Hello there!
Currently i have a weird and really annoying issue that i wasn’t able to solve.
Problem :
- The second i plug my laptop into charge, the performance of the entire system drops drastically;
- The second i unplug it, the system becomes lightning fast.
(the battery level has no impact on this phenomenon)
Weirder : Sometimes it happens that i plug my pc to charge, and it runs at its full potential. I can’t tell what’s going on.
Garuda-inxi :
Kernel: 6.7.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=12228323-29ff-4f5f-86b3-55f915eadd01 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_wayland vt: 1
Type: Laptop System: SAMSUNG product: 750XED v: P13CFG
Mobo: SAMSUNG model: NP750XED-KB7FR
v: SAMSUNG_SW_REVISION_12345+10.0.22621 serial: <superuser required>
UEFI: American Megatrends LLC. v: P13CFG.039.230726.HQ date: 07/26/2023
ID-1: BAT1 charge: 37.9 Wh (68.3%) condition: 55.5/54.4 Wh (102.2%)
volts: 15.8 min: 15.4 model: SAMSUNG Electronics SR Real Battery
type: Li-ion serial: <filter> status: discharging cycles: 49
Info: model: 12th Gen Intel Core i7-1255U bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 4
microcode: 0x430
Topology: cpus: 1x cores: 10 mt: 2 tpc: 2 st: 8 threads: 12 smt: enabled
cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32 KiB, 8x64 KiB
L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 497 high: 927 min/max: 400/4700:3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 600 2: 400 3: 927 4: 400
5: 400 6: 400 7: 400 8: 532 9: 711 10: 400 11: 400 12: 400 bogomips: 62668
Device-1: Intel Alder Lake-UP3 GT2 [Iris Xe Graphics] vendor: Samsung Co
driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:46a8 class-ID: 0300
Device-2: SunplusIT 720p HD Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-8:3 chip-ID: 5959:1502
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.3.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
device-ID: 8086:46a8 memory: 14.96 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.276 layers: 4 device: 0 type: integrated-gpu name: Intel
Graphics (ADL GT2) driver: mesa intel v: 23.3.5-arch1.1
device-ID: 8086:46a8 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 23.3.5-arch1.1 (LLVM 16.0.6) device-ID: 10005:0000
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Samsung Co
chip-ID: 8086:51c8 class-ID: 0401
API: ALSA v: k6.7.4-zen1-1-zen status: kernel-api tools: N/A
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0026
Local Storage: total: 476.94 GiB used: 65.15 GiB (13.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLQ512HBLU-00B
lanes: 4 tech: SSD serial: <filter> fw-rev: FXM7AK1Q temp: 24.9 C
used: 65.15 GiB (13.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.32 GiB used: 46.5 MiB (0.3%)
System Temperatures: cpu: 35.0 C mobo: N/A
Processes: 313 Uptime: 5m wakeups: 1 Memory: total: 16 GiB
available: 15.32 GiB used: 4 GiB (26.1%) Init: systemd v: 255
Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 1520 libs: 428
tools: octopi,pamac,paru,yay Shell: fish v: 3.7.0 running-in: konsole
inxi: 3.3.31
Garuda (2.6.23-1):
System install date: 2023-11-12
Last full system update: 2024-02-08
Relevant software: snapper tlp NetworkManager dracut
Failed units: vmware.service
What I tried :
- Change the cpu frequency
sudo cpupower frequency-set -g performance - Followed (most) tbg tutorial
- Disable BTRFS quotas
- Install various kernels (lts / mainline / linux)
- BIOS is up to date
- No overheat when runing
sensors. - (and more, but don’t think it has any correlation with the current issue)
- Look over google and chat-gpt to figure out other solutions, but seems like i am the only with this issue.
Thank you, and i appreciate any other help (other than garuda-update).
