I have serious problems with pipewire interference over-writing my audio driver by garuda which blocks the onboard mic capture device. (Millions of old sturdy Lenovo laptop users are out here)
When I checked with alsamixer, it shows the pipewire loaded instead of my onboard. But when I tried to deselect the pipewire from Garuda settings, it also did not work.
I will try next week with a plug and play mic-camera with on chip drivers, and see if that will bypass this.
Here are the specs for the onboard devices garuda will not load. (generic pipewire will load the speakers but not the microphone "capture" device - neither on board nor headphones.
Please, do not post pictures from terminal output.
From the template that appears when you open a new topic. You could not see this because your post was posted in a wrong post.
Post your terminal/konsole in- and output as text (nopictures) from:
inxi -Faz
That is correct in so far, but why therefore post the complete screen?
But you have now neither the console images nor the output of inxi -Faz posted as text.
Based on your second image I would guess that you are using BSPWM, but who knows, maybe you just liked my wallpaper
The alsamixer image was inteded to show that pipewire has colonized/occupied my audio system. I admit i am too lazy to crop the image before posting. I did shrink the size for your convenience.
Nevertheless, in garuda settings, I have de-selected pipewire, yet it still runs by default, i.e.,
No, microphone was not displaying in settings. Pretty sure it was working before in earlier garuda versions installed on this same machine. Only garuda is installed on the computer - no dual boot OS or such.
Looks like i have to go fishing for Realtek ALC3232 driver to load to over write the pipewire.
The wierd thing is that pipewire still runs even though it is deselected in garuda settings.
