Hello community I always had this problem: When start my computer the wallpaper is bugged, sometimes I can see black lines on random parts in screen. I am sure than latte is the cause because when it finish to load the wallpaper and system works fine. Also when I remove latte on autostart this error don't aappear.Any solution to fix that?
kindly provide the output of inxi -Faz in a proper format
A few "hints", since there are a lot of threads about this point:
- Delay autostart
Desktop is empty with no dock or hotbar 2 - #11 by lindsm - Configuration tips
psifidotos: Latte Dock v0.10.1 | Bug Fix Release - Most importantly, an important fix is upcoming
Latte-dock freezing randomly - #42 by psifidotos
- and this is important, previously when Latte was starting and user had enabled Borderless maximized windows, latte was triggering a kwin restart/reconfigure with every latte startup, this is not needed any more. The fix is part of v0.10.4
I use the second hint and works fine
