When my laptop goes to sleep, either through leaving it for a while or closing the lid, it doesn’t wake back up. I’m stuck on a black screen with no functional inputs. The light on the power button and keys like caps lock still work, but only holding the power button to force shutdown does anything. Obviously, I can do things to keep it from ever sleeping, but that’s not a great plan for battery life.
I suspect it has to do with the Nvidia drivers. I had some other issues getting the DGPU to work at all. Suspend/resume worked fine when I was only using the Intel graphics drivers.
I’ve already tried all the steps mentioned in this post, but to no avail. Since my issue is a bit different, I figured I’d start a new topic.
If you tried the command in the first comment in this thread you linked, it looks like it didn’t work because it is supposed to add the nvidia-drm.modeset=1 kernel parameter. It is missing from the parameters line in your inxi. You too Jeshu.
An easy way to add this kernel parameter is with the Garuda Boot Options utility. Just paste it in after your other parameters and click Apply:
I’m not sure if that will solve your issue or not; my understanding is there are some major issues with the 545 Nvidia drivers. I have seen some folks have been downgrading them to 535 for now because of that.
Another thing I have seen in the forums is the latest version of mesa and lib32-mesa can cause problems for some Nvidia systems, such as in this thread: EOS doesn't boot on my GPU - Kernel, boot, graphics & hardware - EndeavourOS. During your troubleshooting it may be worthwhile to test downgrading those as well.
Thanks y’all. Sorry for the slow reply. None of the above managed to solve the issue for me either.
Bluetooth is already turned off, so that’s not an issue for me.
Here’s the output of journalctl as you mentioned:
Jan 11 17:42:20 garrett-82xv systemd-sleep[33034]: Performing sleep operation 'suspend'...
Jan 11 17:42:20 garrett-82xv kernel: PM: suspend entry (deep)
Jan 11 17:42:20 garrett-82xv systemd-sleep[33034]: Failed to lock home directories: Unknown object '/org/freedesktop/home1'.
Jan 11 17:42:20 garrett-82xv systemd[1]: Starting System Suspend...
Jan 11 17:42:20 garrett-82xv systemd[1]: Reached target Sleep.
Jan 11 17:42:20 garrett-82xv kscreenlocker_greet[33002]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/VirtualKeyboard.qml:8:1: module "QtQuick.VirtualKeyboard" is not installed
Jan 11 17:42:20 garrett-82xv kscreenlocker_greet[33002]: kf.kirigami: Failed to find a Kirigami platform plugin
Jan 11 17:42:20 garrett-82xv kscreenlocker_greet[33002]: Qt: Session management error: networkIdsList argument is NULL
Jan 11 17:42:20 garrett-82xv kwin_x11[4672]: kwin_core: XCB error: 152 (BadDamage), sequence: 22535, resource id: 16784917, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Jan 11 17:42:20 garrett-82xv kernel: r8169 0000:07:00.0 enp7s0: Link is Down
Jan 11 17:42:20 garrett-82xv NetworkManager[721]: <info> [1705020140.1247] device (enp7s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Jan 11 17:42:20 garrett-82xv avahi-daemon[722]: Interface enp7s0.IPv4 no longer relevant for mDNS.
Jan 11 17:42:20 garrett-82xv avahi-daemon[722]: Leaving mDNS multicast group on interface enp7s0.IPv4 with address 192.168.0.7.
Jan 11 17:42:20 garrett-82xv avahi-daemon[722]: Withdrawing address record for 192.168.0.7 on enp7s0.
Jan 11 17:42:20 garrett-82xv NetworkManager[721]: <info> [1705020140.1126] dhcp4 (enp7s0): state changed no lease
Jan 11 17:42:20 garrett-82xv NetworkManager[721]: <info> [1705020140.1126] dhcp4 (enp7s0): activation: beginning transaction (timeout in 45 seconds)
Jan 11 17:42:20 garrett-82xv avahi-daemon[722]: Interface enp7s0.IPv6 no longer relevant for mDNS.
Jan 11 17:42:20 garrett-82xv NetworkManager[721]: <info> [1705020140.1126] dhcp4 (enp7s0): canceled DHCP transaction
Jan 11 17:42:20 garrett-82xv avahi-daemon[722]: Leaving mDNS multicast group on interface enp7s0.IPv6 with address fe80::c65:aa6d:103d:a42b.
Jan 11 17:42:20 garrett-82xv avahi-daemon[722]: Withdrawing address record for fe80::c65:aa6d:103d:a42b on enp7s0.
Jan 11 17:42:20 garrett-82xv NetworkManager[721]: <info> [1705020140.1122] device (enp7s0): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
Jan 11 17:42:20 garrett-82xv systemd[1]: Started Network Manager Script Dispatcher Service.
Jan 11 17:42:20 garrett-82xv systemd[1]: Starting Network Manager Script Dispatcher Service...
Jan 11 17:42:20 garrett-82xv kded5[4671]: org.kde.plasma.nm.kded: Unhandled active connection state change: 3
Jan 11 17:42:20 garrett-82xv NetworkManager[721]: <info> [1705020140.0919] device (enp7s0): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
Jan 11 17:42:20 garrett-82xv NetworkManager[721]: <info> [1705020140.0918] manager: NetworkManager state is now ASLEEP
Jan 11 17:42:20 garrett-82xv NetworkManager[721]: <info> [1705020140.0912] device (wlp0s20f3): set-hw-addr: reset MAC address to C0:A5:E8:98:C3:C1 (unmanage)
Jan 11 17:42:20 garrett-82xv NetworkManager[721]: <info> [1705020140.0909] device (wlp0s20f3): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Jan 11 17:42:20 garrett-82xv NetworkManager[721]: <info> [1705020140.0907] manager: sleep: sleep requested (sleeping: no enabled: yes)
Jan 11 17:42:20 garrett-82xv ModemManager[802]: <msg> [sleep-monitor-systemd] system is about to suspend
Jan 11 17:42:20 garrett-82xv systemd-logind[733]: The system will suspend now!
Jan 11 17:42:16 garrett-82xv irqbalance[727]:
Jan 11 17:42:06 garrett-82xv irqbalance[727]: Selecting irq 130 for rebalancing
Jan 11 17:42:06 garrett-82xv irqbalance[727]: Selecting irq 151 for rebalancing
Jan 11 17:41:56 garrett-82xv irqbalance[727]: Selecting irq 135 for rebalancing
Jan 11 17:41:56 garrett-82xv irqbalance[727]: Selecting irq 151 for rebalancing
Jan 11 17:41:56 garrett-82xv irqbalance[727]: Selecting irq 130 for rebalancing
Jan 11 17:41:46 garrett-82xv irqbalance[727]: Selecting irq 126 for rebalancing
Jan 11 17:41:46 garrett-82xv irqbalance[727]: Selecting irq 136 for rebalancing
Jan 11 17:41:46 garrett-82xv irqbalance[727]: Selecting irq 151 for rebalancing
Jan 11 17:41:36 garrett-82xv irqbalance[727]: Selecting irq 128 for rebalancing
Jan 11 17:41:36 garrett-82xv irqbalance[727]: Selecting irq 134 for rebalancing
Jan 11 17:41:36 garrett-82xv irqbalance[727]: Selecting irq 136 for rebalancing
Jan 11 17:41:36 garrett-82xv irqbalance[727]: Selecting irq 126 for rebalancing
Jan 11 17:41:36 garrett-82xv irqbalance[727]: Selecting irq 131 for rebalancing
Jan 11 17:41:36 garrett-82xv irqbalance[727]: Selecting irq 135 for rebalancing
Jan 11 17:41:36 garrett-82xv irqbalance[727]: Selecting irq 151 for rebalancing
Jan 11 17:41:26 garrett-82xv irqbalance[727]:
Jan 11 17:41:16 garrett-82xv irqbalance[727]: Selecting irq 137 for rebalancing
Jan 11 17:41:16 garrett-82xv irqbalance[727]: Selecting irq 151 for rebalancing
Jan 11 17:41:06 garrett-82xv irqbalance[727]: Selecting irq 129 for rebalancing
Jan 11 17:41:06 garrett-82xv irqbalance[727]: Selecting irq 151 for rebalancing
Jan 11 17:40:56 garrett-82xv irqbalance[727]:
Jan 11 17:40:46 garrett-82xv irqbalance[727]: Selecting irq 131 for rebalancing
Jan 11 17:40:46 garrett-82xv irqbalance[727]: Selecting irq 129 for rebalancing
Jan 11 17:40:46 garrett-82xv irqbalance[727]: Selecting irq 151 for rebalancing
Jan 11 17:40:36 garrett-82xv irqbalance[727]: Selecting irq 129 for rebalancing
Jan 11 17:40:36 garrett-82xv irqbalance[727]: Selecting irq 127 for rebalancing
Jan 11 17:40:34 garrett-82xv rtkit-daemon[4594]: Supervising 1 threads of 1 processes of 1 users.
Jan 11 17:40:26 garrett-82xv irqbalance[727]:
Jan 11 17:40:16 garrett-82xv irqbalance[727]: Selecting irq 136 for rebalancing
Jan 11 17:40:16 garrett-82xv irqbalance[727]: Selecting irq 151 for rebalancing
Jan 11 17:40:06 garrett-82xv irqbalance[727]:
Jan 11 17:39:56 garrett-82xv irqbalance[727]: Selecting irq 134 for rebalancing
Jan 11 17:39:56 garrett-82xv irqbalance[727]: Selecting irq 132 for rebalancing
Jan 11 17:39:56 garrett-82xv irqbalance[727]: Selecting irq 129 for rebalancing
Jan 11 17:39:56 garrett-82xv irqbalance[727]: Selecting irq 128 for rebalancing
Jan 11 17:39:56 garrett-82xv irqbalance[727]: Selecting irq 136 for rebalancing
Jan 11 17:39:56 garrett-82xv irqbalance[727]: Selecting irq 135 for rebalancing
Jan 11 17:39:51 garrett-82xv rtkit-daemon[4594]: Supervising 1 threads of 1 processes of 1 users.
Jan 11 17:39:46 garrett-82xv irqbalance[727]:
Jan 11 17:39:36 garrett-82xv irqbalance[727]: Selecting irq 131 for rebalancing
Jan 11 17:39:36 garrett-82xv irqbalance[727]: Selecting irq 151 for rebalancing
Jan 11 17:39:26 garrett-82xv irqbalance[727]:
Jan 11 17:39:18 garrett-82xv systemd[4397]: app-systemsettings-7f8f10cb2ccc4a14a27ffaf208b8c266.scope: Consumed 2.184s CPU time.
Jan 11 17:39:16 garrett-82xv irqbalance[727]: Selecting irq 129 for rebalancing
Jan 11 17:39:16 garrett-82xv irqbalance[727]: Selecting irq 137 for rebalancing
Jan 11 17:39:16 garrett-82xv irqbalance[727]: Selecting irq 135 for rebalancing
Jan 11 17:39:16 garrett-82xv irqbalance[727]: Selecting irq 134 for rebalancing
Jan 11 17:39:16 garrett-82xv irqbalance[727]: Selecting irq 131 for rebalancing
Jan 11 17:39:16 garrett-82xv irqbalance[727]: Selecting irq 132 for rebalancing
Jan 11 17:39:16 garrett-82xv irqbalance[727]: Selecting irq 151 for rebalancing
Jan 11 17:39:08 garrett-82xv systemsettings[25729]: qml: The item SubCategoryPage_QMLTYPE_103(0x5649655a4fb0) is already in the PageRow
Jan 11 17:39:06 garrett-82xv irqbalance[727]:
Jan 11 17:38:56 garrett-82xv irqbalance[727]: Selecting irq 128 for rebalancing
Jan 11 17:38:48 garrett-82xv systemsettings[25729]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Jan 11 17:38:48 garrett-82xv systemsettings[25729]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ScrollablePage.qml:200:9: QML MouseArea: Binding loop detected for property "width"
Jan 11 17:38:48 garrett-82xv plasmashell[4811]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:286: Unable to assign [undefined] to QString
Jan 11 17:38:48 garrett-82xv systemd[4397]: Started System Settings - System Settings.
Jan 11 17:38:46 garrett-82xv irqbalance[727]: Selecting irq 126 for rebalancing
Jan 11 17:38:46 garrett-82xv irqbalance[727]: Selecting irq 135 for rebalancing
Jan 11 17:38:46 garrett-82xv irqbalance[727]: Selecting irq 151 for rebalancing
Jan 11 17:38:36 garrett-82xv irqbalance[727]: Selecting irq 136 for rebalancing
Jan 11 17:38:36 garrett-82xv irqbalance[727]: Selecting irq 135 for rebalancing
Jan 11 17:38:36 garrett-82xv irqbalance[727]: Selecting irq 134 for rebalancing
Jan 11 17:38:27 garrett-82xv rtkit-daemon[4594]: Supervising 1 threads of 1 processes of 1 users.
Jan 11 17:38:26 garrett-82xv irqbalance[727]: Selecting irq 127 for rebalancing
Jan 11 17:38:26 garrett-82xv irqbalance[727]: Selecting irq 136 for rebalancing
Jan 11 17:38:26 garrett-82xv irqbalance[727]: Selecting irq 133 for rebalancing
Jan 11 17:38:26 garrett-82xv irqbalance[727]: Selecting irq 126 for rebalancing
Jan 11 17:38:26 garrett-82xv irqbalance[727]: Selecting irq 151 for rebalancing
Jan 11 17:38:17 garrett-82xv sudo[25005]: pam_unix(sudo:session): session closed for user root
Jan 11 17:38:17 garrett-82xv sudo[25005]: pam_unix(sudo:session): session opened for user root(uid=0) by garrett(uid=1000)
Jan 11 17:38:17 garrett-82xv sudo[25005]: garrett : TTY=pts/0 ; PWD=/home/garrett ; USER=root ; COMMAND=/usr/bin/true
Jan 11 17:38:17 garrett-82xv sudo[24366]: pam_unix(sudo:session): session closed for user root
Jan 11 17:38:16 garrett-82xv irqbalance[727]: Selecting irq 135 for rebalancing
Jan 11 17:38:16 garrett-82xv irqbalance[727]: Selecting irq 132 for rebalancing
Jan 11 17:38:16 garrett-82xv irqbalance[727]: Selecting irq 134 for rebalancing
Jan 11 17:38:16 garrett-82xv irqbalance[727]: Selecting irq 151 for rebalancing
Jan 11 17:38:11 garrett-82xv sudo[24366]: pam_unix(sudo:session): session opened for user root(uid=0) by garrett(uid=1000)
Jan 11 17:38:11 garrett-82xv sudo[24366]: garrett : TTY=pts/0 ; PWD=/home/garrett ; USER=root ; COMMAND=/usr/bin/nano /etc/dracut.conf.d/resume.conf
Jan 11 17:38:06 garrett-82xv irqbalance[727]: Selecting irq 130 for rebalancing
Jan 11 17:38:06 garrett-82xv irqbalance[727]: Selecting irq 126 for rebalancing
Jan 11 17:38:06 garrett-82xv irqbalance[727]: Selecting irq 136 for rebalancing
Jan 11 17:38:06 garrett-82xv irqbalance[727]: Selecting irq 133 for rebalancing
Jan 11 17:38:06 garrett-82xv irqbalance[727]: Selecting irq 151 for rebalancing
Jan 11 17:38:01 garrett-82xv systemd[1]: systemd-timedated.service: Deactivated successfully.
Jan 11 17:37:57 garrett-82xv systemd-timesyncd[707]: Initial clock synchronization to Thu 2024-01-11 17:37:57.486116 MST.
Jan 11 17:37:57 garrett-82xv systemd-timesyncd[707]: Contacted time server 129.146.193.200:123 (0.arch.pool.ntp.org).
Jan 11 17:37:57 garrett-82xv irqbalance[727]:
Jan 11 17:37:54 garrett-82xv sudo[23716]: pam_unix(sudo:session): session closed for user root
Jan 11 17:37:54 garrett-82xv sudo[23716]: pam_unix(sudo:session): session opened for user root(uid=0) by garrett(uid=1000)
Jan 11 17:37:54 garrett-82xv sudo[23716]: garrett : TTY=pts/0 ; PWD=/home/garrett ; USER=root ; COMMAND=/usr/bin/true
Jan 11 17:37:54 garrett-82xv sudo[9092]: pam_unix(sudo:session): session closed for user root
Jan 11 17:37:47 garrett-82xv irqbalance[727]: Selecting irq 151 for rebalancing
Jan 11 17:37:39 garrett-82xv systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Jan 11 17:37:37 garrett-82xv irqbalance[727]: Selecting irq 128 for rebalancing
Jan 11 17:37:35 garrett-82xv rtkit-daemon[4594]: Supervising 1 threads of 1 processes of 1 users.
Jan 11 17:37:34 garrett-82xv kwin_x11[4672]: kwin_core: XCB error: 152 (BadDamage), sequence: 17549, resource id: 16778106, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Jan 11 17:37:33 garrett-82xv rtkit-daemon[4594]: Supervising 1 threads of 1 processes of 1 users.
Jan 11 17:37:33 garrett-82xv gmenudbusmenuproxy[4850]: kde.dbusmenuproxy: Got an empty menu for 0 on ":1.55" at "/org/appmenu/gtk/window/2"
Jan 11 17:37:32 garrett-82xv rtkit-daemon[4594]: Supervising 1 threads of 1 processes of 1 users.
Jan 11 17:37:32 garrett-82xv rtkit-daemon[4594]: Successfully made thread 17346 of process 16912 owned by '1000' RT at priority 10.
Jan 11 17:37:32 garrett-82xv rtkit-daemon[4594]: Supervising 0 threads of 0 processes of 0 users.
Jan 11 17:37:32 garrett-82xv systemd[1]: Started Time & Date Service.
Jan 11 17:37:31 garrett-82xv systemd[1]: Starting Time & Date Service...
Jan 11 17:37:31 garrett-82xv plasmashell[4811]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:286: Unable to assign [undefined] to QString
Jan 11 17:37:31 garrett-82xv systemd[4397]: Started FireDragon - Web Browser.
Jan 11 17:37:29 garrett-82xv NetworkManager[721]: <info> [1705019849.9366] manager: NetworkManager state is now CONNECTED_GLOBAL
Jan 11 17:37:29 garrett-82xv plasmashell[4811]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x564e462dd130) QQmlContext(0x564e44600a70) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Jan 11 17:37:29 garrett-82xv NetworkManager[721]: <info> [1705019849.6241] device (enp7s0): Activation: successful, device activated.
Jan 11 17:37:29 garrett-82xv NetworkManager[721]: <info> [1705019849.6239] manager: NetworkManager state is now CONNECTED_SITE
Jan 11 17:37:29 garrett-82xv NetworkManager[721]: <info> [1705019849.6238] device (enp7s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Jan 11 17:37:29 garrett-82xv NetworkManager[721]: <info> [1705019849.6237] device (enp7s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Jan 11 17:37:29 garrett-82xv systemd[1]: Started Network Manager Script Dispatcher Service.
Jan 11 17:37:29 garrett-82xv systemd[1]: Starting Network Manager Script Dispatcher Service...
Jan 11 17:37:29 garrett-82xv NetworkManager[721]: <info> [1705019849.5645] device (enp7s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Jan 11 17:37:29 garrett-82xv avahi-daemon[722]: Registering new address record for 192.168.0.7 on enp7s0.IPv4.
Jan 11 17:37:29 garrett-82xv avahi-daemon[722]: New relevant interface enp7s0.IPv4 for mDNS.
Jan 11 17:37:29 garrett-82xv avahi-daemon[722]: Joining mDNS multicast group on interface enp7s0.IPv4 with address 192.168.0.7.
Jan 11 17:37:29 garrett-82xv dbus-broker-launch[718]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
Jan 11 17:37:29 garrett-82xv NetworkManager[721]: <info> [1705019849.5577] policy: set 'Wired connection 1' (enp7s0) as default for IPv4 routing and DNS
Jan 11 17:37:29 garrett-82xv NetworkManager[721]: <info> [1705019849.5575] dhcp4 (enp7s0): state changed new lease, address=192.168.0.7
Jan 11 17:37:29 garrett-82xv avahi-daemon[722]: Registering new address record for fe80::c65:aa6d:103d:a42b on enp7s0.*.
Jan 11 17:37:29 garrett-82xv avahi-daemon[722]: New relevant interface enp7s0.IPv6 for mDNS.
Jan 11 17:37:29 garrett-82xv avahi-daemon[722]: Joining mDNS multicast group on interface enp7s0.IPv6 with address fe80::c65:aa6d:103d:a42b.
Jan 11 17:37:29 garrett-82xv NetworkManager[721]: <info> [1705019849.5546] dhcp4 (enp7s0): activation: beginning transaction (timeout in 45 seconds)
Jan 11 17:37:29 garrett-82xv NetworkManager[721]: <info> [1705019849.5544] device (enp7s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Jan 11 17:37:29 garrett-82xv NetworkManager[721]: <info> [1705019849.5540] device (enp7s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Jan 11 17:37:29 garrett-82xv NetworkManager[721]: <info> [1705019849.5540] manager: NetworkManager state is now CONNECTING
Jan 11 17:37:29 garrett-82xv NetworkManager[721]: <info> [1705019849.5539] device (enp7s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Jan 11 17:37:29 garrett-82xv NetworkManager[721]: <info> [1705019849.5538] device (enp7s0): Activation: starting connection 'Wired connection 1' (2453bcb9-1d1d-3faf-989a-3ba2cfd0738d)
Jan 11 17:37:29 garrett-82xv NetworkManager[721]: <info> [1705019849.5536] policy: auto-activating connection 'Wired connection 1' (2453bcb9-1d1d-3faf-989a-3ba2cfd0738d)
Jan 11 17:37:29 garrett-82xv NetworkManager[721]: <info> [1705019849.5531] device (enp7s0): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
Jan 11 17:37:29 garrett-82xv kernel: r8169 0000:07:00.0 enp7s0: Link is Up - 1Gbps/Full - flow control rx/tx
Jan 11 17:37:29 garrett-82xv NetworkManager[721]: <info> [1705019849.5529] device (enp7s0): carrier: link connected
Jan 11 17:37:27 garrett-82xv irqbalance[727]: Selecting irq 128 for rebalancing
Jan 11 17:37:17 garrett-82xv irqbalance[727]: Selecting irq 131 for rebalancing
Jan 11 17:37:17 garrett-82xv irqbalance[727]: Selecting irq 137 for rebalancing
Jan 11 17:37:17 garrett-82xv irqbalance[727]: Selecting irq 133 for rebalancing
Jan 11 17:37:17 garrett-82xv irqbalance[727]: Selecting irq 126 for rebalancing
Jan 11 17:37:07 garrett-82xv kernel: block nvme0n1: the capability attribute has been deprecated.
Jan 11 17:37:07 garrett-82xv irqbalance[727]: Selecting irq 124 for rebalancing
Jan 11 17:37:07 garrett-82xv irqbalance[727]: Selecting irq 129 for rebalancing
Jan 11 17:37:07 garrett-82xv irqbalance[727]: Selecting irq 134 for rebalancing
Jan 11 17:37:07 garrett-82xv irqbalance[727]: Selecting irq 132 for rebalancing
Jan 11 17:37:07 garrett-82xv irqbalance[727]: Selecting irq 135 for rebalancing
Jan 11 17:37:07 garrett-82xv irqbalance[727]: Selecting irq 136 for rebalancing
Jan 11 17:37:05 garrett-82xv sudo[9092]: pam_unix(sudo:session): session opened for user root(uid=0) by garrett(uid=1000)
Jan 11 17:37:05 garrett-82xv sudo[9092]: garrett : TTY=pts/0 ; PWD=/home/garrett ; USER=root ; COMMAND=/usr/bin/dracut-rebuild
Jan 11 17:37:00 garrett-82xv sudo[9067]: pam_unix(sudo:session): session closed for user root
Jan 11 17:37:00 garrett-82xv sudo[9067]: pam_unix(sudo:session): session opened for user root(uid=0) by garrett(uid=1000)
Jan 11 17:37:00 garrett-82xv sudo[9067]: garrett : TTY=pts/0 ; PWD=/home/garrett ; USER=root ; COMMAND=/usr/bin/true
Jan 11 17:37:00 garrett-82xv sudo[9054]: pam_unix(sudo:session): session closed for user root
Jan 11 17:36:58 garrett-82xv sudo[9054]: pam_unix(sudo:session): session opened for user root(uid=0) by garrett(uid=1000)
Jan 11 17:36:58 garrett-82xv sudo[9054]: garrett : TTY=pts/0 ; PWD=/home/garrett ; USER=root ; COMMAND=/usr/bin/nano /etc/dracut.conf.d/resume.conf
Jan 11 17:36:57 garrett-82xv irqbalance[727]: Selecting irq 136 for rebalancing
Jan 11 17:36:56 garrett-82xv systemd[1]: libvirtd.service: Deactivated successfully.
Jan 11 17:36:55 garrett-82xv sudo[8384]: pam_unix(sudo:session): session closed for user root
Jan 11 17:36:55 garrett-82xv sudo[8384]: pam_unix(sudo:session): session opened for user root(uid=0) by garrett(uid=1000)
Jan 11 17:36:55 garrett-82xv sudo[8384]: garrett : TTY=pts/0 ; PWD=/home/garrett ; USER=root ; COMMAND=/usr/bin/true
Jan 11 17:36:55 garrett-82xv sudo[6157]: pam_unix(sudo:session): session closed for user root
Jan 11 17:36:47 garrett-82xv irqbalance[727]: Selecting irq 132 for rebalancing
Jan 11 17:36:47 garrett-82xv irqbalance[727]: Selecting irq 128 for rebalancing
Jan 11 17:36:47 garrett-82xv irqbalance[727]: Selecting irq 134 for rebalancing
Jan 11 17:36:47 garrett-82xv irqbalance[727]: Selecting irq 131 for rebalancing
Jan 11 17:36:47 garrett-82xv irqbalance[727]: Selecting irq 135 for rebalancing
Jan 11 17:36:37 garrett-82xv irqbalance[727]:
Jan 11 17:36:32 garrett-82xv systemd[1]: Startup finished in 4.470s (firmware) + 7.906s (loader) + 527ms (kernel) + 2.161s (initrd) + 1min 38.077s (userspace) = 1min 53.144s.
Jan 11 17:36:32 garrett-82xv systemd[1]: Reached target Graphical Interface.
Jan 11 17:36:32 garrett-82xv systemd[1]: Reached target Multi-User System.
Jan 11 17:36:32 garrett-82xv systemd[1]: Started Samba SMB Daemon.
Jan 11 17:36:32 garrett-82xv smbd[7723]: Copyright Andrew Tridgell and the Samba Team 1992-2023
Jan 11 17:36:32 garrett-82xv smbd[7723]: smbd version 4.19.4 started.
Jan 11 17:36:32 garrett-82xv smbd[7723]: [2024/01/11 17:36:32.862458, 0] ../../source3/smbd/server.c:1746(main)
Jan 11 17:36:32 garrett-82xv systemd[1]: Starting Samba SMB Daemon...
Jan 11 17:36:32 garrett-82xv systemd[1]: Failed to start Samba NMB Daemon.
Jan 11 17:36:32 garrett-82xv systemd[1]: nmb.service: Failed with result 'timeout'.
Jan 11 17:36:32 garrett-82xv systemd[1]: nmb.service: start operation timed out. Terminating.
Jan 11 17:36:27 garrett-82xv irqbalance[727]: Selecting irq 124 for rebalancing
Jan 11 17:36:27 garrett-82xv irqbalance[727]: Selecting irq 126 for rebalancing
Jan 11 17:36:27 garrett-82xv irqbalance[727]: Selecting irq 130 for rebalancing
Jan 11 17:36:17 garrett-82xv irqbalance[727]: Selecting irq 124 for rebalancing
Jan 11 17:36:17 garrett-82xv irqbalance[727]: Selecting irq 131 for rebalancing
Jan 11 17:36:17 garrett-82xv irqbalance[727]: Selecting irq 136 for rebalancing
Jan 11 17:36:07 garrett-82xv irqbalance[727]: Selecting irq 124 for rebalancing
Jan 11 17:36:07 garrett-82xv irqbalance[727]: Selecting irq 132 for rebalancing
Apparently there’s a character limit for the posts. Here’s the second half:
Jan 11 17:35:57 garrett-82xv irqbalance[727]: Selecting irq 124 for rebalancing
Jan 11 17:35:57 garrett-82xv irqbalance[727]: Selecting irq 125 for rebalancing
Jan 11 17:35:57 garrett-82xv irqbalance[727]: Selecting irq 131 for rebalancing
Jan 11 17:35:57 garrett-82xv irqbalance[727]: Selecting irq 128 for rebalancing
Jan 11 17:35:57 garrett-82xv irqbalance[727]: Selecting irq 134 for rebalancing
Jan 11 17:35:57 garrett-82xv irqbalance[727]: Selecting irq 136 for rebalancing
Jan 11 17:35:57 garrett-82xv irqbalance[727]: Selecting irq 132 for rebalancing
Jan 11 17:35:54 garrett-82xv sudo[6157]: pam_unix(sudo:session): session opened for user root(uid=0) by garrett(uid=1000)
Jan 11 17:35:54 garrett-82xv sudo[6157]: garrett : TTY=pts/0 ; PWD=/home/garrett ; USER=root ; COMMAND=/usr/bin/nano /etc/dracut.conf.d/resume.conf
Jan 11 17:35:53 garrett-82xv systemd[1]: run-snapper\x2dtools\x2drLTgJY.mount: Deactivated successfully.
Jan 11 17:35:53 garrett-82xv kernel: BTRFS info: devid 1 device path /dev/nvme0n1p2 changed to /dev/disk/by-uuid/295cb0e5-646b-4f62-be41-46c327e38c7a scanned by Thread (pooled) (6176)
Jan 11 17:35:53 garrett-82xv pkexec[6167]: garrett: Executing command [USER=root] [TTY=unknown] [CWD=/home/garrett] [COMMAND=/usr/bin/snapper-tools find-old]
Jan 11 17:35:53 garrett-82xv pkexec[6167]: pam_unix(polkit-1:session): session opened for user root(uid=0) by garrett(uid=1000)
Jan 11 17:35:47 garrett-82xv irqbalance[727]: IRQ 129 affinity is now unmanaged
Jan 11 17:35:47 garrett-82xv irqbalance[727]: Cannot change IRQ 129 affinity: Input/output error
Jan 11 17:35:47 garrett-82xv irqbalance[727]: Selecting irq 124 for rebalancing
Jan 11 17:35:47 garrett-82xv irqbalance[727]: Selecting irq 134 for rebalancing
Jan 11 17:35:47 garrett-82xv irqbalance[727]: Selecting irq 129 for rebalancing
Jan 11 17:35:47 garrett-82xv irqbalance[727]: Selecting irq 137 for rebalancing
Jan 11 17:35:47 garrett-82xv irqbalance[727]: Selecting irq 136 for rebalancing
Jan 11 17:35:37 garrett-82xv irqbalance[727]: Selecting irq 133 for rebalancing
Jan 11 17:35:37 garrett-82xv irqbalance[727]: Selecting irq 136 for rebalancing
Jan 11 17:35:37 garrett-82xv irqbalance[727]: Selecting irq 126 for rebalancing
Jan 11 17:35:37 garrett-82xv irqbalance[727]: Selecting irq 128 for rebalancing
Jan 11 17:35:37 garrett-82xv irqbalance[727]: Selecting irq 137 for rebalancing
Jan 11 17:35:37 garrett-82xv irqbalance[727]: Selecting irq 134 for rebalancing
Jan 11 17:35:37 garrett-82xv irqbalance[727]: Selecting irq 127 for rebalancing
Jan 11 17:35:36 garrett-82xv systemd[1]: dbus-:1.3-org.kde.powerdevil.backlighthelper@0.service: Deactivated successfully.
Jan 11 17:35:33 garrett-82xv systemd[1]: dbus-:1.3-org.kde.powerdevil.chargethresholdhelper@0.service: Deactivated successfully.
Jan 11 17:35:32 garrett-82xv systemd[1]: dbus-:1.3-org.kde.powerdevil.discretegpuhelper@0.service: Deactivated successfully.
Jan 11 17:35:32 garrett-82xv systemd[1]: user-954.slice: Consumed 1.616s CPU time.
Jan 11 17:35:32 garrett-82xv systemd[1]: Removed slice User Slice of UID 954.
Jan 11 17:35:32 garrett-82xv systemd[1]: Stopped User Runtime Directory /run/user/954.
Jan 11 17:35:32 garrett-82xv systemd[1]: user-runtime-dir@954.service: Deactivated successfully.
Jan 11 17:35:32 garrett-82xv systemd[1]: run-user-954.mount: Deactivated successfully.
Jan 11 17:35:32 garrett-82xv systemd[1]: Stopping User Runtime Directory /run/user/954...
Jan 11 17:35:32 garrett-82xv systemd[1]: user@954.service: Consumed 1.241s CPU time.
Jan 11 17:35:32 garrett-82xv systemd[1]: Stopped User Manager for UID 954.
Jan 11 17:35:32 garrett-82xv systemd[1]: user@954.service: Deactivated successfully.
Jan 11 17:35:32 garrett-82xv (sd-pam)[2566]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
Jan 11 17:35:31 garrett-82xv systemd[2565]: Reached target Exit the Session.
Jan 11 17:35:31 garrett-82xv systemd[2565]: Finished Exit the Session.
Jan 11 17:35:31 garrett-82xv systemd[2565]: Reached target Shutdown.
Jan 11 17:35:31 garrett-82xv systemd[2565]: app.slice: Consumed 1.114s CPU time.
Jan 11 17:35:31 garrett-82xv systemd[2565]: Removed slice User Application Slice.
Jan 11 17:35:31 garrett-82xv systemd[2565]: Closed D-Bus User Message Bus Socket.
Jan 11 17:35:31 garrett-82xv systemd[2565]: Removed slice User Core Session Slice.
Jan 11 17:35:31 garrett-82xv systemd[2565]: Stopped D-Bus User Message Bus.
Jan 11 17:35:31 garrett-82xv systemd[2565]: Stopping D-Bus User Message Bus...
Jan 11 17:35:31 garrett-82xv dbus-broker[2624]: Dispatched 718 messages @ 1(±1)μs / message.
Jan 11 17:35:31 garrett-82xv systemd[2565]: Closed PipeWire Multimedia System Sockets.
Jan 11 17:35:31 garrett-82xv systemd[2565]: Closed PipeWire PulseAudio.
Jan 11 17:35:31 garrett-82xv systemd[2565]: Closed p11-kit server.
Jan 11 17:35:31 garrett-82xv systemd[2565]: Closed GnuPG public key management service.
Jan 11 17:35:31 garrett-82xv systemd[2565]: Closed GnuPG cryptographic agent and passphrase cache.
Jan 11 17:35:31 garrett-82xv systemd[2565]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Jan 11 17:35:31 garrett-82xv systemd[2565]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Jan 11 17:35:31 garrett-82xv systemd[2565]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Jan 11 17:35:31 garrett-82xv systemd[2565]: Closed GNOME Keyring daemon.
Jan 11 17:35:31 garrett-82xv systemd[2565]: Closed GCR ssh-agent wrapper.
Jan 11 17:35:31 garrett-82xv systemd[2565]: Closed GnuPG network certificate management daemon.
Jan 11 17:35:31 garrett-82xv systemd[2565]: Stopped Timer for profile-sync-daemon - 1Hour.
Jan 11 17:35:31 garrett-82xv systemd[2565]: Stopped target Timers.
Jan 11 17:35:31 garrett-82xv systemd[2565]: Stopped target Sockets.
Jan 11 17:35:31 garrett-82xv systemd[2565]: Stopped target Paths.
Jan 11 17:35:31 garrett-82xv systemd[2565]: Stopped target Basic System.
Jan 11 17:35:31 garrett-82xv systemd[2565]: Stopped Profile-sync-daemon.
Jan 11 17:35:31 garrett-82xv systemd[2565]: Stopping Profile-sync-daemon...
Jan 11 17:35:31 garrett-82xv systemd[2565]: Stopped target Main User Target.
Jan 11 17:35:31 garrett-82xv systemd[2565]: Activating special unit Exit the Session...
Jan 11 17:35:31 garrett-82xv systemd[1]: Stopping User Manager for UID 954...
Jan 11 17:35:28 garrett-82xv plasmashell[4811]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Jan 11 17:35:28 garrett-82xv sudo[5277]: garrett : a password is required ; TTY=pts/0 ; PWD=/home/garrett ; USER=root ; COMMAND=/usr/bin/true
Jan 11 17:35:28 garrett-82xv kwin_x11[4672]: Module 'org.kde.kwin.decoration' does not contain a module identifier directive - it cannot be protected from external registrations.
Jan 11 17:35:28 garrett-82xv plasmashell[4811]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Jan 11 17:35:28 garrett-82xv plasmashell[4811]: file:///usr/share/plasma/plasmoids/org.kde.plasma.betterinlineclock/contents/ui/CalendarView.qml:86:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 11 17:35:28 garrett-82xv plasmashell[4811]: file:///usr/share/plasma/plasmoids/org.kde.plasma.betterinlineclock/contents/ui/CalendarView.qml:101:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 11 17:35:28 garrett-82xv plasmashell[4811]: file:///usr/share/plasma/plasmoids/org.kde.plasma.betterinlineclock/contents/ui/CalendarView.qml:115:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 11 17:35:28 garrett-82xv plasmashell[4811]: Both point size and pixel size set. Using pixel size.
Jan 11 17:35:28 garrett-82xv plasmashell[4811]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:286: Unable to assign [undefined] to QString
Jan 11 17:35:27 garrett-82xv systemd[4397]: Started Konsole - Terminal.
Jan 11 17:35:27 garrett-82xv irqbalance[727]: Selecting irq 124 for rebalancing
Jan 11 17:35:27 garrett-82xv irqbalance[727]: Selecting irq 134 for rebalancing
Jan 11 17:35:26 garrett-82xv plasmashell[4811]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Jan 11 17:35:26 garrett-82xv systemd[1]: systemd-hostnamed.service: Deactivated successfully.
Jan 11 17:35:25 garrett-82xv plasmashell[4811]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Jan 11 17:35:24 garrett-82xv plasmashell[4811]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Jan 11 17:35:24 garrett-82xv plasmashell[4811]: qml: recreating buttons
Jan 11 17:35:24 garrett-82xv plasmashell[4811]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Jan 11 17:35:24 garrett-82xv plasmashell[4811]: file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/main.qml:95: TypeError: Cannot read property 'airplaneModeAvailable' of null
Jan 11 17:35:24 garrett-82xv plasmashell[4811]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Jan 11 17:35:24 garrett-82xv plasmashell[4811]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
Jan 11 17:35:24 garrett-82xv kwin_x11[4672]: kwin_core: XCB error: 152 (BadDamage), sequence: 2075, resource id: 16777239, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Jan 11 17:35:24 garrett-82xv systemd[4397]: Started PipeWire PulseAudio.
Jan 11 17:35:23 garrett-82xv plasmashell[4811]: file:///usr/lib/qt/qml/org/kde/kirigami.2/Avatar.qml:289:9: QML Image: Cannot open: file:///usr/share/plasma/plasmoids/org.kde.plasma.userswitcher/contents/ui/user-identity
Jan 11 17:35:23 garrett-82xv plasmashell[4811]: file:///usr/share/plasma/plasmoids/org.kde.plasma.betterinlineclock/contents/ui/DigitalClock.qml:76:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 11 17:35:23 garrett-82xv plasmashell[4811]: file:///usr/share/plasma/plasmoids/org.kde.plasma.betterinlineclock/contents/ui/DigitalClock.qml:82:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 11 17:35:23 garrett-82xv plasmashell[4811]: Both point size and pixel size set. Using pixel size.
Jan 11 17:35:23 garrett-82xv plasmashell[4811]: Loading Calendar plugin HolidaysEventsPlugin(0x564e4406fc90)
Jan 11 17:35:23 garrett-82xv plasmashell[4811]: Loading Calendar plugin AstronomicalEventsPlugin(0x564e44068300)
Jan 11 17:35:23 garrett-82xv plasmashell[4811]: Loading Calendar plugin AlternateCalendarPlugin(0x564e440761d0)
Jan 11 17:35:23 garrett-82xv plasmashell[4811]: file:///usr/share/plasma/plasmoids/org.kde.plasma.betterinlineclock/contents/ui/main.qml:70:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 11 17:35:23 garrett-82xv plasmashell[4811]: file:///usr/share/plasma/plasmoids/org.kde.windowappmenu/contents/ui/Broadcaster.qml:128:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 11 17:35:23 garrett-82xv plasmashell[4811]: file:///usr/share/plasma/plasmoids/org.kde.windowappmenu/contents/ui/Broadcaster.qml:141:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 11 17:35:23 garrett-82xv plasmashell[4811]: file:///usr/share/plasma/plasmoids/org.kde.windowbuttons/contents/ui/main.qml:246:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 11 17:35:23 garrett-82xv plasmashell[4811]: file:///usr/share/plasma/plasmoids/org.kde.windowbuttons/contents/ui/main.qml:251:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jan 11 17:35:23 garrett-82xv plasmashell[4811]: /////////////////////////
Jan 11 17:35:23 garrett-82xv plasmashell[4811]: "Plasma Desktop version: 5.27.10 (334602)"
Jan 11 17:35:23 garrett-82xv plasmashell[4811]: no offers
Jan 11 17:35:23 garrett-82xv plasmashell[4811]: Calling KPluginInfo::property("X-KDE-PluginInfo-Name") is deprecated, use KPluginInfo::pluginName() in "/usr/lib/qt/plugins/org.kde.kdecoration2/breezedecoration.so" instead.
Jan 11 17:35:23 garrett-82xv plasmashell[4811]: Plugin changed to: "org.kde.kwin.aurorae"
Jan 11 17:35:23 garrett-82xv plasmashell[4811]: Window Buttons : plasma theme default colors ::: "/tmp/plasmashell-jHPMeX/default.colors"
Jan 11 17:35:23 garrett-82xv plasmashell[4811]: Window Buttons : plasma theme original colors ::: "/usr/share/plasma/desktoptheme/Dr460nized/colors"
Jan 11 17:35:23 garrett-82xv plasmashell[4811]: Window Buttons : theme widgets path ::: "/usr/share/plasma/desktoptheme/Dr460nized/widgets"
Jan 11 17:35:23 garrett-82xv plasmashell[4811]: Window Buttons : theme path ::: "/usr/share/plasma/desktoptheme/Dr460nized"
Jan 11 17:35:23 garrett-82xv plasmashell[4811]: Window Buttons : current plasma theme ::: "Dr460nized"
Jan 11 17:35:23 garrett-82xv plasmashell[4811]: kf.coreaddons: KPluginFactory could not create a KDecoration2::DecorationThemeProvider instance from "/usr/lib/qt/plugins/org.kde.kdecoration2/breezedecoration.so"
Jan 11 17:35:23 garrett-82xv plasmashell[4811]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Jan 11 17:35:23 garrett-82xv displaycal-apply-profiles[4984]: dispwin exitcode: 1
Jan 11 17:35:23 garrett-82xv displaycal-apply-profiles[4984]: Dispwin: Error - Failed to get the displays current ICC profile
Jan 11 17:35:23 garrett-82xv displaycal-apply-profiles[4984]: Dispwin: Warning - new_dispwin: Expected VideoLUT depth 11 doesn't match actual 10
Jan 11 17:35:23 garrett-82xv displaycal-apply-profiles[4984]: About to open dispwin object on the display
Jan 11 17:35:23 garrett-82xv displaycal-apply-profiles[4984]: -L
Jan 11 17:35:23 garrett-82xv displaycal-apply-profiles[4984]: -d1
Jan 11 17:35:23 garrett-82xv displaycal-apply-profiles[4984]: -v
Jan 11 17:35:23 garrett-82xv displaycal-apply-profiles[4984]: /usr/bin/dispwin
Jan 11 17:35:23 garrett-82xv displaycal-apply-profiles[4984]: Command line:
Jan 11 17:35:23 garrett-82xv displaycal-apply-profiles[4984]: --------------------------------------------------------------------------------
Jan 11 17:35:23 garrett-82xv displaycal-apply-profiles[4984]: ...ok.
Jan 11 17:35:23 garrett-82xv displaycal-apply-profiles[4984]: Argyll has virtual display support
Jan 11 17:35:23 garrett-82xv displaycal-apply-profiles[4984]: ArgyllCMS 3.1.0
Jan 11 17:35:23 garrett-82xv displaycal-apply-profiles[4984]: Enumerating display devices and communication ports...
Jan 11 17:35:23 garrett-82xv displaycal-apply-profiles[4984]: Loading calibration curves of current display device profile...
Jan 11 17:35:23 garrett-82xv displaycal-apply-profiles[4984]: ================================================================================
Jan 11 17:35:23 garrett-82xv displaycal-apply-profiles[4984]: Loading /home/garrett/.config/DisplayCAL/DisplayCAL.ini
Jan 11 17:35:23 garrett-82xv kioslave5[5109]: QObject::connect: No such slot DesktopProtocol::_k_slotRedirection(KIO::Job *, QUrl)
Jan 11 17:35:23 garrett-82xv at-spi2-registryd[5133]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
Jan 11 17:35:23 garrett-82xv systemd[4397]: Started dbus-:1.3-org.freedesktop.Notifications@0.service.
Jan 11 17:35:23 garrett-82xv systemd[4397]: Created slice Slice /app/dbus-:1.3-org.freedesktop.Notifications.
Jan 11 17:35:23 garrett-82xv kdeconnectd[4973]: Error sending UDP packet: QAbstractSocket::NetworkError
Jan 11 17:35:23 garrett-82xv systemd[4397]: Started dbus-:1.46-org.a11y.atspi.Registry@0.service.
Jan 11 17:35:23 garrett-82xv kded5[4671]: Registering ":1.36/org/ayatana/NotificationItem/remmina_icon" to system tray
Jan 11 17:35:23 garrett-82xv systemd[4397]: Created slice Slice /app/dbus-:1.46-org.a11y.atspi.Registry.
Jan 11 17:35:23 garrett-82xv dbus-broker-launch[5124]: Ready
Jan 11 17:35:23 garrett-82xv at-spi-bus-launcher[5124]: Policy to allow eavesdropping in /usr/share/defaults/at-spi2/accessibility.conf +17: Eavesdropping is deprecated and ignored
Jan 11 17:35:23 garrett-82xv at-spi-bus-launcher[5124]: Policy to allow eavesdropping in /usr/share/defaults/at-spi2/accessibility.conf +15: Eavesdropping is deprecated and ignored
Jan 11 17:35:23 garrett-82xv systemd[4397]: Started Accessibility services bus.
Jan 11 17:35:23 garrett-82xv systemd[4397]: Starting Accessibility services bus...
Jan 11 17:35:23 garrett-82xv kaccess[4999]: X server XKB extension major= 1 minor= 0
Jan 11 17:35:23 garrett-82xv systemd[4397]: psd-resync.service: Consumed 1.026s CPU time.
Jan 11 17:35:23 garrett-82xv systemd[4397]: Startup finished in 1.906s.
Jan 11 17:35:23 garrett-82xv systemd[4397]: Finished Timed resync.
Jan 11 17:35:23 garrett-82xv kded5[4671]: Registering ":1.42/StatusNotifierItem" to system tray
Jan 11 17:35:23 garrett-82xv wireplumber[4918]: <WpPortalPermissionStorePlugin:0x5618c26d01e0> Failed to call Lookup: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for camera
Jan 11 17:35:23 garrett-82xv pipewire[4917]: [0:00:31.036099330] [4917] INFO Camera camera_manager.cpp:284 libcamera v0.1.0
Jan 11 17:35:23 garrett-82xv pipewire[4917]: [0:00:31.036071814] [4917] ERROR IPAModule ipa_module.cpp:292 v4l2-compat.so: IPA module has no valid info
Jan 11 17:35:23 garrett-82xv pipewire[4917]: [0:00:31.036049703] [4917] ERROR IPAModule ipa_module.cpp:172 Symbol ipaModuleInfo not found
Jan 11 17:35:23 garrett-82xv bluetoothd[723]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSource/opus_05_duplex
Jan 11 17:35:23 garrett-82xv bluetoothd[723]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSink/opus_05_duplex
Jan 11 17:35:23 garrett-82xv bluetoothd[723]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSource/faststream_duplex
Jan 11 17:35:23 garrett-82xv bluetoothd[723]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
Jan 11 17:35:23 garrett-82xv bluetoothd[723]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
Jan 11 17:35:23 garrett-82xv bluetoothd[723]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSource/aptx_ll_0
Jan 11 17:35:23 garrett-82xv bluetoothd[723]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSource/aptx_ll_1
Jan 11 17:35:23 garrett-82xv bluetoothd[723]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSource/sbc_xq
Jan 11 17:35:23 garrett-82xv bluetoothd[723]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSink/sbc_xq
Jan 11 17:35:23 garrett-82xv bluetoothd[723]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSource/aac
Jan 11 17:35:23 garrett-82xv bluetoothd[723]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSink/aac
Jan 11 17:35:23 garrett-82xv bluetoothd[723]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSink/aptx
Jan 11 17:35:23 garrett-82xv bluetoothd[723]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSource/aptx_hd
Jan 11 17:35:23 garrett-82xv bluetoothd[723]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSink/aptx_hd
Jan 11 17:35:23 garrett-82xv bluetoothd[723]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSource/ldac
Jan 11 17:35:23 garrett-82xv kernel: Bluetooth: RFCOMM ver 1.11
Jan 11 17:35:23 garrett-82xv kernel: Bluetooth: RFCOMM socket layer initialized
Jan 11 17:35:23 garrett-82xv kernel: Bluetooth: RFCOMM TTY layer initialized
Jan 11 17:35:23 garrett-82xv systemd[1]: Started Manage, Install and Generate Color Profiles.
Jan 11 17:35:23 garrett-82xv systemd[1]: Starting Manage, Install and Generate Color Profiles...
Jan 11 17:35:23 garrett-82xv plasmashell[4811]: file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/InlineMessage.qml:265:13: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Jan 11 17:35:23 garrett-82xv remmina[4980]: The kwallet secret plugin has been initialized and it will be your default secret plugin
Jan 11 17:35:23 garrett-82xv remmina[4980]: kf.windowsystem: Cannot use KWindowSystem without a QGuiApplication
Jan 11 17:35:23 garrett-82xv remmina[4980]: [X2GO] X2Go plugin loaded.
Jan 11 17:35:23 garrett-82xv systemd[4397]: app-autorandr@autostart.service: Failed with result 'exit-code'.
Jan 11 17:35:23 garrett-82xv systemd[4397]: app-autorandr@autostart.service: Main process exited, code=exited, status=1/FAILURE
Jan 11 17:35:23 garrett-82xv systemd[4397]: app-autorandr\x2dkde@autostart.service: Failed with result 'exit-code'.
Jan 11 17:35:23 garrett-82xv systemd[4397]: app-autorandr\x2dkde@autostart.service: Main process exited, code=exited, status=1/FAILURE
Jan 11 17:35:23 garrett-82xv autorandr[4991]: Failed to load profile 'default': Profile not found (line 1637)
Jan 11 17:35:23 garrett-82xv autorandr[4992]: Failed to load profile 'default': Profile not found (line 1637)
Jan 11 17:35:23 garrett-82xv remmina[4980]: Remmina plugin glibsecret (type=Secret) has been registered, but is not yet initialized/activated. The initialization order is 2000.
Jan 11 17:35:22 garrett-82xv remmina[4980]: Remmina plugin kwallet (type=Secret) has been registered, but is not yet initialized/activated. The initialization order is 1000.
Jan 11 17:35:22 garrett-82xv org_kde_powerdevil[4852]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Jan 11 17:35:22 garrett-82xv remmina[4980]: Load modules from /usr/lib/remmina/plugins
Jan 11 17:35:22 garrett-82xv systemd[4397]: Started Virtual filesystem service.
Jan 11 17:35:22 garrett-82xv systemd[4397]: Starting Virtual filesystem service...
Jan 11 17:35:22 garrett-82xv plasmashell[4811]: file:///usr/share/plasma/wallpapers/a2n.blur/contents/ui/WindowModel.qml:23:3: Unable to assign [undefined] to QRect
Jan 11 17:35:22 garrett-82xv plasmashell[4811]: file:///usr/share/plasma/wallpapers/a2n.blur/contents/ui/main.qml:44:17: QML Image: Cannot open: file:///usr/share/wallpapers/Malefor
Jan 11 17:35:22 garrett-82xv remmina[4980]: Remmina does not log all output statements. Turn on more verbose output by using "G_MESSAGES_DEBUG=all" as an environment variable.
More info available on the Remmina wiki at:
https://gitlab.com/Remmina/Remmina/-/wikis/Usage/Remmina-debugging
Jan 11 17:35:22 garrett-82xv kaccess[4999]: Xlib XKB extension major= 1 minor= 0
Jan 11 17:35:22 garrett-82xv systemd[4397]: Reached target Startup of XDG autostart applications.
Jan 11 17:35:22 garrett-82xv systemd[4397]: Condition check resulted in Klipper being skipped.
Jan 11 17:35:22 garrett-82xv systemd[4397]: app-klipper@autostart.service: Skipped due to 'exec-condition'.
Jan 11 17:35:22 garrett-82xv systemd[4397]: Finished KDE Session Restoration.
Jan 11 17:35:22 garrett-82xv systemd[4397]: Finished KSplash "ready" Stage.
Jan 11 17:35:22 garrett-82xv systemd[4397]: Started Accessibility.
Jan 11 17:35:22 garrett-82xv systemd[4397]: Started Geoclue Demo agent.
Jan 11 17:35:22 garrett-82xv systemd[4397]: Started Autorandr.
Jan 11 17:35:22 garrett-82xv systemd[4397]: Started Profile Loader.
Jan 11 17:35:22 garrett-82xv systemd[4397]: Started Remmina Applet.
Jan 11 17:35:22 garrett-82xv systemd[4397]: Started KDE Connect.
Jan 11 17:35:22 garrett-82xv systemd[4397]: Started Firewall Applet.
Jan 11 17:35:22 garrett-82xv systemd[4397]: Started Garuda System Maintenance.
Jan 11 17:35:22 garrett-82xv systemd[4397]: Failed to start BTRFS Assistant Snapper check.
Jan 11 17:35:22 garrett-82xv systemd[4397]: app-snapper\x2dtools\x2dcheck@autostart.service: Failed with result 'exit-code'.
Jan 11 17:35:22 garrett-82xv systemd[4397]: app-snapper\x2dtools\x2dcheck@autostart.service: Main process exited, code=exited, status=1/FAILURE
Jan 11 17:35:22 garrett-82xv systemd[4397]: Condition check resulted in Print Queue Applet being skipped.
