showing up when I had a VPN on and local printers couldn't be retrieved, but I have it on all the time and the freeze only occurs sometimes. I'm kind of out of ideas as nothing even shows up in the logs.
Output of inxi -Faz:
â•─pc@pc in ~ took 1ms
╰─λ inxi -Faz
System: Kernel: 5.14.9-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=8a0a4f23-e4b4-468d-a55d-308b2de6b338
rw rootflags=subvol=@ quiet
cryptdevice=UUID=06b5b85e-d9c6-4b3d-8ad4-9160c300f9fc:luks-06b5b85e-d9c6-4b3d-8ad4-9160c300f9fc
root=/dev/mapper/luks-06b5b85e-d9c6-4b3d-8ad4-9160c300f9fc splash rd.udev.log_priority=3
vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1
resume=/dev/mapper/luks-a775b892-c6c9-43c9-8c98-189505509025 loglevel=3
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: Dell product: XPS 13 9370 v: N/A serial: <filter> Chassis: type: 10
Mobo: Dell model: 0W970W v: A06 serial: <filter> UEFI: Dell v: 1.15.0 date: 06/07/2021
Battery: ID-1: BAT0 charge: 48.4 Wh (100.0%) condition: 48.4/52.0 Wh (93.1%) volts: 8.5 min: 7.6
model: LGC-LGC6.73 DELL H754V05 type: Li-ion serial: <filter> status: Full
CPU: Info: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Kaby Lake note: check
family: 6 model-id: 8E (142) stepping: A (10) microcode: EA cache: L2: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 31999
Speed: 3785 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 3785 2: 3794 3: 3861 4: 3793
5: 3790 6: 3968 7: 3786 8: 3825
Graphics: Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:5917 class-ID: 0300
Device-2: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo bus-ID: 1-5:2
chip-ID: 0bda:58f4 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: intel
Screen-1: 0 s-res: 1920x1944 s-dpi: 96 s-size: 506x513mm (19.9x20.2") s-diag: 721mm (28.4")
Monitor-1: eDP1 res: 1536x864 dpi: 135 size: 290x170mm (11.4x6.7") diag: 336mm (13.2")
Monitor-2: DP1-1 res: 1920x1080 hz: 60 dpi: 81 size: 600x340mm (23.6x13.4") diag: 690mm (27.2")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.2.3 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel v: kernel
alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
Device-2: Realtek USB Audio type: USB driver: snd-usb-audio bus-ID: 3-1.3.4:7
chip-ID: 0bda:402e class-ID: 0102 serial: <filter>
Sound Server-1: ALSA v: k5.14.9-zen2-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Network: Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Rivet Networks Killer 1435 Wireless-AC driver: ath10k_pci v: kernel port: f040
bus-ID: 02:00.0 chip-ID: 168c:003e class-ID: 0280
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152 bus-ID: 4-1.4:4
IF: enp57s0u1u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth: Device-1: Foxconn / Hon Hai type: USB driver: btusb v: 0.8 bus-ID: 1-7:3 chip-ID: 0489:e0a2
Drives: Local Storage: total: 476.94 GiB used: 31.37 GiB (6.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: PC611 NVMe 512GB size: 476.94 GiB
rev: 11002111 temp: 46.9 C scheme: GPT
Partition: ID-1: / raw-size: 459.81 GiB size: 459.81 GiB (100.00%) used: 31.37 GiB (6.8%) fs: btrfs
dev: /dev/dm-0 maj-min: 254:0 mapped: luks-06b5b85e-d9c6-4b3d-8ad4-9160c300f9fc
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 708 KiB (0.3%) fs: vfat
ID-3: /home raw-size: 459.81 GiB size: 459.81 GiB (100.00%) used: 31.37 GiB (6.8%) fs: btrfs
ID-4: /var/log raw-size: 459.81 GiB size: 459.81 GiB (100.00%) used: 31.37 GiB (6.8%) fs: btrfs
ID-5: /var/tmp raw-size: 459.81 GiB size: 459.81 GiB (100.00%) used: 31.37 GiB (6.8%) fs: btrfs
ID-1: swap-1 type: zram size: 15.33 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
ID-2: swap-2 type: partition size: 16.86 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/dm-1
maj-min: 254:1 mapped: luks-a775b892-c6c9-43c9-8c98-189505509025
Sensors: System Temperatures: cpu: 59.0 C mobo: 42.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 4697
Info: Processes: 285 Uptime: 51m wakeups: 9 Memory: 15.33 GiB used: 7.81 GiB (50.9%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1408 lib: 341
Shell: fish v: 3.3.1-393-g86a442fb6 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
Thanks!
