I have russian installed in my system, so I passed the logs through the translator. There may be some inaccuracies in the words
sudo fdisk -l
Disk /dev/nvme0n1: 476.94 GiB, 512110190592 bytes, 1000215216 sectors
Disk model: INTEL SSDPEKNW512G8H
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk label type: gpt
Disk ID: 52764997-9024-6540-9C0E-F2BADF274256
Device Start End Sectors Size Type
/dev/nvme0n1p1 2048 746975231 746973184 356.2 G File system Linux
/ dev/nvme0n1p2 746975232 999395327 252420096 120.4 G Microsoft basic data
/dev/nvme0n1p3 999395328 999428095 32768 16M Microsoft Reserved partition
/ dev/nvme0n1p4 1000009728 1000214527 204800 100M EFI
Disk /dev/zram0: 1.94 GiB, 2082988032 bytes, 508542 sectors
Units: sectors of 1 * 4096 = 4096 bytes
Sector size (logical/physical): 4096 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk /dev/zram1: 1.94 GiB, 2082988032 bytes, 508542 sectors
Disk /dev/zram2: 1.94 GiB, 2082988032 bytes, 508542 sectors
Disk /dev/zram3: 1.94 GiB, 2082988032 bytes, 508542 sectors
Disk /dev/zram4: 1.94 GiB, 2082988032 bytes, 508542 sectors
Disk /dev/zram5: 1.94 GiB, 2082988032 bytes, 508542 sectors
Disk /dev/zram6: 1.94 GiB, 2082988032 bytes, 508542 sectors
Disk /dev/zram7: 1.94 GiB, 2082988032 bytes, 508542 sectors
sudo parted -l
Model: INTEL SSDPEKNW512G8H (NVME)
Disk /dev/nvme0n1: 512GB
Sector size (logical/physical): 512B/512B
Partition table: gpt
Disk flags:
Number Start End Size File System Name Flags
1 1049kB 382GB 382GB btrfs
2 382GB 512GB 129GB ntfs legacy_boot, msftdata
3 512GB 512GB 16,8MB Microsoft reserved partition msftres
4 512GB 512GB 105MB fat32 EFI system partition bootable, esp
Model: Unknown)
Disk /dev/zram5: 2083MB
Sector size (logical/physical): 4096B/4096B
Partition table: loop
Disk flags:
Number Start End Size File System Flags
1 0,00B 2083MB 2083MB linux-swap(v1)
Model: Unknown)
Disk /dev/zram3: 2083MB
Disk flags:
Model: Unknown)
Disk /dev/zram1: 2083MB
Disk flags:
Model: Unknown)
Disk /dev/zram6: 2083MB
Disk flags:
Model: Unknown)
Disk /dev/zram4: 2083MB
Disk flags:
Model: Unknown)
Disk /dev/zram2: 2083MB
Disk flags:
Model: Unknown)
Disk /dev/zram0: 2083MB
Disk flags:
Model: Unknown)
Disk /dev/zram7: 2083MB
Disk flags:
lsblk -f
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINT
zram0 [SWAP]
zram1 [SWAP]
zram2 [SWAP]
zram3 [SWAP]
zram4 [SWAP]
zram5 [SWAP]
zram6 [SWAP]
zram7 [SWAP]
nvme0n1
├─nvme0n1p1 btrfs e70e0471-a96d-4f7b-8d91-55805210645d 325,1G 9% /run/timeshift/backup
├─nvme0n1p2 ntfs 353A4DB32209D32A 100,5G 16% /run/media/user/353A4DB32209D32A
├─nvme0n1p3
└─nvme0n1p4 vfat FAT32 AA07-7C98 70,5M 27% /boot/efi
