The problem is with libre office, Kate and the applications with Onboard .
It’s used as a on screen keyboard and used to insert words while typing on manually clicking.
Installed from
sudo pacman -S onboard
Refered link before downloading
https://archlinux.org/packages/community/x86_64/onboard/
It has some problems while using keyboard shortcuts
It sucks when typing some keyboard shortcuts
While I was trying to type in italics Ctrl + I It won’t made fonts itallic
Also it on pressing F11 it shows Ambiguous shortcut
=> In Libre office it’s actually used to display Slidebar deck
In the text editor kate it stop showing suggestions after Auto fill ing of texts
After closing Onboard it works fine
If it’s system fault please fix that it really waste a lot of time
OR
Any other solution
Naman
15 January 2022 16:44
2
First of all, this might be the problem in the onboard itself. You should ask its devs for help.
Secondly, why are you even using it if you have physical keyboard?
I use it because of a old keyboard num lock , scroll lock keys won't work, they are important to me and use it for inserting bigger words
I'm actually experimenting with the old machine
I know that the machine barely support Garuda Dr460nized than windows 10 or 11
Hoping that keyboard and some other parts won't work well
The PC has abdoned for years and I want to use it completely
Some how I managed to dual boot with win 7 and it performs good without much lags
It has all minimum requirements of 4GiB memory and +30 GiB storage
DESKTOP DETAILS
CPU - Intel CPU G230 @ 3.00 GHz (Pentium 4)
Graphic - Mesa DRI Intel HD graphics 2500
This video made on same machine
SGS
15 January 2022 18:02
4
IDK the price for them in India but free delivery and return included in Germany (incl. fee/tax) € 10.25
Summary
https://www.amazon.de/Logitech-Business-Keyboard-deutsches-schwarz/dp/B003UL1RGC
Nonetheless, contact Onboard.
Naman
15 January 2022 18:13
5
virat_17:
G230
*G2030
I had even slower processor, G2020, prior to laptop that I bought very recently (HP Omen en1036ax) on this New Year.
Although Dr460nized works perfectly fine, I would suggest some lighter DE like Cinnamon or Xfce for that hardware.
And as @SGS suggested, buy a new keyboard. They are really cheap, and will save you a lot of issues. You can grab a decent one under $4 or $5.
K
Im checking onboard web and I will correct myself and If any corrections are made I will report it
It's worthy for touch screen devices
In future Users may switch to linux when they are using touch screen laptops will help them a lot !
I have found the best solutions among many results
Onboard
It works well with Gnome apps like gedit text editor
On gedit it works fine use it rather than Kate
I think
It works because it’s built for gnome
Use gedit to type flawless without pausing or closing onboard
Install gedit by
sudo pacman -S gedit
Refer before installation
https://archlinux.org/packages/extra/x86_64/gedit/
Alternative solutions
kvkd
https://aur.archlinux.org/packages/kvkbd/
https://forum.kde.org/viewtopic.php?f=216&t=125404
Florence virtual keyboard
https://aur.archlinux.org/packages/florence/
ASCII Keyboard Art
Same topic is discussed here
Is it possible to get an on screen keyboard for accessibility. I have a 2 in 1 laptop that I would like to use in tablet mode.
The touchscreen works fine but there is no keyboard.
I also have an issue after switching back from tablet mode where the touchpad stops working?
Any guidance would be appreciated
I kindly request to distro maintainers and developers to include any kind of virtual keyboard for all DE's in the next update
SGS
16 January 2022 09:13
10
Please check for yourself where it is not included, since this issue is resolved, no developer is likely to come in here again.
If it is missing somewhere, you can then ask for addition in the appropriate areas
Issues & Assistance
KDE 3 times, Gnome, Xfce, Lxqt, Sway, BSPWM, Qtile and Wayfire.
https://mirrors.fossho.st/garuda/iso/garuda/
Onboard is included in i3wm
https://mirrors.fossho.st/garuda/iso/garuda/i3/220116/garuda-i3-linux-zen-220116.pkgs.txt
missing pakage Onboard on
Naman
16 January 2022 13:38
12
There is no very nice onscreen keyboard for KDE, afaik.
The best one is kvkbd, which is not very well maintained for Arch Linux.
Most of other editions already come with onboard. like Cinnamon, Xfce etc,
system
Closed
18 January 2022 13:39
13
