Hello Garuda users!
I recently switched to linux so im quite new to this. kwin_wayland appears to be consistently using 70 - 90% of my cpu and what other forms says do not seem to work. other forum posts say to install NVIDIA drivers to stop the such high usage but this seems to not have worked for me (i tried both open source and propriety) even after restarts and system updates nothing has changed still high cpu usage and frame drops/stutters (i think this is related to drivers and not wayland)
any help is much appreciated to help me continue my switch to linux ![]()
CPU: AMD Ryzen 7 3700X (16) @ 3.600GHz
GPU: NVIDIA GeForce RTX 2060
garuda-inxi:
root=UUID=6205bd81-9fc4-4afa-b9ea-00a9525432b6 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_wayland dm: SDDM
Type: Desktop System: Gigabyte product: B450M DS3H WIFI v: N/A serial: N/A
Mobo: Gigabyte model: B450M DS3H WIFI-CF v: x.x serial: N/A
UEFI-[Legacy]: American Megatrends v: F50 Y1 date: 12/17/2019
Info: model: AMD Ryzen 7 3700X socket: AM4 bits: 64 type: MT MCP arch: Zen 2
gen: 3 level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3600 min/max: 2200/4426 boost: enabled
base/boost: 3600/4400 scaling: driver: acpi-cpufreq governor: performance
volts: 1.1 V ext-clock: 100 MHz cores: 1: 3600 2: 3600 3: 3600 4: 3600
5: 3600 6: 3600 7: 3600 8: 3600 9: 3600 10: 3600 11: 3600 12: 3600
13: 3600 14: 3600 15: 3600 16: 3600 bogomips: 114983
Device-1: NVIDIA TU104 [GeForce RTX 2060] vendor: Micro-Star MSI
driver: nvidia v: 545.29.02 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2023-10; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 0a:00.0
chip-ID: 10de:1e89 class-ID: 0300
Device-2: Logitech BRIO Ultra HD Webcam
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 3.1
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 6-4:2 chip-ID: 046d:085e
Display: server: X.Org v: 23.2.2 with: Xwayland v: 23.2.2
compositor: kwin_wayland driver: X: loaded: modesetting,nouveau,nvidia
alternate: fbdev,nv,vesa gpu: nvidia display-ID: :1 screens: 1
Monitor-1: Unknown-1 res: 1920x1080 hz: 60 dpi: 96
size: 508x285mm (20x11.22") modes: 1920x1080
drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: swrast
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: llvmpipe (LLVM 16.0.6 256 bits)
device-ID: ffffffff:ffffffff memory: 15.2 GiB unified: yes
API: Vulkan v: 1.3.269 layers: 4 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 2060 driver: nvidia v: 545.29.02
device-ID: 10de:1e89 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
Device-1: NVIDIA TU104 HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0a:00.1
Device-3: JMTek LLC. USB PnP Audio Device
lanes: 1 mode: 1.1 bus-ID: 1-2.4.1:6 chip-ID: 0c76:161e class-ID: 0300
Device-4: Logitech BRIO Ultra HD Webcam
API: ALSA v: k6.6.1-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.85 status: n/a (root, process) with:
lanes: 1 port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 07:00.0
IF: wlp7s0 state: down mac: <filter>
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:3 chip-ID: 8087:0aa7
lmp-v: 8 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 2.75 TiB used: 13.21 GiB (0.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lexar model: 1TB SSD
lanes: 4 tech: SSD serial: <filter> fw-rev: S0614B0 temp: 40.9 C
SMART: yes health: PASSED on: 1y 308d 3h cycles: 1,517
read-units: 93,509,039 [47.8 TB] written-units: 96,870,099 [49.5 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM001-1ER164
family: Barracuda 7200.14 (AF) size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: HDD rpm: 7200
serial: <filter> fw-rev: CC25 temp: 36 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 4y 239d 11h cycles: 1600
read: 845.69 TiB written: 88.9 TiB Pre-Fail: attribute: Spin_Retry_Count
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 13.21 GiB (0.7%)
fs: btrfs block-size: 4096 B dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 13.21 GiB (0.7%) fs: btrfs block-size: 4096 B dev: /dev/sda1
maj-min: 8:1
ID-3: /var/log raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
maj-min: 8:1
ID-4: /var/tmp raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
maj-min: 8:1
ID-1: swap-1 type: zram size: 15.56 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 67.4 C mobo: 34.0 C
Processes: 371 Uptime: 28m wakeups: 0 Memory: total: 16 GiB
available: 15.56 GiB used: 4.22 GiB (27.1%) Init: systemd v: 254
pm: pacman pkgs: 1333 libs: 379 tools: octopi,paru Shell: garuda-inxi (sudo)
default: Bash v: 5.2.15 running-in: konsole inxi: 3.3.31
Garuda (2.6.19-2):
System install date: 2023-11-16
Last full system update: 2023-11-20
(edit : ran garuda-inxi as super user)
